Bumper
Revision as of 23:50, 30 August 2016; view current revision
Categories: Body | Fibreglass
Adorning the extreme ends of the Datsun 1200 are chrome bumpers. Although the front bumper is shared by all models, the rear bumper differs between Coupe, Sedan, Van and Sunny Truck. The revised front bumpers have bolt holes for USA and Japan license plates (two sets of holes), while early ones are specific.
[hide]
FRONT - sedan, coupe, wagon, ute
REAR
* Sedan  license number lamp
* Coupe  license number cutout
* Wagon  plain straight bumper
* Ute    bumperettes (rubber pads)
21426.jpgAlbum 21426
OVERRIDERS
21439.jpgAlbum 21439
Front
The front bumper= of a 1200 is a fairly straight chrome bar and has two small notches on the bottom for the front turn-signal lights:
21425.jpgAlbum 21425
All 1200 models used the same front bumper, including Truck through March 1978
North America 1200 came with rubber overriders
10129.jpgAlbum 10129
The front bumper is in three pieces, although it is sold factory assembled as one piece.
  • Two long front sections (left and right) that curve and the end to wrap around the side just a little
  • a shallow degree binding piece (the front bumper is a slight V)
21427.jpgAlbum 21427
inside
Measurements
Bumper bar
Stay bolt holes: 710 mm apart
Height: ~90 mm
Depth at Center: ~30 mm
Depth off Center: ~45 mm
Has both plate holes:
* License Plate holes USA: 7" (~178mm)
* Number Plate holes Japan 210 mm (some threaded, some not)
Some have extra cosmetic front bolt holes:
Outer front bolt holes: 300 mm outboard of stay holes
24720.jpgAlbum 24720
Stays
Early vs late stays have a different bolt angle and spacing (not interchangeable).
Early 1200s use 8mm bolts (fastening Stay to Hood Ledge)
08110-81662 BOLT (up to '72-6)
Later 1200s use 12mm bolts
08114-22510 BOLT (from '72-7)
Changed to a longer 30mm long bolt for 1976 JPN (1973 in USA)
Early Front Bumper Stays: 62671-H1001 to June 19792 (8 mm chassis bolts)
21433.jpgAlbum 21433
Early vs Late stays (notice notch in late version): 62671-H1002 from July 1972 (12 mm chassis bolts)
24909.jpgAlbum 24909
Stay Measurements
early chassis rail bolt holes: ?
late chassis rail bolt holes: ?
B120
STD utes used a flat-silver painted bumper (62651-G1001). DX utes used a chrome bumper (62651-H1001).
From April 1978, Sunny Truck used a rubber-ended bumper:
20832.jpgAlbum click to view 20831.jpgAlbum click to view
Also available in Chrome or Black
21428.jpgAlbum 21428
New Zealand
Some B120 SportStar utes had black bumpers:
385.jpgAlbum 385
B140 Bakkie
The B140 Bakkie has a larger flat bumper, painted black, with lights in the face.
7403.jpgAlbum 7403
PB110
PB110 Sunny Excellent came with a unique front bumper with a separate bar and S-curved ends. Every piece is different from the 1200 (bar, stays & brackets). The fasteners (bolts, washers and shims) are same as the 1200.
H25 bumper
459.jpgAlbum 459
Rear
Rear bumpers differ by 1200 model, and are distinguished by the license plate lighting provision. PB110 used the same rear bumpers as regular B110.
  • Sedan rear bumper has a small light in the center facing up to illuminate the license plate
  • Coupe bumper has a notch for the license plate:
  • Wagon is smooth with no notch and no light:
  • Ute has no rear bumper, just rubber pads
  • North America 1200 had rubber overriders
    3250.jpg 21439.jpgAlbum click to view
  • Alternative bumper on a sedan rear
Coupe Rear
Coupe bumper has a notch for the number plate, the notch is wide to acommodate Commonwealth plates as well as the narrower Japan plates.
H18 (coupe) bumper bar
H19 North America coupe with overriders
post
full full full
Truck
Ute had two small rubber pads (for the tailgate to drop against), and two black corner bumperettes:
Custom
Sunny B210 bumper fitted to Sunny Truck]
21423.jpgAlbum 21423
B140 Bakkie
Late-model B140 Bakkie rear has the standard two black corner bumperettes but with reflectors in the face.
RED starboard
RED port
Starting with the 2003 facelift?]
6427.jpgAlbum 6427
The latest bakkies had Reflectors in the bumperettes
22424.jpgAlbum 22424
8986.jpgAlbum 8986
1973 USA Bumpers
For 1973, USA models got redesigned bumper-to-body brackets to meet FMVSS No. 215 (2.5 mph bumpers). They also used larger bumper pads. The chrome parts look similar but are different.
174_57c618c25c43a.jpgPost 480921
NOTE: A 1973 front bumper with brackets does not fit a 1971 or 1972 model
15928.jpgAlbum 15928
H70 front bumper
H70 rear sedan bumper
H71 rear coupe bumper (notched for license plate)
Implementation Details:
Two-piece construction
Note the double-set of bolt holes for the stays (inboard of the lamp cutouts)
th_Bumper_1973_inside_Left.jpg th_Bumper_1973_below.jpg th_Bumper_1973_above.jpg
License Plate Lighting
 Also see: Rear License Plate Lamp
For North America in order to meet new FMVSS regulations, 1973 Sedan rear bumper was modified to have a brighter license plate lamp (the coupe with its dual lamps was already bright enough). The lighting moved from the bumper to near the plate.
1973 Sedan - bumper bar with no light (H70)
1427.jpgAlbum 1427
The resulting bumper was similar to a wagon bumper but came with large rubber overriders and extra holes to bolt to the larger 1973 stays.
1973 apron panel is same as earlier
174_57c618dba3523.jpgPost 480921
South Africa
1200s in South Africa, at least from 1973, were factory-fitted with Datsun 510 bumpers. These have a bit longer overbend, but are the same width.
8349.jpgAlbum 8349
2738.jpgAlbum 2738
Overriders
JDM models came without rubber overriders, but all North American models had rear overriders front and rear.
NA bumpers with overriders removed (note holes in bumper)
OPTION Overriders
Available from Datsun USA dealers were steel tubular overriders from Amco:
Amco 5563 for Coupe
Fibreglas
FRP (fiber reinforced plastic), fiberglass or carbon fibre
From Bprojects mail order: Stock bumper design made in FRP with White Gel Coating
Custom Bumpers
Bumperettes
Black painted
Bull Bar
Bull bar or roo bar will keep random large animals from smashing your radiator grille.
Heavy-Duty Bumper with Bilby Guard
Bull Bar
sidedraught's Bull Bar:
Safari Bar
Bumperless Look
Bumper removed
7926.jpgAlbum 7926
Chromeless Coupe
14005.jpgAlbum 14005
Smooth Coupe
17954.jpgAlbum click to view
Bumperless Custom
Smooth Utes
Bumpers backside Sunny Trucks (bumperettes removed)
2137.jpgAlbum 2137
See main article: Bumper Parts
バンパー
