Bump Stops
Revision as of 22:35, 6 June 2025; view current revision
Categories: Rear Axle And Rear Suspension | Front Axle And Front Suspension | Lowering
Bump Stops a.k.a. Bound Bumpers limit the suspension travel. When you go over a large bump and the wheel rises up, it will hit the rubber bump stop. Stopping against rubber is better than stopping against metal. When lowering the vehicle, the Bump Stops can be cut to shorter length to provide more travel at the expense of some harshness.
Front
Strut: the front McPherson Strut assembly has a rubber Bound Bumper.
Number 2 in this photo:
24010.jpgAlbum 24010
Rear
Pinion Snubber - see Torque Arrester
174_509b12abdfe7b.jpgUpload click to view
Rear Axle Coupe, Van, and Truck
24926.jpgAlbum 24926
Rear Axle Sedan - see Shock absorbers
24951.jpgAlbum 24951
