Stripes
Revision as of 23:58, 25 September 2025; view current revision
Category: Paint
The purpose of racing stripes is to identify the car among many other similar cars during a busy race. You can also make your street car stand out by applying stripes.
Factory Stripes
SSS
S1 Stripe
Portugal thin stripe with inset 'DATSUN' at the rear.
1447.jpgAlbum 1447 14057.jpgAlbum 14057 46.JPGAlbum 46 1449.jpgAlbum 1449 1452.jpgAlbum 1452
Option 'Datsun' Side Strip
JPN K5040-00067
USA 99990-00107
174_6150f3478980d.jpgAccessories
27055.jpgAlbum 27055
Bold "DATSUN" side stripe adds sportscar flare to the 1200. Makes the car look lower and longer. Stripe is top quality "Scotchcal" vinyl. Each letter is formed with individual pieces of tape to let the original car paint show through for a clean, neat, perfectly colored letter! 71" long, available in black or white.
27054.jpgAlbum 27054 174_56da185c241c7.jpgPost 476899
K5040-00067 TAPE-masking 'D A T S U N' (10 m) Coupe
20634.jpgJDM OPTIONS
"DATSUN" SIDE STRIPE, Part Number 99990-00107 (white). * 9990-00108 (black) $16.75 USD
The Datsun 510 catalog has the same stripe kit, and the description is worded more accurately.
The "DATSUN" side stripe kit comes ready to apply, and adds sports car flair to your automobile. The "Scotchcal" vinyl retains its luster and is long-lasting. Letters are individually formed allowing the original paint to show through. The side stripe is 71" long. Available in black or white.
28035.jpgbrochure
The re-creation on this red 1200 doesn't let the car color show through
174_615258aebd4e1.jpgSuby05 174_615258a34c5b5.jpgSuby05
Different version seen on B210 (narrow spacing, different font)
174_59ead54e9c89b.jpgPost 486509 174_59ead559b03e5.jpgPost 486509 26916.jpgAlbum 26916
Datsun sold variations on this stripe: instead of 'DATSUN', they were '240Z', '260 Z', and 'Li'l Hustler'.
mcdat re-creations
14333_53cf2031f1e13.pngPost 458263 14333_53d1acbfe8283.pngPost 458325
mcdat rear-window version
14333_53d1ca5cbb7ac.pngPost 458329
Option 3/4-inch Side Stripe
174_6150f331f1e03.jpgPost 495906
3/4" SIDE STRIPE KIT, Part Number 99990-00109 (white) * 99990-00110 (black) [$14.00 USD] Thin line side striping to add a subtle touch to the 1200's beautifully sculptured lines. Side striping consists of a 1/4" stripe between two 1/8" stripes for a total slim-line 3/4" stripe. 25 ft. of striping provided, all in high quality "Scotchcal" vinyl. Available in black or white.
27479.jpgUSA OPTIONS
B120 Bakkie
Nissan South Africa stripes
B120
GX Side Stripe
Datsun 1200 GX
8580.jpgAlbum 8580
Sedan and Coupe
8883.jpgAlbum 8883
Black & white
1748.jpgAlbum 1748 1749.jpgAlbum 1749
From 1970-1971 Catalog
?unlisted?
GX-5
GX-5 Black and Red tape stripe differs for Sedan & Coupe, specifically the key holes & side duct places differ.
#GX5 Coupe stripe leading edge is cut at an angle and has a notch for the side vents
#GX5 Sedan strip straight-cut leading edge
Keyhole notch
174_5c25f2963eeb9.jpgPost 490280
GX5 Sedan
Sedan tape stripe looks similar but differs from Coupe
  • Leading edge is straight-cut
  • Key holes is closer to front as the door is shorter
  • No side duct notch
Nissan Part Numbers from 1972 JDM catalog:
76820-H7200 STRIPE SET-accent Sedan
* 76822-H7200 SHEET-accent stripe (R.H.) Sedan
* 76823-H7200 SHEET-accent stripe (L.H.) Sedan
19277.jpgbrochure
5487.jpgAlbum 5487
Sedan stripe will fit any short-door model (4-door sedan, wagon and ute), although of course only the 4door sedan came in GX trim. For 4-door. Also fits ute. Does not fit 2-door.
Fitted to truck:
174_5c25f752a2184.jpgPost 490281 174_5c25f74a79e79.jpgPost 490281
Repro stipe pictured, with angle-cut front edge
174_5c25f77522353.jpgPost 490281 174_5c25f766eb786.jpgPost 490281
GX5 Coupe
Coupe stripe differs from sedan stripe:
  • leading edge is cut at an angle
  • notch for the side vents
  • keyhole notch is farther back due to the longer door
1971.jpgAlbum 1971 174_5c25f2891e8ac.jpgPost 490280
brochures:
26621.jpgbrochure 25661.jpgbrochure 22548.jpgGirl
0570589A30151217W00414.jpg 19087.jpgAlbum 19087 1873.jpgAlbum 1873 1872.jpgAlbum 1872 1970.jpgAlbum 1970 1833.jpgAlbum 1833
76820-H7210 STRIPE SET-accent Coupe
* 76822-H7210 SHEET-accent stripe (R.H.) Coupe
* 76823-H7210 SHEET-accent stripe (L.H.) Coupe
174_5d635b11d79b2.jpgPost 492380 1816.jpgAlbum 1816 174_5c25f2963eeb9.jpgPost 490280 174_5c25f2a2499ff.jpgPost 490280 174_5c25f2ae9bacb.jpgPost 490280 174_5c25f2c922ec3.jpgPost 490280 174_5c25f2d488742.jpgPost 490280 174_5c25f2e12823e.jpgPost 490280
carps version
13022_4d8b104f2a76a.jpgPost 361007 13022_4d8b103ecf019.jpgPost 361007 13022_4d8b10686a032.jpgPost 361007
GX5 Yellow
Factory brochures show what appears to be a Black & Yellow stripe, which is not in the parts catalog:
Perhaps this is just faded photos and it is the usual red stripe.
