R145
Revision as of 08:58, 20 November 2023; view current revision
Category: Propeller Shaft And Differential Carrier
Hitachi R145 was used in 4WD applications as the rear final drive. Many applications used a 4-bolt rear cradle which contained the entire suspension except for the struts.
[hide]
Coupling Type - Hydraulic (alloy case)
Coupling Type - Electric (alloy case)
Y11 38760-4N500 COUPLING
T30 38761-8H500 coupling
T31 38761-JG20A KIT [with bearings]
T32 38761-4BF0A complete assembly [Large-type]
174_6552da6457279.jpgPost 399034
Hydraulic clutch Coupling Type
C24 Serena
M12 Prairie Liberty
K11 March
P12 Primera
VW11V Expert エキスパート
U30 0108-
Electric Coupling Type
T30 X-Trail
Murano USA Z50 electric coupling
24212.jpgAlbum 24212
Electric Coupled
174_6552da5a8eb82.jpgPost 399034 174_6552da6d9dd4b.jpgPost 399034 28889.jpgAlbum 28889 28888.jpgAlbum 28888
Sources
R145 was mostly used with 4-cylinder engines
 B14 1995-1999 Sunny
 B15 1999–2004 Sunny
RB14 1995-2000 Rasheen
 B30 2005-2012 Lafesta
 C24 1999-2000 Serena JPN (IRS post-vanette)
     2001-2012 Asia markets
     2007-2023 China
 C25 2005-2010 Serena
 C26 2011-2015 Serena
 L34 2019-2024 Altima USA
 J10 2006-2012 Nissan Qashqai/Dualis
 J11 2017-2022 Rogue Sport
 J32 2008-2013 Teana [Altima]
 K11 9911-0010 Micra/March CG10DE+CGA3DE
 M12 9811-0105 Prairie Liberty
 N14 1990-1995 Pulsar
 N15 1995-2000 Pulsar#N15
 N30 1997-2001 Nissan R'nessa
 P12 2001-2008 Primera
 S35 2010-2011 Rogue
 T30 2001-2007 X-Trail
 T32 2015-2020 Rogue
JU30 2000-2003 Bassara
 U30 1998-2003 Presage
 U31 2004-2009 Presage
VW11 1999-2006 Expert エキスパート
 W11 1999-2005 Avenir
 Y11 2002-2005 Wingroad/AD Van VHNY11, VFY11
 Y12 2005-2012 Wingroad/AD Van/NV150 Ad
 Z50 2002-2007 Murano USA
 Z51 2009-2014 Murano USA
 Z53 2015-2024 Murano USA
 Renault Kangoo
 HY 2007-2017 Renault Samsung Koleos/QM5
Gearset
2.466
3.357
3.692 ?
38100-10E60 GEAR SET-FINAL DRIVE 47/14=3.357
             M12, N30, W11, U13
38100-CA000 GEAR SET-FINAL DRIVE 37/15=2.466 [split case] $617 USD
             T31 J11 U31 Z50 Z51
38100-CA00E GEAR SET-FINAL DRIVE             [split case] $1384 USD (2023)
             Z50 Z51 U31 J10 T31 Altima.2019-2024 Murano.2011-2024 Rogue.2010-2011,2015-2020
             Rogue Sport.2017-2022
             * superceeds 38100-CA000
38100-4N500 GEAR SET-FINAL DRIVE 37/15=2.466 [split case]
             C24,K11,M12,P12,T30,VW11,W11,JU30,U30.2002- Y11
38100-4N50E GEAR SET-FINAL DRIVE 37/15=2.466 [split case]
             T31   2011-2016 Serena C26.MR20DD
38100-11E65 48/13=3.692 [long pinion]
             JU30 9911-0108 KA24DE+YD25DDT, B15, G10, U30.2000-2001 split case
R180 gearsets interchange with R145?
38100-03G10 GEAR SET-FINAL DRIVE 37/10=3.700 [R180 long pinion]
             B13, B14, N14, N15, RB14 Rasheen
LSD
Can R145 use the R180 LSD?
Coupling
The coupling takes the place of a center differential. These models have a totally different case, which is split on the axle centers.
Electric Coupling
The electric coupling is designed to work at any setting from non-powered to fully-powered, for various torque splits. The electric coupling, when not powered, allows the rear diff to free-wheel (putting the vehicle into FWD mode). When fully powered, the propeller shaft rotation connects to the diff as normal.
For this reason, operating as a RWD-only diff is complicated. You could use a relay and fully power it, but the failure mode would be to stop transmitting power.
Z50 USA Murano (CVT)
T30 JDM X-Trail GT
Hydraulic Coupling
Appears to be a continuous (non-disconnectable) driver unit?
38760M  assembly
38760KS assembly kit with bearings
38760-4N210 COUPLING ASSY-HYDRAULIC
* K11 March
38760-4N215 COUPLING ASSY-HYDRAULIC
* C24 Serena
* M12 Prairie Liberty
* P12.QR20DE.AT 0101-
* VW11V Expert エキスパート
38760-4N815 COUPLING KIT-HYDRAULIC
* KIT with 38760-4N215 and two bearings
* U30 0108-
* JDM.U30,C24,M12,JU30,P12,VW11,W11
Gasket
Nissan Gasket Silicone Liquid
28883.pngAlbum 28883
Case
38310 CASE (CARRIER COMPL-GEAR) / DIFFERENTIAL HOUSING
COUPLED TYPES
28885.pngAlbum 28885
38310-8H500 [electric coupling]
             JDM T30 X-Trail
38310-CA000 [electric coupling] $1495 USD
             USA Murano.2003-2012.VQ35DE,QR25DE
             USA Rogue 2008-2015.QR25DE
             * Supersedes 38310-8H500
38310-4N500 [hydraulic coupling]
             C24 C25 M12 P12 U30 U31 JU30 W11 M12 VW11
             J31 J32 B30 Y11 Y12
SHORT-NOSE
38311-20E00
   * N30 R'nessa
   * JU30 9911-0108 KA24DE+YD25DDT
38310-4N500
   * JU30.early
LONG-NOSE
38311-71Y00/38311-71Y02
   * B13, B15, M12, G10, N14, N15, RB14, W11
R180 38311-S6200
   * USA.M11 non-LSD
R200 38311-S7000
   * USA.910+M10+M11.LSD+S130
Weight
Longnose R160 < 56 lbs
Longnose R180 ~ 66 lbs
Longnose R200 76 lbs
Shortnose R200 72 lbs
Rear Suspension
431 REAR SUSPENSION
STRUT TYPE
B13,B15 drum brake
N14,N15 DB *DISC OPTION SR20DE
N30 Short-nose
JU30 9911-0108 Short-nose
JU30 0108- Hydraulic Type
U30 0108- R145A hydraulic type
* Double A-arm suspension on cradle
* transverse leaf
* drum brake
P12, strut type, flat 4-bolt?
* disc brake
