B210 Grille
Revision as of 23:58, 24 January 2025; view current revision
Category: Datsun B210
Datsun B210 radiator grilles varied over the production run.
28412.jpgAlbum 28412
Coupe vs Sedan
Early vs Late
#Early Sedan
#Early Coupe
#Late Sedan
#Late Coupe
#Excellent 1400 (also used by 140Y and 160Y)
#Excellent 1600
Early
B210 EARLY means:
  • JDM 1973-1975
  • USA 1974-1976 Model year (to July 1976)
  • AUS 1976-1978
Early Sedan
28400.jpgAlbum 28400
NOTE: USA sedans used the #coupe grille.
NOTE VB210 Vans (wagons) also used this sedan grille.
* 62302-H5125 JDM GRILLE KIT-radiator (ex. GX)
* 62302-H5225 JDM GRILLE KIT-radiator GX
* 62304-H5100 MOULDING-grille radiator (R.H.) GL,GX, V.SP-DX [half-eyebrow]
* 62305-H5100 MOULDING-grille radiator (L.H.) GL,GX V.SP-DX [half-eyebrow]
174_5cd77bbb00ba6.jpgPost 491392
Silver, with non-standard center emblem
1956.jpgAlbum 1956
Gunmetal gray
12659_4b07b2dac193c.jpgUpload click to view 12659_4b07b2fa0bce6.jpgUpload click to view 12659_4b07b30ab8ce1.jpgUpload click to view 12659_4afe7a5140ff2.jpgPost 290637
12659_4cdcc5533d7a9.jpgPost 345758
28398.jpgAlbum 28398 28399.jpgAlbum 28399
1332.jpgAlbum 1332 3851.jpgAlbum 3851 11001_4a6d31d0975da.jpgUpload click to view 11001_4a6d3192208b4.jpgUpload click to view 4489_4b01ce5c57b16.jpgUpload click to view 10405_49d6d7100f65b.jpgUpload click to view 3882_4a23244068bf9.jpgUpload click to view 3882_4a7cd6805d746.jpgUpload click to view 3882_4a2607843d39b.jpgUpload click to view
Ornament
The early sedan grille used 'S' or 'D' mark.
19364.jpgAlbum 19364
Fog Lamp
Fog lamps were a rare OPTION for the early sedan.
Rectangular Fog Lamp (sedan style)
* 26150-H5027 LAMP KIT-fog (from '75-4) (op.) S-all, Van
 * replaced 26150-H5026 LAMP KIT-fog (from '74-1) (op.) S-all, Van
   * superceded 26150-H5025 LAMP KIT-fog (op.) S-all, Van
Early Coupe
174_61f0ea1e1105b.jpgPost 496501
The early Coupe grille has a bold honeycomb style to invoke a sense of power. It is also used by all early USA Sedans.
7032.jpgAlbum 7032
62302-H5500 USA GRILLE KIT-radiator Coupe & Sedan
62302-H5500 JDM GRILLE KIT-radiator K-DX,K-GL
62302-H5700 JDM GRILLE KIT-radiator K-GX
11916_4a3c6139ee283.jpgUpload click to view 29952.jpgAlbum 29952 29953.jpgAlbum 29953 174_4c3909be95ff4.jpgPost 326926
Ornament
The early coupe grille used a shield-shape 'S' or 'D' badge.
Fog Lamp
Fog lamps were OPTION. Most B210 had masking plates in the fog lamp position.
62310-H5500 JDM MASK-fog lamp A K-DX
62310-H5600 JDM MASK-fog lamp A K-GL
26150-H5500 JDM LAMP ASS'Y-fog K-GX (op.)K-DX,K-GL
Round Fog Lamp (coupe-style)
* 26150-H5527 LAMP KIT-fog (from '75-4) (op.) K-DX,K-GL
  * replaced 26150-H5526 LAMP KIT-fog (from '74-1) K-GX (op.) K-DX,K-GL
    * superceded 26150-H5525 LAMP KIT-fog (op.) K-GX (op.) K-DX,K-GL
OPTION fog lamp
11320_4a64275c3fdc9.jpgPost 263846 3508.jpgAlbum 3508
With lamp mask plate (no fog lamp)
11916_4a3c6139ee283.jpgPost 259334 18913.jpgAlbum 18913
With custom fog lamp lenses
Aftermarket driving lamps
4229.jpgAlbum 4229 8761.jpgAlbum 8761
Parts
174_61f109c71ce13.jpgPost 496504
RADIATOR GRILLE (B210 Japan catalog)
1 62302-H5500 GRILLE SET-radiator K-DX,K-GL
  62302-H5700 GRILLE SET-radiator K-GX
2 96706-P0105 SCREW GROMMET 6 [for top edge screws]
3 01461-00021 SCREW-with plain washer 6 [for top edge]
4 62380-H5000 RUBBER-radiator grille 3 [for bottom pins]
5 62310-H5500 MASK-fog lamp A [delete plate] 2 K-DX
  62310-H5600 MASK-fog lamp C [delete plate] 2 K-GL
6 62312-H5525 ORNAMENT KIT-radiator grille
7 01221-00011   NUT-with washer
8 26150-H5500 LAMP ASS'Y-fog K-GX 2
Late
LATE B210 means:
* JDM 1976-1977 (B310 production began November 1977)
* USA 1977-1978 Model year (from August 1976)
* AUS ???
