B310 number plate lamps
Revision as of 23:35, 28 August 2022; view current revision
Category: Datsun B310
The rear license plate was illuminate by lamps either above plate, below plate or on both sides.
f74268333akasrl311-img600x450-1227531832kwtsss12529.jpg 13567.jpgAlbum 13567 minorimn-img600x400-1277726772ktkstn76588.jpg
Japan-market
Round Headlight   Rear Plate below bumper
Square Headlight  Rear Plate above bumper
Large Bumper      Rear Plate above bumper
Round Headlight   Plate below bumper, lamps above plate (tucked up under bumper)
                  all VB310 are round headlight models
Square Headlight  Plate above bumper, lamps in top of bumper
                  Plate above bumper, side lamps OPTION S/K(A14)
Large Bumper      Plate above bumper, lamps on either side of plate
* Large Bumper standard equipment all WB310
               option Sedan/Coupe
Early: top-illuminated
Late:  bottom-illuminated
       side-illuminated (OPTION Sedan/Coupe)
Van:   bottom-illuminated
Large Bumper Models
Large bumper models had no number plate lamp in the bumper -- both early and late models placed the Number Plate and its lamps above the bumper.
Sedan/Coupe  side-illuminated  twin lamps either side
Wagon        top-illuminated   twin-bulbs under chrome trim
Early Large Bumper
Datsun-B210-9.jpg 8853.jpgAlbum 8853
Late Large Bumper (has rubber strip along face)
174_5b5cea85855fc.jpgPost 489076 e86542521carogon_6666-img600x450-12261215557ne6i221743.jpg
Sedan and Coupe Mid
7812-7909 with Shock Absorbing Bumper
28629.pngAlbum 28629
Sedan and Coupe Late
7909- OPTION
28630.pngAlbum 28630
Wagon
For WB310 (Sunny California, etc.) 28627.pngAlbum 28627
Small Bumper Models
Vans used bottom-illuminated type: Two small button-type lamps on the top edge of the bumper.
Europe | Japan
11701.jpgAlbum 11701 12342.jpgAlbum 12342
Early had top-illuminated plate with lamp tucked up under bumper
f74268333akasrl311-img600x450-1227531832kwtsss12529.jpg m51627383hirakka-img600x450-1198906974dsc02065.jpg
Late bottom-illuminated | side-illuminated
Late Sedan bottom-illuminated (two small lamps on bumper) GL | DX
14850.jpgAlbum 14850 24773.jpgAlbum 24773
Late Sedan side-illuminated like 1973 B110
Van
28626.pngAlbum 28626
Sedan and Coupe Early
Early sedan & coupe had top-illuminated plate with lamp tucked up under bumper. It used a single lamp of the same type as B110 coupe and B120 ute.
1200 coupe/ute lamp
20724.jpgAlbum 20724
28628.pngAlbum 28628
7910-
Wagon
WB310 sport wagon had the rear number plate lamp above the plate under a trim piece.
Chrome trim | Sunny California plastic trim
6778.jpgAlbum 6778 e86542521carogon_6666-img600x450-12261215557ne6i221743.jpg
WB310 vs VB110 - similar number plate lighting
95.jpg 2998.jpgAlbum 2998
Type H85 KB110 style lamp shining down (early bumper)
Type H88 Cherry style lamps on top of bumper (late bumper)
Type H856 lamps on either side of plate
Type H87/H89 ""
Lamp
LICENCE LAMP ASSY RH
26510-H8500 K,S -7811
26510-H8560 K,S 7910-8010 IKI
26510-H8565 *S.A14 7910-8010 F/SHOCK AB BUMPER IKI
             K.GS,ES
             S+K.GX,RSE
26510-H8700 *K 7812-7909 F/SHOCK AB BUMPER IKI
26510-H8765 *K.A14 7910-8010 F/SHOCK AB BUMPER IKI
26510-H8800 S,K 7812-7909 IKI
26510-H8900 *S 7812-7909 F/SHOCK AB BUMPER IKI
26510-H9400 V
26510-H9800 W 7812-
LICENCE LAMP ASSY LH
26515-H8565 *S.A14 7910-8010
             K.GS,ES 8011-
             S 8011-
26515-H8700 *K 7812-7909 F/SHOCK AB BUMPER IKI
26515-H8765 *K.A14 7910-8010 F/SHOCK AB BUMPER IKI
26515-H8900 *S 7812-7909 F/SHOCK AB BUMPER IKI
ライセンス ランプ
B310 licence lamp
B310 ライセンス ランプ
Round Bumper Lamps
 26510-H8560 S,K late
 26510-H9400 Van
#26510-W5000 A10
sedan or van? silver. With LW & B wires, bullet connectors
28632.jpgAlbum 28632 28633.jpgAlbum 28633 28634.jpgAlbum 28634
Black, part number unknown. May be B310 or A10. With IKI 6101 lens
28637.jpgAlbum 28637
Black with GW & B wires, bullet connectors. From eBay with long wires. On earth is riveted, the other brazed
28635.jpgAlbum 28635 28636.jpgAlbum 28636
26510-W5000
A10 part number. GW & B wires, bullet connectors, both earths brazed to lamp housing
28638.jpgAlbum 28638
26510-W5000 silver with RW & B wires, bullet connectors IKI 6101 lenses
28639.jpgAlbum 28639 28640.jpgAlbum 28640 28641.jpgAlbum 28641
Lens
26511 LENS-LICENCE PLATE LAMP RH レンズ、ライセンス ランプ
26511-H5000 S,K -7909 [similar to KB110 license lamp ]
26511-H8700 *K 7812-7909 SHOCK AB BUMPER IKI 2
26511-H8900 *S 7812-7909 SHOCK AB BUMPER IKI 2
             *S,K.A14 7910- SHOCK AB BUMPER
26511-H9800 W 7812-
26511-M0200 S,K 7910-
             V
Applied Model Code
M02: designed for E10RT Nissan Cherry/Datsun 100A
26511-M0200 REAR NUMBER PLATE LAMP LENS, IKI 6101
28624.jpgAlbum 28624 28625.jpgAlbum 28625
