Hitachi R145 was used in 4WD applications as the rear final drive. Many applications used a 4-bolt rear cradle which contained the entire suspension except for the struts.
Coupling Type - Hydraulic (alloy case) Coupling Type - Electric (alloy case) Short Pinion type (cast iron) Long Pinion type (cast iron)
Standard type [short pinion] N14, N15 Pulsar B13, B15 Sunny N30, JU30 M12, G10, RB14, W11 P12, VW11, W11
Short Pinion type (38300-5V200 NN30 R'nessa SR20 Rear diff shown)
2 rear mounting studs + 2 front mounting ears
Long pinion type (N14 Pulsar including RNN14 GTI-R)
2 rear mounting studs + 4 front mounting bolt bosses
Hydraulic clutch Coupling Type C24 Serena M12 Prairie Liberty K11 March P12 Primera VW11V Expert エキスパート U30 0108-
Electric Coupling Type T30 X-Trail Murano USA Z50 electric coupling
Sources
R145 was mostly used with 4-cylinder engines
Z50 2002-2007 Muranoᵂ USA N14 1990-1995 Pulsar N15 1995-2000 Pulsar#N15 B14 1995-1999 Sunny B15 1999–2004 Sunnyᵂ RB14 1995-2000 Rasheenᵂ C24 1999-2000 Serena JPN (IRS post-vanette) 2001-2012 Asia markets 2007-2023 China K11 9911-0010 Micra/Marchᵂ CG10DE+CGA3DE M12 9811-0105 Prairie Libertyᵂ N30 1997-2001 Nissan R'nessaᵂ P12 2001-2008 Primeraᵂ T30 2001-2007 X-Trailᵂ JU30 2000-2003 Bassaraᵂ U30 1998-2003 Presageᵂ VW11 1999-2006 Expertᵂ エキスパート W11 1999-2005 Avenirᵂ
J10 2006-2012 Nissan Qashqaiᵂ/Dualis Nissan Rogueᵂ Renault Kangooᵂ HY 2007-2017 Renault Samsung Koleos/QM5ᵂ
Gearset
2.466 split case with coupling 2.466 split case with coupling 3.357 3.692 3.700
38100-CA000ᴳ GEAR SET-FINAL DRIVE 37/15=2.466 $617 USD [split case] T31 J11 U31 Z50 Z51 38100-4N500ᴳ GEAR SET-FINAL DRIVE 37/15=2.466 [split case] C24,K11,M12,P12,T30,VW11,W11,JU30,U30 38100-10E60ᴳ GEAR SET-FINAL DRIVE 47/14=3.357 [short pinion] M12, N30, W11, U13 38100-11E65ᴳ 48/13=3.692 [long pinion] JU30 9911-0108 KA24DE+YD25DDT, B15, G10, U30 38100-03G10ᴳ GEAR SET-FINAL DRIVE 37/10=3.700 [long pinion] B13, B14, N14, N15, RB14
LSD
Both Nissan and Cusco sell rear LSD
38760 38411-20R21 COUPLING ASSY-VISCOUS $584 USD * superseded 38411-20R14 * N14 JDM.SR20DET * M11 USA Axxess 0189-0394 *4WD.KA24E.SGL.FA (R200?)
Cusco MZ TYPE-RS No. LSD684 1.5 way Subaru BP/BL (2003-2009 Legacy/Liberty) MZ 1-way
Coupling
The coupling takes the place of a center differential. These models have a totally different case, which is split on the axle centers.
Electric Coupling
The electric coupling, when not powered, allows the rear diff to free-wheel (FWD mode).
When fully powered, the propeller shaft powers the diff as normal.
The coupling is designed to work at any setting from non-powered to fully-powered, for various torque splits.
For this reason, operating as a RWD-only diff is complicated. You could use a relay and fully power it, but the failure mode would be to stop transmitting power.
Z50 USA Murano (CVT) T30 JDM X-Trail GT
Hydraulic Coupling
38760M
38760-4N210 COUPLING ASSY-HYDRAULIC * K11 March
38760-4N215 COUPLING ASSY-HYDRAULIC * C24 Serena * M12 Prairie Liberty * P12.QR20DE.AT 0101- * VW11V Expert エキスパート
38760-4N815 COUPLING KIT-HYDRAULIC * superceded 38760-4N215? * U30 0108- * JDM.U30,C24,M12,JU30,P12,VW11,W11 * P12.QR20DE.AT 0101-
Gasket
38320-01G02 or Liquid Gasket
Case
38310 CASE (CARRIER COMPL-GEAR)
COUPLED TYPES 38310-8H500 [electric coupling] T30 38310-4N500 [hydraulic coupling] C24, M12, JU30.QR25DE, P12, U30, VW11, W11
SHORT-NOSE 38311-20E00 * N30 Rnessa * JU30 9911-0108 KA24DE+YD25DDT 38310-4N500 * JU30.early
LONG-NOSE 38311-71Y00/38311-71Y02 * B13, B15, M12, G10, N14, N15, RB14, W11
R180 38311-S6200 * USA.M11 non-LSD R200 38311-S7000 * USA.910+M10+M11.LSD+S130
Weight
Longnose R160 < 56 lbs Longnose R180 ~ 66 lbs Longnose R200 76 lbs Shortnose R200 72 lbs
Rear Suspension
431 REAR SUSPENSION STRUT TYPE B13,B15 drum brake N14,N15 DB *DISC OPTION SR20DE
N30 Short-nose JU30 9911-0108 Short-nose JU30 0108- Hydraulic Type U30 0108- R145A hydraulic type * Double A-arm suspension on cradle * transverse leaf * drum brake
P12, strut type, flat 4-bolt? * disc brake
