Brake Wiring
Revision as of 23:15, 1 August 2016; view current revision
Category: Wiring
Dash Brake lamp lights up if there is a problem.
[hide]
Brake Stop Lights
See: brake stop lamp wiring
Hand Brake Switch
Lamp switch for Hand Brake pull-handle was fitted to USA 1200s, Japan Sunny Truck staring 7510, and is fitted to newer Australia utes.
The switch turns on the warning lamp
Parking Brake Lever
1972 USA Owners manual (Page 13 ... 13):
When the parking brake is applied, the brake warning light will glow
full
Dash-top Lamp (AUSTRALIA)
Cluster Gauge Lamp (USA/late JAPAN)
Dash Lamp (early JAPAN)
UTE: switch wire goes up back wall
Pressure Loss Switch
A brake check switch is used on North American 1200s to signal if there is a problem with the brake pressure.
See Main Article: Warning Light Switch#Wiring
Schematic
The dash lamps are always connect to 12V when IGN switch is on. They only light up when a switch grounds the bulb. A switch is fitted to the hand brake lever. When you pull the lever, it grounds the circuit.
  • G: Green wire from IGN fuse to dash cluster lamps
  • B: Black wire to main body earth bolt in engine compartment
  • Y/G: Yellow wire w/Green stripe, from switch to bulb, grounds the bulb
21612.jpgAlbum 21612
(Most 1200s don't have the Check/Service Warning Light Switch)
21611.jpgAlbum 21611
