710
Revision as of 21:28, 26 February 2025; view current revision
Category: Nissan Vehicles
710 was the first generation (1973-1977) of the Nissan Violet. Available in Sedan and Hardtop models, both of which had fastback styling (the difference is the door frames — sedans have frames around the door windows, while hardtops have no frames around the door glass). The 710 Hardtop has up-sweeping rear side glass, while 2-door sedan had down-sweeping rear side glass.
Nissan Violet was the C-class (compact) model family for the Nissan Cherry sales organization. The corporate rationale was to have something similar in class and cost to the Bluebird 510, because the Bluebird 610 was going upmarket. Thus, it would slot below the cost of the 610 with IRS, but above the Sunny Excellent. It was similar to the compact Datsun 510 with same running gear & chassis/suspension (while the 710 did not use IRS in most of its models, it was used in the SSS. Other grades used the 510 straight axle). This also consolidated the export market which had relied on low-cost non-IRS 510 models in some countries e.g. Mexico. 710 was similar to 610 but used different body panels and interior and shorter wheelbase. 710 was larger than 510, but 610 was even bigger.
* Sold by Nissan Cherry Store as a larger companion model to the Sunny
* L-engine powered
* Same size as Datsun 610 Bluebird
* SSS models came with IRS
1973-1977 Nissan model series 710 was marketed as:
  • Nissan Violet (Japan)
  • Datsun 710 (USA & Canada)
  • Datsun 140J/160J (Commonweath export countries)
  • Datsun 160J (Mexico)
    nickname "bolillo" (dinner roll)
  • Yue Loong Violet (Taiwan)
710 "160J" with 1600 engine
16575.jpgAlbum 16575 3339.jpgAlbum 3339
710 "Violet 1600"
4504.jpgAlbum 4504
710 "140J" with 1400 engine
400px-1974_Datsun_Violet_140J.jpgWIKI go to Wikipedia
Models
4-dr Sedan
2-dr Sedan (early series only)
2-dr Hardtop (coupe)
4-dr Van (wagon/estate/familiar/guayin)
710 early series: 1973-1976
711 late series:  1975-1976
For the 711 facelift, the sedan changed from fastback style to notchback style. For the US market, this was only seen in the last final year of the 710.
400px-Datsun_160J_%28depan%29%2C_Denpasar.jpgWIKI click for photo 400px-C._1975_Datsun_Violet_140J_710_%2814531820652%29.jpgWIKI go to Wikipedia
2-door Hardtop versus 2-door Sedan
400px-Datsun_Violet_710_001.JPGWIKI go to Wikipedia 400px-Datsun_710_two-door_orange,_front_left.jpgWIKI go to Wikipedia
Hardtop
400px-Datsun_Violet_710_001.JPGWIKI go to Wikipedia 400px-Datsun_Violet_710_002.JPGWIKI click for photo
2-door Sedan
400px-Datsun_710_two-door_orange,_front_left.jpgWIKI go to Wikipedia 400px-Datsun_710_two-door_orange%2C_rear_left.jpgWIKI go to Wikipedia
4-door
400px-Nissan_Violet_710.jpgWIKI go to Wikipedia 400px-Nissan_Violet_710_rear.jpgWIKI go to Wikipedia
Wagon
400px-Datsun_710_wagon.jpgWIKI click for photo 9098067467_ccf0de51f6_z.jpgflicker click to view
Violet and Bluebird
Violet was the C-class (compact) model family for the Nissan sales organization (later named Nissan Blue). It was a similar to the Bluebird 610, albeit looking very different, with unique body styles, sheet metal, and interior but same running gear & chassis/suspension. 710 did not use IRS in most of its models, to slot below the cost of the 610 with IRS. Further reducing costs it was closer in size to the 510, with shorter wheelbase than the 610. Bluebird moved upscale into the luxury sedan market with the 610 and 810, including availability of long-wheelbase six-cylinder models, while Violet 710 and A10 continued as the lesser compact sedan.
