Doors
Revision as of 04:42, 1 November 2025; view current revision
Categories: Body | Fibreglass
Datsun 1200s come in 2-door, 3-door, 4-door and 5-door models.
Also see: Glass including window winders and regulators
Comparisons
Long            Short
2-door Coupe  | Wagon
2-door Sedan  | 4-door Sedan
              | Ute
Tall Frame    | Short Frame
2-door Sedan  | 2-door Coupe
Coupe Window Frame is shorter than Sedan:
ute/wagon/sedan doors
Front Doors
Same front doors are use by 4-door sedan, 4-dr van and Truck
2-door sedan and Coupe use long doors. The bodies are nearly the same, but the window frames are different.
Coupe vs Sedan 2-doors
26868.jpgAlbum 26868 24886.jpgAlbum 24886 24887.jpgAlbum 24887
2-dr Coupe and 2-dr Sedan door stampings are the same, but the door window frame differs. These photos of coupe doors test-fitted to a sedan so vividly illustrate the difference, which is about 3 cm in height.
Further, coupe and 2-door Door Card varies.
The 2-door inside metal is finished (here in black paint) and uses a mini door card
7569.jpgAlbum click to view
The 2-door coupe door-top is completely covered by the fabric door card
5039.jpgAlbum 5039
Rear Doors
4-dr Sedan and 4-dr Van use different doors with differently-shaped glass.
4-door
Four door models include the 4-dr Sedan and 5-dr wagon.
The lower part of the doors are identical 4-door Sedan to 4-door Wagon.
2-door
Datsun 1200 2-door models include Sedan, Coupe, 2-dr wagon, and pickup versions.
  • 2-door Sedan and 2-door coupe are long doors (same door bottom, different glass frames)
  • 2-door wagon and Pickup use short doors (of 4-door sedan type)
Fiberglass
  • ProdBodies formerly Japco - fibreglas hood, fenders, flares, door, trunk, spoiler, air dam
Door Scuff Plates
Kicking plate is the door jamb/scuff plate/threshold plate.
Door Interior Panels
(Datsun terminology: "Door Finisher")
Door Exterior Panels
See also: Wagon rear door
Door Panel Assembly include the skin, door frame and the sash/window frame
Door Outside Panel, commonly known as the "skin" is the exterior panel sheet, which could be replaced by weldeding to the door frame
82152-H1000, rear 4-door outside panel
26248.jpgAlbum 26248
2-door skin being welded to door
datsun177.jpgPost click for topic
Escutcheons
The chrome escutcheon is located behind the interior door latch handle. Right and left vary, in the location where the fitting screw hole is drilled, as well as where the rubber anti-rattle nub is fitted.
22028.jpgAlbum 22028
  • 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
  • 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
Exterior Handles
As you pull up on the door handle, it raises the latch rod. The rod snaps into the plastic 'holder' bushing.
22032.jpgAlbum 22032
82605-H1000 ASS'Y-HANDLE, door outside FRONT,REAR (R.H.)
82606-H1000 ASS'Y-HANDLE, door outside FRONT,REAR (L.H.)
80605-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT RH $11.83 USD
80606-H1901 ASSY-HANDLE DOOR OUT SIDE FRONT LH $11.78 USD
22030.jpgAlbum 22030 22029.jpgAlbum 22029 22031.jpgAlbum 22031
24220-H6200 HOLDER-OUTSIDE HANDLE [E-clip] > 84371-H1000 [push-clip]
80608-H1000 ASSY-ROD OUT SIDE HANDLE (?same part used for rear doors?)
6248.jpgAlbum 6248
This one has the original simpler type of nylon rod holder.
