In 1977 Nissan released the B310 and three months introduced new trims GX-E and SGX-E. These featured fuel injected (EGI) engines, the legendary A14E motor. It improved upon the B310 GX which came with a single carburetor A14S motor. Nissan "introduction" Service Bulletin Number 350 highlights the features of the new model, in this case the biggest change from the GX to the GX-E is the Fuel Injection system. The Service Bulletin No. 350 is 60 pages.
PART 1 (Specifications, Engine) | PART 2 (Chassis, Body)
cover![]() | NISSAN サービス周報 NISSAN Service Bulletin
昭 和 53 年 2月 第 350 号 (S-27)
ダットサンサンー1400
排出ガス 53 年度規制適合車 NAPS
Page 1 はじめに Introduction (Page 28 PDF)
Sunny 1400 4-door Sedan GX-E サニー 1400 4 ドア セダン GX-E
Sunny 1400 Coupe SGX-E サニー 1400 クーペ SGX-E
Sunny 1400 Coupe SGX-E Instruments サニー 1400 クーペ SGX-E インストルメント
A14-type EGI-specification Engine A14型 EGIエンジン仕様
Page 4 目次 Table of Contents (Page 2 PDF)
Summary
概要 Summary
Page 5 Page 4 PDF
92PS/6,400rpm A14 engine with electronic controlled fuel injection (EGI)
プロペラ シャフトの2分割3ジョエント方式
2 division, 3 u-joint formula Propeller Shaft
Accent Stripe & Rear Emblem
車台実施始番号 CHASSIS NUMBERS E-HB310型車 Vehicle Types HB310-000001〜250000(日産車体)セダン (Nissan car body) sedan HB310-250001〜500000(冨士重工)クーペ (Fuji Heavy Industries) coupe HB310-500001〜999999(座間工場)セダン、クーペ (Zama plant) sedan, coupe
[page 6 original page 5 PDF]
車種構 成 Model Configuration 4-door GX-E 4-speed, 5-speed SGX-E 4-speed, 5-speed Coupe GX-E 4-speed, 5-speed SGX-E 4-speed, 5-speed
Model Type
車種型式 Model Type
Page 7 Page 6 PDF
--Model-- -頬別-- E - HB310 KRHEAZ H: 1400cc Z: for Okinawa -: Other -: 1200cc A: automatic transmission F: 5-speed transmission -: 4-speed transmission E: EGI-spec engine -: Carburetor-spec engine S: CT [city] D: Deluxe H: GL, SGL X: GX, SGX R: 2-door -: 4-door K: coupe -: sedan E: 1978 emissions regulations
Coupe KHB310 base is Deluxe LA= SGL,SGX Z= Cold weather model O= For Okinawa
Model Table
車種型式ー覧表 Model Type - Table List
Page 9 Page 8 PDF
Page 10 Page 9 PDF
Main Specifications Table
主要諸元表 Main Specifications Table
Page 11 Page 10 PDF
車名及び型式 ダットサン E-HB310 道 称 名 4 ドア クーペ XE KXE mm 3995 幅 mm 1590 1595 轴 距 mm 2340 |
Main Specifications Table Car name and model Datsun E-HB310 Trim four-door coupe XE KXE mm 3995 Width mm 1590 1595 Wheelbase mm 2340 |
Specification Table
明細諸元表 Specification Table
Page 12 Page 11 PDF
Page 13 Page 12 PDF
Page 14 Page 13 PDF
Page 15 Page 14 PDF
Page 16 Page 15 PDF
Page 17 Page 16 PDF
Appearance
外観四面図 Appearance All-sides Diagrams
Page 18 Page 17 PDF
Page 19 Page 18 PDF
Driving Performance Curve
走行性能曲線 Driving Performance Curve
Page 20 Page 19 PDF
Engine Performance Curve
エンジン 性能 曲線 Engine Performance Curve
Editor's Note:Horsepower A14 : 80 PS @ 6000 RPM A14E: 92 PS @ 6400 RPMNOTE: Pferdestärke (PS), abbreviation of the German term for metric horsepower, almost exactly the same as SAE Horsepower.