Nissan Violet versus Datsun Bluebird
710, 610, B210 comparo
While both 610 and 710 were compact sedans, both were larger than the 510. The 710 was closer to the 510, for example it was the same length as the 510, while 610 was almost 4 inches longer.
Dimensions     510  710  610  PB210
Wheelbase (mm) 2420 2450 2500 2340
Length (mm)    4120 4120 4215 4045
Width (mm)     1560 1580 1600 1545
Height (mm)    1402 1375 1415 1360
Weight (kg)     940 1005 1035  907
While the PB210 Sunny Excellent used the same running gear as the 510 (including engine/transmission and front suspension), it was a class size below. It was significantly shorter, lower and narrower than the 510 and also somewhat lighter in weight.
Applied Model Codes
Applied Model Codes
K01	710 Sedan '74
K03	710 Sedan '74
K04	710 Sedan '74
K05	710 Sedan '74
K09	710 Sedan '74
K10	710 Sedan '74
K11	710 Sedan '74
K12	710 Sedan '74
K13	710 Coupe '74
K16	710 Sedan '74
K17	710 Sedan '74
K20	710 Sedan '74
K21	710 Coupe '74
K25	710 Coupe '74
K29	710 Wagon '74
K30	710 Wagon '74
K31	710 Wagon '74
K32	710 Wagon '74
N69 L16E (SSS)
N70 LPG (L16P & L18P)
N71 L14
N72 Van
N74 Notchback
 710   4-door sedan
 710-R 2-door sedan (door has window frame "post")
K710   2-door Hardtop (door window has no frame) coupe
       (1400 & 1600)
 710  STD 1400 L14 engine
 710D DX 1400  L14 engine
 710H GL 1400  L14 engine
P710  DX 1600  L16 engine
P710H GL 1600  L16 engine
P710K SSS - IRS, L16 twin carb engine
P710E SSS - IRS, L16 EFI engine
P710Y TAXI
P710P TAXI LPG L16P
R710P TAXI LPG L18P (late series)
Grille
27069.jpgAlbum 27069
L14
L16
L16S - single carb
L16T - Twin carb
L16E - EFI (SSS model)
L16P LPG TAXI
L18P LPG TAXI 1.8 liter
SSS
SSS version of 710 differed from other trim levels:
  • IRS with R160 differential
  • Twin-carb or EFI
  • 4-door Sedan or Hardtop (coupe). No 2-dr sedan SSS was offered
Sedan SSS: P710TE 4-speed
Sedan SSS: P710FE 5-speed
Coupe SSS: KP710TE 4-speed
Coupe SSS: KP710TE 5-speed
L16T: SU-type (early series only)
L16E: EFI
SSS Hardtop
South Africa
160J - hardtop & sedan
160U - SSS(?) hardtop & sedan
ZA K710 "160U SSS" Hardtop coupe
16936.jpgAlbum 16936
ZA 710 "160U SSS" 4-door Sedan
IMG_0063.jpgPost click for topic IMG_0059.jpgPost click for topic 16574.jpgAlbum 16574 16573.jpgAlbum 16573 16572.jpgAlbum 16572 16571.jpgAlbum 16571
USA models only came with the highline (H-code) engine. The L16 was not offered.
KHL710  Hardtop coupe
 HL710R 2-dr sedan
 HL710  4-dr sedan
WHL710  4-dr wagon
1974  L18 engine to 1974 August
1975- L20B engine from 1974 September (1975 model year)
suffix U export 710
1975-1976 model year
* CAL - suffix V California emissions
* CAN - suffix N Canada
* FED - USA emissions except CAL
Brochures
USA 'Datsun 710' in Ticket to Ride 1974 Datsun range brochure
29540.jpgbrochure
USA Datsun 710 brochure. "Wabash Cannonball" refers to a famous locomotive
11929.jpgAlbum 11929 11930.jpgAlbum 11930