22033.jpgAlbum 22033
Interior Handles
Arm Rests
1200 Standard came with simple #Pull Handles. All other 1200s came with Armrests.
80940-H1100 B110 COMP-ARM REST BLACK #766 $36.65 USD
* also used by
  * B210 Front and Rear doors
  * 620 USA OPTION to 0678, standard equipment from 0778
80940-B9501 620 (BROWN) OPTION to 0678, standard equipment from 0778 USA
80940-B9700 620 (BLUE) OPTION to 0678, standard equipment from 0778 USA
May fit:
80691-A0800 510 DX black with chrome strip
B310 (top, ribbed type) vs B110 DX (plain type)
4923.jpgAlbum 4923
Pull Handles
B110 STD interior handle 'door pulls'
19080.jpgAlbum 19080
80960-H1001 HANDLE-PULL FRONT & REAR
* B110 STD (Deluxe came with armrests)
* 620 USA standard equipment to 0678
* 521 USA from Jul 1969
* B210 JDM sedan & van, 2-dr & 4-dr, front and rear doors
* KHC120 "Vanette" 8003-8210 HANDLE,PULL FRONT DOOR
80960-H1000 HANDLE-PULL (early version with M5 screws)
B310 STD door pulls
80960-H8800 HANDLE-PULL(BLACK)
80960-H8500 HANDLE-PULL(BROWN) to 0779
80960-03W01 HANDLE-PULL(BROWN) from 0879
B310 DX armrests (front doors)
80940-W5000 ARMREST ASSY-DOOR (BLACK 021G0)
80940-H9100 ARMREST ASSY-DOOR (BLUE 021B16) to 0779
80940-H9101 ARMREST ASSY-DOOR (BLUE 021B27) from 0879
80940-H8500 ARMREST ASSY-DOOR (BROWN 021C3) to 0779
80940-01W01 ARMREST ASSY-DOOR (BROWN 021C5) from 0879
Above Door Fittings
Coat Hooks & Assist Rails (assist grips/assist straps)
73940-H1101 B110 ASSY-RAIL ASSIST, also 620 OPTION
* From 0778 620 OPTION 73940-B9800
Japan models:
73940-H1101 ASSY-RAIL ASSIST (for rear) (2) Coupe, Sedan ex. STD
* also used by 620 Truck
* Driver's standard, Passenger OPTION
73940-H3200 ASSY-RAIL ASSIST (for front) (1) Coupe, Sedan ex. STD
73940-H5000 B210 ASSY-ASSIST GRIP (GRAY, VK-204)OPTION
96750-H5000 B210 HANGER-COAT (GRAY,#1618)
B310 above-door pull strap & coat hooks
4924.jpgAlbum 4924
73940-H8501, 73940-W5800 (various) ASSIST GRIP ASSY
96750-H8500 (various) HANGER-COAT
Latch
It seems the latches is identical between 2-dr sedan, 4-dr sedan and Coupe. But there are right-side and left-side parts.
In 1969, Sunny was upgraded to the rack & pinion Safety Lock style and this was used by Datsun 1200.
28342.jpgAlbum 28342
Striker
Door Lock Striker
18056.jpgAlbum 18056
ASSY-STRIKER DOOR LOCK FRONT + REAR
80570-21000 RH ALL
80571-21000 LH ALL
80570-E6000 RH USA COUPE + SEDAN 2-DOOR
80571-E6000 LH USA COUPE + SEDAN 2-DOOR
80577-21000 BOLT-SPECIAL TO FIX STRIKER (6)
E60     designed for C30 Laurel STD (1970)
210	designed for Datsun 510-S
Fits: 510 S30 B110 520 521 620 311 Roadster Patrol
Striker with shims
18708.jpgAlbum 18708
Lock Mechanism
Door+Lock1200 Assembly
8358.jpgAlbum 8358
The L-shaped rod on the left of this photo is to the Lock Cylinder. If turning the Key won't move the knob far enough to lock or unlock, try bending this rod
The other rod (which goes straight up) is to the interior Lock pull Knob
ASSY-DOOR LOCK FRONT & REAR
VAN + SEDAN 4 DOOR
* 80502-H1001 RH
* 80503-H1001 LH
* 80502-H1001 RH VAN REAR < 80502-H1002 FROM 1971.1
* 80503-H1001 LH VAN REAR < 80503-H1002 FROM 1971.1
COUPE + 2 DOOR
* 80502-H1201 RH 1971 <> 80502-H3600 (1972-1973)
* 80503-H1201 LH 1971 <> 80502-H3600 (1972-1973)
08320-61012 SCREW-MACHINE M6x10, Flat head (6)
08916-43610 WASHER-LOCK TOOTH (6)
Remote Control
Remote Control Assembly (inside door handle)
174_518af631070d2.jpgUpload click to view
Lock Knob
door lock pull pin, threads M4 P0.8
23391.jpgAlbum 23391
80595-N1600 KNOB-DOOR LOCK [black, package of five?]