Late Sedan
New Grille has a clearly rectangular center section. There is a bright chrome strip outlining the center section.
174_5cd77bde929e7.jpgPost 491392
Variations
* no fog lamps
* amber fog lamps
* yellow fog lamps
* Silver outline with silver center section (AU)
* Silver outline with black center section (UK GLS, UK Estate)
* Black outline with black center section (GX, SSS, FRA)
2044.jpgAlbum 2044
AUS black center
45085711015_f8c0495235_z.jpgflicker click to view 8577.jpgAlbum 8577
AUS silver center
3872.jpgAlbum 3872 11814_4a1bdfc035123.jpgUpload click to view
JDM 7702-7707
62302-H7426 GRILLE KIT-FRONT S.A12,A14,-=STR, V.DX,SPDX
62302-H7425 GRILLE KIT-FRONT =STR, V.SMDX
* 62302-H7401 JDM GRILLE ASSY-RADIATOR =STR+V.SMDX (2-dr STD 4-speed + Van Semi-DX)
62302-H7402 JDM GRILLE ASSY-RADIATOR K.A12S,A14S.DX,GL
62302-H7420 JDM GRILLE ASSY-RADIATOR S.A12,A14-=STR V.DX,SPDX
62302-H7502 JDM GRILLE ASSY-RADIATOR *S.A14S.GX [same as USA]
MOULDING
62304-H7410 MOULDING-RADIATOR GRILLE S.A12,A14-=STR, V.DX,SPDX
62304-H7411 MOULDING-RADIATOR GRILLE S.A12,A14-=STR
part-black grille (w/silver headlight surrounds)
10255_4a34c2df98dd1.jpgUpload click to view 10146_4c22bab2acbc8.jpgUpload click to view
GX all-black grille (w/black headklight surrounds) + fog lamps
11611.jpgAlbum 11611 1968.jpgAlbum 1968 7711_4b241ff4254a5.jpgUpload click to view
1976 GX
174_5c97e15b3095d.jpgPost 490993
1977 GX-T
174_5c9ae1885e33f.jpgPost 491015 174_5c9ae1af618cb.jpgPost 491015
Ornament
See main article: B210 Grille Badge#Late Sedan
Late Coupe
NOTE: USA and Canada coupes used the worldwide #late Sedan grille
26939.jpgAlbum 26939
The late coupe grille is a honeycomb type similar to the early coupe grille, but without the round lamp cutouts. It has a horizontal bar through it with a new emblem mounted right over this bar.
174_61f0eb318f2d5.jpgPost 496501
Compare to early Coupe
JDM
62302-H7427 JDM GRILLE KIT-FRONT K.A12,K.A14.DX,GL
62302-H7525 JDM GRILLE KIT-FRONT K.A14.GX
* 62302-H7506 JDM GRILLE ASSY-RADIATOR K.A14.GX
* 62304-H7506 JDM MOULDING-RADIATOR GRILLE K.A12,A14
H7427 Coupe B211
H7525 Coupe.A14.GX includes fog lamps
10994_4ae90d6f286b1.jpgUpload click to view 10994_4aefbc82e6507.jpgUpload click to view
Export (coupe grille was used on export Sedans)
2531_4ae6401781cff.jpgUpload click to view 2531_4ae640772dd62.jpgUpload click to view 7431.jpgAlbum 7431 4487_59d8a42a05d2f.jpgPost 486374
Ornament
15432.jpg 174_5a696536a72fd.jpgPost 487406
グリル
Sunny Excellent
174_59d8c13932f50.jpg#1400 174_5d5c7266878d3.jpg#1600
Excellent 1400
B210-based Datsun Sunny 1400 Excellent (PB210) used a deep-vee, twin-nostril grille. This grille was also used by 140Y and 160Y including the 140Z & 160Z coupes.
Note the "S" emblem (for Sunny) on the grille
174_61f0ed1c6b1ff.jpgPost 496501 11375.jpgAlbum 11375 1865.jpgAlbum click to view
GX models were equipped with foglights integrated into the front grill.
