Bulbs
Revision as of 01:09, 7 September 2018; view current revision
<-- Back to: Lighting System
5021.jpgAlbum 5021
1. Exterior single element, one bottom contact
Rear T/S (turn signal) -- See Tail Lights
* 23 watt Type 1073
  * North America can also use 27 watt Type 1156 e.g. Wagner 1156
  * Japan
* 21 watt (other countries)
5021.jpgAlbum 5021
REAR INDICATORS
<-- single bottom contact
2. Exterior dual element, two bottom contacts
Dual-filament bulb
* Front park & T/S -- See Front Combination Lamp
* Rear Tail & Stop -- See Tail Lights
23/8 watt Type 1034
  * Japan
  * North America (can also use 27/8W Type 1157)
12/5 watt
  * other countries
5021.jpgAlbum 5021
DUAL FILAMENT BULB
double bottom contacts -->
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
5021.jpgAlbum 5021
3. FUSE
<-- 10A
23313.jpgFuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
5021.jpgAlbum 5021
4. FUSE
15A -->
23313.jpgFuse Box
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
26945-H4600 (not sure if this lamp only, or whole unit)
* Type 3175 e.g. Wagner 12100
5021.jpgAlbum 5021
5. SEAT BELT LAMP
5023.jpgWarning
6. Dome Lamp
10 watt (room lamp) 26736-89902
* Type SV7, ~29 mm long (pictured) seems to fit best, but are usually 3w or 5w
* Type SV8 SV8 5168 10 watt
* SV7-8 Festoon base (pointy ends)/ LES / SV7
Some parts stores specify the larger unit (Type 3175) which is readily available, but the Room Lamp socket must be bent slightly to fit.
5021.jpgAlbum 5021
6. ROOM LAMP
20758.jpgDome Lamp
7. Instrument Panel Lamp
T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
* Cluster Gauge illumination bulbs, warning bulbs
* SQUARE METER ONLY: + two dash T/S bulbs
5021.jpgAlbum 5021
7. WEDGE HOLDER & BULB
26261-89902 1.7W bulb (ROUND GAUGE B110)
26711-89902 2.7W bulb (ROUND GAUGE B120)
26261-89900 3.4W bulb (SQUARE GAUGE)
24884.jpgWedge Lamps
26260-89900 Wedge Socket
Twist-lock holder (7 used in round dash). These sockets fit bulbs with a W2.1x9.5d base (aka W2, miniature wedge, or T5 base.
Nissan 26260-89900 Wedge Socket $3.28 USD each [twist-in type]
* Type V-2 Instrument Panel socket T10 cluster plug lamp for 1/2" or 13m hole
* 7 or 8 for bar meter dash
* 7 for B110 round gauge dash
* 8 for B120 round gauge dash
  * #26261-89902 1.7 watt bulb (ROUND GAUGE)
     2.7 watt Type 161 is often specified by aftermarket
JPN B110
  * #26261-89900 BULB-12V, 3.4W SQUARE METER 7
  * #26261-89902 BULB-12V, 1.7W ROUND METER 7
JPN B120
  SQUARE METER
   * #26261-89900 -7803 12V-3.4W 8
  ROUND METER
   * #26261-89902 BULB 12V-2.7W 6
   * #26711-89900 BULB 12V-1.7W 2
   * #26261-01G00 BULB 12V-1.4W 8910- F/EXH TEMP
   * #26711-89900 BULB 12V-1.7W 8910- F/BRAKE WARNING
T10 glass with T5/W5W base
* Type 194 1.0 watt
* Type 161 2.7 watt Type 161 specs
* Type 158 3.4 watt
* Type 159 6 volt
CAUTION: Type 159 is identical looking, but only 1.0 watt 6.3V. In addition there are several others including lower and higher wattage versions.
Bar Cluster Gauge uses 7 or 8 lamps including the T/S bulbs
27148.jpgAlbum 27148
8. Exterior Lamp
5021.jpgAlbum 5021
CAUTION: various watts
8. bulb for:
* Side Marker
* License Lamp
* Reverse Lamp
Side-marker lamp
6 watt (flashing, non-North America)
8 watt (North America, non-flashing)
  * Wagner 97
  * Sylvania 97 (9.32 watt  nominal)
License Lamp
7.5 watt Coupe, Van 26715-89901 Ichikho
10  watt Sedan, except North America
7.5 watt Sedan USA
  * B29.012.625 (7.5w) or [Toshiba A12V8W 6 7]
Reverse Light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
5021.jpgAlbum 5021
9. Dash T/S bulb
<-- 1.7W round dash
<-- 26260-H1800 SOCKET-WITH LEAD WIRE
BULBS FOR DASH T/S INDICATORS
* #26261-89900 BULB 3.4 watt (SQUARE GAUGE)
* #26711-89900 BULB 1.7 watt (ROUND GAUGE)
  can use 1.9 watt Type 1445 e.g.Wagner 1445
  1.9W G3-1/2 (7/16" globe) BA9S, 22.7 mm long 1445 specs
14515.jpgAlbum 14515 IMG_1398.jpg 21615.jpgAlbum 21615
Lamp Specifications
Australia
1974 B120 Owner's Manual (Page 30 ... 30)
Bulb Chart
Headlight unit 12V-50/40W
Directional    12V-21/5W
Parking        12V-21/5W
Side Flasher   12V-6W
License Plate
  Sedan        12V-10W
  Wagon, Van   12V-7.5W
Rear Combo
  Tail         12V-21/5W
  Stop (brake) 12V-21/5W
  Turn Signal  12V-21W
  Back-up      12V-21W
Meter (bar type)
  illumination 12V-3.4W
  IGN warning  12V-3.4W
  T/S          12V-3.4W
  BEAM         12V-3.4W
  OIL          12V-3.4W
  Clock        12V-3.4W
Room light     12V-10W
Rectangle Meter specs (1974 B120)
Head Lamp
26705-04101 Sealed beam unit (Koito)
26705-08700 Sealed beam unit (Koito)
Front Combination Lamp - Early
26717-89920 BULB (12V-23/7W)
26261-89900 BULB (12V-3W)
Front Combination Lamp - Late
26717-89900 BULB (12V-23) [P21W]
26261-89920 BULB (12V-8/3.4W) [P21/5W???]