Fits: 31, 411, B10, B110, B120, B310, 510, 240Z
27977.jpgAlbum 27977 27976.jpgAlbum 27976
Pulls from other cars can work too, like this chromed knob:
19488.jpgAlbum 19488
NOTE: B210 has wedge shaped knobs
80970-A4600 Interior Lock Knob Grommet ドアロックノブ グロメット
25618.jpgAlbum 25618
31116.jpgAlbum 31116
Lock Key Cylinder
See Locks
Parts
8361.jpgAlbum 8361
The B120 diagram here is almost identical to the Coupe, except that the insulator (80504F) is not used on the other models. The part numbers are mostly the same as Coupe, except for the latch and striker.
Coupe and 2-dr Sedan latch parts are identical.
4-dr sedan parts are mostly different, but the latch itself, escutcheon, and inside door handle (remote control) is the same on front doors. The striker and door handle are different.
80760-H1000 ASSY-HANDLE DOOR WINDOW REGULATOR $24.00 USD
80502-H3600 ASSY-DOOR LOCK FRONT RH $128.10 USD
80503-H3600 ASSY-DOOR LOCK FRONT LH NLA
Hinges
See Door Hinge
Hinge Repair
See Door Hinge
Rubber
80886-H1000 Rubber - Door cover RH
80887-H1000 Rubber - Door cover LH
80834-H1000 Spacer - Weatherstrip spacer, front door RH
80835-H1000 Spacer - Weatherstrip spacer, front door LH
5498.jpgAlbum 5498
Drain Plugs
These drain plugs fit all Datsun 510, 1200, 620, and 280ZX. The plugs fit on the underside of the doors (2 per door). They help prevent rust by letting water out, and keeping mud from coming in.
22025.jpgAlbum 22025
Weatherstrip
22284.jpgAlbum 22284
Door Weatherstrip
Door weatherstripping is same material (possible same shape/length) as 510.
  • 80830-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
  • 80831-H1001 WEATHERSTRIP ASS'Y-front door (R.H.) 4 door
  • 80830-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe $58.90 USD
  • 80831-H1202 WEATHERSTRIP ASS'Y-front door (R.H.) 2-dr Sedan, Coupe $59.90 USD
  • 80836-H1000 WEATHERSTRIP ASS'Y-door inside (R.H.) 4 door
  • 80837-H1000 WEATHERSTRIP ASS'Y-door inside (L.H.) 4 door
  • 80836-H1200 WEATHERSTRIP ASS'Y-door inside (R.H.) 2-dr Sedan, Coupe, Coupe (L.H.) $7.53 USD
  • 80837-H1200 WEATHERSTRIP ASS'Y-door inside (L.H.) 2-dr Sedan $7.53 USD
2-door Sedan
80830-H1202 ASSY-WEATERSTRIP FRONT DOOR RH (from '70-Jul.)
* 80830-H1200 ASSY-WEATHERSTRIP FRONT DOOR RH
80831-H1200 ASSY-WEATHERSTRIP FRONT DOORLH (from '70-Jul.)