Torque: A14 : 11.5 kg/m @ 3600 RPM A14E: 11.7 kg/m @ 3600 RPM
A14型 EGIエンジン仕様
A14型 キャブレーターエンジン仕様
A14-type Carburetor-specification Engine
Engine
エンジン Engine
1. 概要 Summary
エ ン ジ ン
1. 概要
1-1 概要
ダットサン サニー E-HB310型車に、53年度排出ガス規制適合のA14型EGI仕様エンジン搭載車を新たに設けました。
この項では、A14型キャブレーター仕様エンジンとの相違点及び新たに追加された各装置について記載いたします。
エンジン構成
エンジン A14型 A14型 A12A型 A12型
項目 キャブレーター EGI仕様 キャブレーター キャブレーター
53年度排出 E-HB310型車 E-HB310型車 E-B310型車 - ガス規制適合車 50年 H-VB310型車 - - H-VB310型車 ガス規制適合車
エンジン本体 電子制
1.1 Summary
E-HB310 type vehicle, certified for 1978 emissions, A14 with EGI engine
E-HB310 A14 meets 1978 emissions standards E-HB310 A14E meets 1978 emissions standards E-B310 A12A meets 1978 emissions standards H-VHB310 A12 meets 1975 emissions standards
Engine Number Embossing 番号打刻
A14-121716P~
1.3 Engine something
1.4 NAPS specification
Engine Room
1.5
Engine Appearance
1.6 Engine 外観 Appearance
Left side of engine
full | original
Right side of engine
full | original
EGI Control System
1.7 A-series EGI-specification engine Control System
Engine something
1.8 Engine
Page 29 Page 30 PDF
Page 30 Page 31 PDF
Basic Engine
2. エンジン本体 Basic Engine
Page 31 Page 32 PDF
Intake Manifold Stud Length 1 45mm length 2 40mm length 28mm length (additional studs) 水穴 water holes
Piston
2.2 Piston
No. 1-4 "E"
Camshaft
Cam taken from B-HB211 (A14 Twin Carburetor)
Timing A14E: 20, 56, 58, 18 A14: 14, 54, 56, 20
Valve Spring and Valve Seat
Page 32 Page 33 PDF
Same as B-HB211 (A14 Twin Carburetor)
Rocker Cover Assembly
2.5
A14E: Gold Top A14S: Blue Top
full | original
キャブレーターエンジン仕様 Carburetor specification
EGI仕様 EGI specification
Blowby Hose ASSY
2.6 PCV Positive Crankcase Ventilation System
Manifold
2.2 Manifold
Intake Manifold
2.2.1
Page 33 Page 34 PDF
負圧取り出し Negative pressure taken out VVT バルブへ To the VVT Valve
Exhaust Manifold
2.2.2
Manifold Cover
2.2.3
Intake Manifold Gasket
2.2.4
original
取り付け面 clamp face
See 14035-H9202
Intake Manifold Bracket
2.2.5
Electronic Fuel Injection
3. 電子制御料噴射装置 Electronic Control Fuel Injection (Nissan EGI)
Page 34 Page 35 PDF
B-PA10 (L16 engine) [Stanza] B-S11 (L18 engine) [S10 Silvia]
Fuel System
3-1 燃料系
Fuel Pump, Fuel Damper
3.1.1 Fuel Pump, Fuel Damper
Fuel Filter
3.1.2 Fuel Filter
Fuel Tube
3.1.3 Fuel Tube
Fuel Injector
3.1.4 Fuel Injector
Pressure Regulator
3.1.5 Pressure Regulator
Air System
3.2 空気系
Page 35 Page 36 PDF
Air Duct
3.2.1 Air Duct
Air Cleaner Element
3.2.2 Air Cleaner Element
Air Flow Meter
3.2.3 Air flow meter
B-HB310 A31-000400 22680-H9200 B-PA10 A31-000310 22680-W5501 B-S11 A31-000121 22680-N6904
Air Duct Hose
エア ダクト ホース
3.2.4 Air duct hose
air flow meter 60mm throttle chamber 77mm
Throttle Chamber
3.2.5 Throttle Chamber
Page 36 Page 37 PDF
Air Regulator port Blowby Gas (PCV) port Idle port EGR port VVT port Distributor Vacuum port
Air Regulator
3.2.6 Air Regulator
車種 car model 流量 flow rate 識別 identification 項目 item
B-PA10 | |||
B-HB310 | B-S11 | ||
20°C flow rate | 14m³/h | 19m³/h | |
identification | A32-000400 | - |
Electronic Control System
3.3 電子制御系
Page 37 Page 38 PDF
Control Unit
3.3.1 Control Unit
Fuel Increase Correction
3.3.2 燃料増量補正
Page 39 Page 41 PDF
Air-fuel ratio switching instrumentation
3.4 空燃比切替装
Page 40 Page 42 PDF
EFI Relays
3.5 電子制御燃料噴射装?のリレー類
Page 41 Page 43 PDF
3.5.1 EGI Relay
3.5.2 Fuel Pump Relay
EGR
4. 排気 ガス還流(EGR)装置
4. Exhaust Gas Recirculation (EGR) Equipment
Page 42 Page 44 PDF
EGR Equipment
4-1 排気ガス還流装置の装置;
4-1 EGR Equipment
EGR装置は、キャブレター仕様と同じ負荷比例代です。制御信号として排圧のほかに吸入空気量(負荷)に比するベンチュリー負圧を加する
COMPONENT PARTS PART NAME FUNCTION 1 neutral switch neutral position detection 2 speed sensor, speed amp detection vehicle speed from about 45 km/h 3 TV valve water temp (about 50C) ??? 4 VC solenoid valve ? 5 VVT valve ? 6 EGR control valve ?