140Y South Africa (no fog lamps, just blanking plates)
19991.jpgAlbum 19991 174_59d8c13932f50.jpgPost 486376
174_5d413fa437c7c.pngPost 492048
See also: Fog Lamps
RADIATOR GRILLE COUPE, SEDAN
1 62302-H5800 GRILLE-radiator outer
2 62303-H5800 GRILLE-radiator inner (R.H.)
3 62304-H5800 GRILLE-radiator inner (L.H.)
fixing top edge
 4 96706-P0105 SCREW GROMMET 6
 5 01461-00021 SCREW-with plain washer 6
fixing bottom edge
 6 62380-H5000 RUBBER-radiator grille 3
fog lamp delete plate
 7 62306-H5800 MASK-fog lamp (R.H.) DX,GL
 8 62307-H5800 MASK-fog lamp (L.H.) DX,GL
 9 08513-51623 SCREW-tapping DX,GL 8
10 62312-H5825 ORNAMENT KIT-radiator grille
 11 01221-00011 NUT-with washer
fog lamp GX, (op.) DX+GL
 12 26150-H5800 LAMP ASS'Y-fog (R.H.)
    26155-H5800 LAMP ASS'Y-fog (L.H.)
 13 08510-51623 SCREW-with washer 8
NOTE: grille is upside down in these photos
174_5d410419232e6.jpgPost 492043 174_5d4103d126668.jpgPost 492043 174_5d4103d8d95bc.jpgPost 492043 174_5d4103df0accd.jpgPost 492043 174_5d4103e85ab1a.jpgPost 492043 174_5d4103f64c4b1.jpgPost 492043 174_5d4103fe178cf.jpgPost 492043 174_5d410404e224a.jpgPost 492043 174_5d41040fb5d31.jpgPost 492043
Excellent 1600
The 1976-1977 Excellent 1600 (GB211) replaced the earlier Excellent 1400 in the Japan home market. The 1600 featured a more luxury-looking grille instead of the sporty-looking grille of the 1400.
GB211
* Single center-section (no twin-nostril look)
* no horizontal bar
* GX comes with fog lamps
62302-H7925 GRILLE KIT-FRONT L16.GL
62302-H7926 GRILLE KIT-FRONT L16.GX
* 62302-H7900 GRILLE ASSY-RADIATOR K.L16S
* 62304-H7900 MOULDING-RADIATOR GRILLE L16
62311-H7925 ORNAMENT-FRONT [S-badge looks like 1/2 Mid-model Sunny Truck badge] Coupe & Sedan
174_5d5c7266878d3.jpgbrochure
174_61dfc28ed3dda.jpgPost 496438 174_61dfc29b530a2.jpgPost 496438 174_61dfc28ed3dda.jpgPost 496438
174_61dfef52d6b78.jpgPost 496439
174_61dfef35d5535.jpgPost 496439 174_61dfef3e91b03.jpgPost 496439 174_61dfef49caf68.jpgPost 496439
As usual, USA models used different grilles, partly due to FMVSS safety regulations. Canada models were the same.
  • 5-mph bumper safety changed the front apron, and did not allow use of the standard front combination lights. So the parking and signal lights were moved to the Grille.
  • Nissan Motor Co. in U.S.A. standardized on a single grille for all B210 -- coupes and sedans used the same grille.
NA 1974-1976 Model year (to July 1976)
NA 1977-1978 Model year (from August 1976)
Early North America
1974-1975 north american sedans and coupes used the worldwide #Early Coupe grille. The fish-gill type #Early Sedan grille was not used.
174_5d3047748b95f.jpgPost 491917
  • Same as JDM Coupe grille (non-GX)
  • #Fog-lamp position was used for amber combination lamp (turn signal + parking lights). This was necessitated because the under-the-bumper lamps couldn't be used due to the 5mph bumpers
174_5d304762a22c5.jpgPost 491917
USA used amber Turn Signal lamps in place of the JDM fog lamps (non-USA has the Turn Signal/Markers/Indicators in the bumper)
174_4c3902216a198.jpgPost 326923
Late North America
Late North America B210s used the #late sedan grille for all coupes, as can be seen on this Canadian Coupe:
12259_4a8f4c5732987.jpgPost 272377
* Black or gray ouline with same color center section
62302-H7526 USA KIT GRILLE-RADIATOR (WITH MOULDI 0876-0177
* 62302-H7500 USA GRILLE-RADIATOR 0876-0177
* 62304-H7410 USA MOULDING-GRILLE RADIATOR 0876-0177
F2302-H7420 USA KIT GRILLE-RADIATOR (WITH MOULDI 0277-0777
* 62302-H7502 USA GRILLE-RADIATOR 0277-0777
* 62304-H7411 USA MOULDING-GRILLE RADIATOR 0277-
62302-H7700 USA GRILLE-RADIATOR 0877- [Black]
* 62304-H7411 USA MOULDING-GRILLE RADIATOR 0877-
With moulding installed:
With moulding missing:
