The engine number is stamped on the engine block itself. It positively identifies the engine size (e.g. A12) as well as the serial number. The mark is always on the left (distributor) side of a Datsun A-series engine, but the location varies with the year. If you do not see the number, wipe the grease off the engine block.
Engine Number
Left Side of Engine --------------------------------- To about 1980 | From about 1981 Below #4 plug | Below #2 plug ---------------------------------
Late: above fuel pump boss, below #2 plug
1970-1973 A12 Engine ID Mark is below #4 spark plug, on jutting pad (above starter)
1974~1981 A12 ID Mark, below #4 plug
full
~1982-1995 A12 ID Mark Type B is below #2 & #3 spark plugs, center of block, above fuel pump, forward of distributor
A12-E
Early ID - Stamp is below #4 spark plug, on vertical pad
Early Tall-Block (A13/A14/A15) ID Mark is below #4 spark plug, aft of distributor
Late Tall-block (A14 or A15) ID Mark location is below #2 & #3 spark plugs, center of block, above fuel pump, forward of distributor
Tall Block Comparo: 1974 A12 vs 1974 A13 - Left: A12, Right: A13 tall block
Matching Numbers
If the engine is the original one, the serial number will match that on the Model Number Plate.
Nissan A Engines: Overview | A10 | A12 | A12A | A13, old | A13, new | A14 | A15