* or 26261-89925 BULB (12V-8/3.4W) 7804-
North America
1972 USA Owners manual (Page 36 ... ):
Bulb Chart
  Spec. SAE No. Nissan/Ichiko
Headlight unit 50/40W 6012 26705-04201
Front Combo Light
  Direction and Parking
23/8W
1034*
26717-89920
Side marker 8W 67 26715-89902
License plate 7.5W 89 26715-89901
Rear Combo Light
  Tail
  Stop (brake)
  Turn signal
  Back-up light
23/8W
23/8W
23W
23W
1034*
1034*
1073^
1073
26717-89920
26717-89900
Wiper Knob (1973) 3.4W 158  ?
Heater control (1973) 3.4W 57  ?
Meter (round gauge)
  illumination
1.7W
161
26711-89900
  IGN warning 1.7W 161 26711-89900
  Turn Signal 26713-89900
  BEAM 1.7W 161 26711-89900
  OIL warning 1.7W 161 26711-89900
  BRAKE warning 1.7W 161 26711-89900
Room light 10W n/a 26736-89902
* 1157 can replace type 1034 but uses more current
^ 1156 can replace type 1073
Portugal
Opticas 12V-50/40W
12V-21/5W Luz de mudança de direcção o de presença
12V-6W Luzes laterais de mudança de direcção
12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras
 12V-5W luz de presença
 12V-21W luz de stop (travões)
 12V-21W luz de mudança de direcção
 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos
12V-3W Luz avisadora da ignicão
12V-3W Luz indicadora dos máximos
12V-3W Luz avisadora da pressao do óleo
12V-10W Luz interior
12V-3W Luz de iluminação do relogió
Nissan Part Numbers
26261-01G00
Nissan 26261-01G00 BULB 8910- 12V-1.4W F/EXH TEMP
Nissan 26260-95W00 SOCKET ASSY-BULB 8910- F/EXH TEMP
26261-89900
Nissan 26261-89900 BULB 3.4 watt [F/SQUARE METER]
Nissan-Toshiba 158p 3.4W
27147.jpgAlbum 27147
Type 158 specs 14V-3.36W Miniature Wedge T3-1/4 Glass (25.8mm MOL 10mm diameter) W2.1x9.5d Base
#9. Instrument Panel Turn Signal
#7. Instrument Panel Lamp
Meter Part Numbers SQUARE GAUGE DASH
* JPN B110 bar meter
* JPN B120 -7803 TURN SIGNAL (2)
* JPN B120 8910- BRAKE WARNING (1)
* Many 2000s era Nissan Cargo Lamp, Marker Lamp, Tail Lamp, etc
26261-89902
Nissan 26261-89902 BULB 12V-2.7W
Meter Part Numbers B120 ROUND GAUGE DASH
26705-04101
Headlight Part Numbers
* JPN B120 -8910 (except Okinawa -8503)
26705-08700
26705-04201
26705-04201 UNIT-SEALED BEAM (ICHIKHO) <> #26705-89925 (ICHIKHO)
* 12V-50/40W
* USA B110
26705-89905
26705-89905 UNIT-SEALED BEAM (KOITO)
* 12V-50/40W
* USA B110
26705-89920
26705-89920 HEAD LAMP UNIT IKI
26705-89925
26705-89925 UNIT-SEALED BEAM (ICHIKHO) <> #26705-04201 (ICHIKHO)
* 12V-50/40W
* USA B110
* JPN HEAD LAMP UNIT IKI F/OKINAWA -8503
26705-C9920
26705-C9920 HEAD LAMP UNIT [square type]
* JPN B120 8910-
26711-89900
Nissan 26711-89900 BULB 12V-1.7W
* G10 glass with BA9S base (10MM Globe with 9mm Bayonet mount)
27145.jpgAlbum 27145 24410.jpgAlbum 24410 27146.jpgAlbum 27146
#9. Instrument Panel Turn Signal qty 2
Meter Part Numbers round guage
* USA B110
* JPN B110
* JPN B120 7804-
26717-89900
26717-89900
26715-89901
26715-89901 BULB 12V-7.5W (ICHIKO)
* 12V-7.5W
License Lamp Part Numbers
* USA B110 Sedan, Coupe
* JPN B120 Truck
* JPN B110 Coupe
* JPN B110 Van 1970-1971
26715-89902
26715-89902
* 12V-8W
* USA B110 front & rear Side Lighting Parts Numbers
26717-89920
26717-89920 BULB 12V-23/8W (ICHIKHO)
* 12V-23/8W
Front Combination Lamp Part Numbers Direction and Parking
* USA B110
* JPN B110
* JPN B120 -7308
Sedan Rear Combination Lamp Part Numbers
Coupe Rear Combination Lamp Part Numbers
Truck Rear Combination Lamp Part Numbers
Van Rear Combination Lamp Part Numbers
* USA B110
* JPN B110
* JPN B120 Truck
26736-89902
26736-89902
Room Lamp Part Numbers
* USA B110
* ? JPN except Truck, Van ?