PB110
PB110 Datsun Sunny Excellent 1400 had stripes for both the GX and GL grades.
サニーエクセレントサイドストライプ Sunny Excellent side stripe
GX
Sedan & Coupe use the same stripe sets
Black/yellow/black stripe. The body color shows in between the three parts
24168.jpgbrochure 29107.jpgbrochure
76821-H2703 STRIPE SET-accent (black & yellow) (L.H.) SGX, CGX
76820-H2703 STRIPE SET-accent (black & yellow) (R.H.) SGX, CGX
174_4d4f28033ea8a.jpgPost 355956
L4 straight-cut end
174_6574b48316a1a.jpgPost 498103 174_6574b495ccc57.jpgPost 498103
76821-H2702 STRIPE SET-accent (white & yellow) (L.H.) SGX, CGX
76820-H2702 STRIPE SET-accent (white & yellow) (R.H.) SGX, CGX
174_55f8fa577ddd8.jpgPost 472376
GL
  • K5040-00195 TAPE-marking (960mm) as req. S-GL
  • K5040-00196 LABEL-marking (R.H.) S-GL
  • K5040-00197 LABEL-marking (L.H.) S-GL
B310
2a.jpg.bbaff5ba2a18f51be6d8397cc77ec1d8.jpg C4b.jpg.411201b661e20a65ef9fcccd42cd0d06.jpg
Common Pinstripe
  1. Along the Swage Line (Character Line), aka Side Crease
  2. Just below the belt line, accentuating the coke-bottle shap
Character Line Pinstripe
A character line stripe can be painted or implemented with a rubbing strip.
#GX Side Stripe
#GX-5 had one applied
#S1 Stripe
#PB110 used a character line pinstripe
Pinstripe applied to the character line — like a Datsun dealer would apply to a new 1200, as shown in Press Photos
2855.jpgAlbum 2855
Compare to the unpainted character line, which in shadow adds a noticeable line to the side of the car:
13885.jpgAlbum 13885
This "perimeter" stripe variation wraps around the back of the sedan
2326.jpgAlbum 2326 2325.jpgAlbum 2325
Belt Line Pinstripe
Pinstrip just below the car belt line.
Belt-line pinstripe accentuates the slight Coke-bottling styling of the 2-door sedan (pinched-waist beltline)
124.jpgAlbum 124
Bustle Stripe
1650.jpgAlbum 1650
Bumblebee Stripe
Bumblebee Stripe goes around the nose of the car
1719.jpgAlbum 1719 1720.jpgAlbum 1720 1721.jpgAlbum 1721
Lightning Stripe
2437.jpgAlbum 2437 16816.jpgAlbum 16816 16817.jpgAlbum 16817
Diagonal multi-color (lightning primitive abstraction)
18089.jpgAlbum 18089
Le Mans Racing Stripes
The original racing stripes. Le Mans racing stripes
7353.jpgAlbum 7353
Double Rally Stripes
Thin stripes | Classic stripes | Offset Stripe
BRE Stripes
The famous pattern of the 1968 Datsun team by Pete Brock of BRE, itself an evolution of racing hash marks/fender stripes.
Main: BRE
nasmie_majiet_nissan_1400_racing_de.jpg 2953.jpg 13002.jpg 11601.jpg 795.jpg msv5-2.jpg
Scallops
Paint scallops is an old hot rod style. Try it on a 1200.
1200 Pickup with Primer paint and scallops
14450.jpgAlbum 14450
13767.jpgAlbum click to view 13960.jpgAlbum 13960
2570.jpgAlbum 2570
Tricolor
Datsun Colours - red, white and blue
13714.jpgAlbum 13714
Misc
Dazzle stripes
18189.jpgAlbum 18189
Strobe Stripe on Sublime Green paint. Buy stripe kit from Trimbrite part number R76010
174_5ae3800ee57fe.jpgPost 488190 22717.jpgAlbum 22717 22716.jpgAlbum 22716
Yenko stripe
20090.jpgAlbum 20090
Spear
174_55ea1bf73d2be.jpgPost 471955 174_55ea1becdb6be.jpgPost 471955
Reverse Boss
17745.jpgAlbum 17745
classic Racing Forg paint scheme
Starsky & Hutch Style
5776.jpgAlbum 5776
90s Style
7009.jpgAlbum 7009 14352.jpgAlbum 14352