Page 43 Page 45 PDF
WATER TEMP TRANSMISSION VEHICLE VC solenoid VENTURI (TV VALVE) GEAR POSITION SPEED valve about 50C or less - - - about 50C or more neutral - ON except neutral ~45km/h or less OFF ~45km/h or more ON
EGR 2
4-2 排気ガス還流装置の概要
4-2 Overview of the Exhaust Gas Recirculation system
EGR Control Valve
4.2.1 EGR Control Valve
VVT Tube
4.2.2 VVT Tube
VVT Valve Bracket
4.2.3 VVT Valve Bracket
Page 44 Page 46 PDF
取り付け mounting
EGR Passage
4.2.4 EGR Passage
排気ガス涌 路
Straight Connector
4.2.5 Straight Connector
互換性:なし(A12A型、キャブレター仕様と有)
Compatibility: None (A12A type, carburetor specifications and ?)
EGR Tube
4.2.6
水温 water temperature
TV = Thermal Valve
Vacuum Piping Figure
4-3 バキューム配管実態図
4-3 Vacuum Piping Figure
Page 45 Page 47 PDF
長さ length
識別色 identification color 緑 green 白 white 青 blue 黄 yellow 桃 peach
部位 part
No 長さ 識別色 部位 1 170mm (green) vacuum gallery - pressure regulator 2 90mm (peach) VVT tube - VVT valve 3 200mm (white) VVT valve - TV valve side 3-way connector 4 70mm (yellow) vacuum gallery - distributor side 3-way connector 5 50mm (yellow) vacuum gallery - distributor side 3-way connector 6 190mm (white) vacuum gallery - TV valve 7 170mm (white) EGR control valve - TV valve side 3-way connector 8 110mm (white) TV valve - 3-way connector 9 540mm (yellow) distributor - 3-way connector 10 120mm (blue) vacuum gallery - VC solenoid valve [Vacuum Cut] 11 200mm (blue) VVT valve - VC solenoid valve 12 200mm (blue) throttle chamber - vacuum gallery 13 90mm (green) vacuum connector - vacuum gallery 14 130mm (yellow) throttle chamber - vacuum gallery (distributor use) 15 230mm (blue) throttle chamber - VC solenoid valve 16 170mm (white) throttle chamber - vacuum gallery (EGR control valve use) 17 blanking cap
Air Cleaner and EAI
5. エア クリナー及び二次空気導入(EAI)装置 Air Cleaner and Exhaust Air Induction (EAI) Equipment
Page 46 Page 48 PDF
left caption: 接続ホース Connecting Hose
right caption: EAI バルブ Valve
full | Japanese
lower caption: 二次空気導入チューブ Secondary air induction tube
EAI Hose
5.1
EAI Valve
5.2
Page 47 Page 49 PDF
EAI Tube
5.3
Engine Electrical
6. Engine 電装 Electrical
Distributor
6.1 Distributor [points type]
Hitachi D4A7-01 Mitsubishi T4T00475
Centrifugal Advance 12 degrees maximum @ 2400 rpm:
full
Vacuum Advance 13.5 degrees maximum:
full
Alternator
6.2 Alternator
IC internally regulated Hitachi LR150-36 Mitsubishi AQ2250C31
PA10 EGI [Datsun Stanza]
Fuel System
7. 燃料系統 Fuel System
燃料系 Fuel System
基本的には、キャブレーター仕様とはぼ同じですが、燃ホースの径がー部異なります。Basically, it is the same to pot and carburetor specifications - diameter of the fuel hose differs.
仕様 Specification
... フューエル ゲージ ユニット Fuel Gauge Unit サーミスター式(GL以上) Carburetor: Thermistor type (GL or more) EGI: Thermistor type ... フューエル チューブ Fuel Tube アウトレット Outlet 6.35mm carburetor 12mm EGI リターン Return 6.35mm carburetor 8mm EGI
8. ????
Exhaust System
[page 49 original, page 52 PDF]
8. 排気系統 Exhaust System
排気系 Fuel System
排気系は、触媒コンバータ(サイズ、容量)、... Exhaust system, catalytic converter (size, capacity), ...
Chassis
See PART 2
Chassis * Propeller Shaft
Body
See PART 2
* Accent Stripe * Rear Emblem * Rear Floor Insulator
Body Electrical
See PART 2
* Wiring and Relays * Tachometer * Washer Tank * Air Conditioner (Cooler Option)