* 80831-H1202 ASSY-WEATHERSTRIP FRONT DOOR LH
willieoec-img600x450-1327300679jcpxxv91495.jpg willieoec-img600x450-1327300679phtoil91495.jpg willieoec-img600x450-1327300679o5by1i91495.jpg
Inside Door Weatherstrip
27 is the inside door weatherstrip (glued to door and to window frame)
80836-H1200 WEATHERSTRIP-FRONT DOOR INSIDE RH
80837-H1200 WEATHERSTRIP-FRONT DOOR INSIDE LH
Front door inside weatherstrip snaps into top of door panel
23391.jpgAlbum 23391 8710_5a763a5426998.jpgPost 487507
Door Outer Moulding
80834-H1000 SPACER-WEATHERSTRIP FRONT DOOR RH
80835-H1000 SPACER-WEATHERSTRIP FRONT DOOR LH
80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH $41.33 USD
* replaced 80820-H1200 ASSY-MOULDING FRONT DOOR OUTER RH
80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH $46.18 USD
* replaced 80821-H1200 ASSY-MOULDING FRONT DOOR OUTER LH
80825-H1000 CLIP-MOULDING DOOR OUTER (8)
4-door/Ute/Wagon front door
80820-H3100 MOULDING ASS'Y-door outer (R.H.) <> 80820-H1000
80821-H3100 MOULDING ASS'Y-door outer (L.H.) <> 80821-H1000
2-door Sedan/2-door Coupe
80820-H3600 ASSY-MOULDING FRONT DOOR OUTER RH 2 DOOR > 80820-H1200
80821-H3600 ASSY-MOULDING FRONT DOOR OUTER LH 2 DOOR > 80821-H1200
80820-H3100 moulding assembly (note rubber attached by staples)
174_60c7b081bb59e.jpgPost 495511 174_60c7b08ecf920.jpgPost 495511
ドア ウェザー ストリップ ドア インサイド モール ガラスウエザーストリップ
Door Bumper
See also: Fuel Door
All 1200 doors have a rubber bumpier, so when you slam the door, it softly stops it.
80832-H1000 RUBBER-BUMPER FRONT DOOR
Two bumpers = two doors
26397.jpgAlbum 26397
Sealing Screen
Door screen seal
28363.jpgAlbum 28363
black adhesive fastens this plastic sheet to the door panel. Even after 30 years the adhesive is still gooey and pliable.
SCREEN-SEALING,FRONT DOOR INSIDE
* left & right side identical
4-door and Truck
  80804-H1000 -8102
  80804-G1900 8103-8104
  80804-G1901 8105-
2-door Sedan and 2-door Coupe
  80804-H1200
At the factory a plastic sheet is put on the door panel (behind the Door Cards) and seals water and moisture from getting into the interior.
Scissor Doors
"Lambo" style doors on Datsun 1200.
Suicide Doors
10257_4bfdc15e0fd49.jpgPost 319267
1239.jpgAlbum 1239 1915.jpgAlbum 1915 3302.jpgAlbum 3302 4467.jpgAlbum 4467 4838.jpgAlbum 4838 4840.jpgAlbum 4840 6248.jpgAlbum 6248 8358.jpgAlbum 8358 8361.jpgAlbum 8361 8960.jpgAlbum 8960 9800.jpgAlbum 9800 10883.jpgAlbum 10883 10884.jpgAlbum 10884 11056.jpgAlbum 11056 11084.jpgAlbum 11084 12094.jpgAlbum 12094 12095.jpgAlbum 12095 12096.jpgAlbum 12096 15195.jpgAlbum 15195 15266.jpgAlbum 15266 15267.jpgAlbum 15267 16764.jpgAlbum 16764 16783.jpgAlbum 16783 16784.jpgAlbum 16784 17027.jpgAlbum 17027 17028.jpgAlbum 17028 17566.jpgAlbum click to view 17696.jpgAlbum 17696 17728.jpgAlbum 17728 17729.jpgAlbum 17729 17753.jpgAlbum 17753 18055.jpgAlbum 18055 18709.jpgAlbum 18709
