<-- back to Sedan badges
Grille #Center Ornament and #Grille Left Side Badge (trim badge)
Center Ornament
#Early Center Ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Early grille center badge 62312-H1626 ('D') and 62312-H1026 ('S')
- 1970-1973 Sedan & Van (wagon)
- 1971-1978 Truck (ute)
1972 Center Ornament
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
DX early - no trim badge on grille
DX 1972 #62330-H3125 EMBLEM SET-radiator grille "DELUXE"
GL early #62330-H2026
GL 1972 #62330-H3325 EMBLEM SET-radiator grille "GL"
GX early #62330-H2325 COUPE, SEDAN
GX 1972 #62330-H3425 EMBLEM SET-radiator grille "GX"
1972 GX5 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
62330-H2325
GX early (1970-1971) COUPE, SEDAN grille badge
Compare to rear see-through badge
grille badge has long studs for mounting through the grille
contrast with rear sedan badge which has flush-mount pins
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
GX flat badge
This modern GX badge has no pins. It has a design like the early GX front trim badge (with the same black background) but is designed for stick-on applications so won't easily fit the 1200 sedan or coupe grilles. Has sticky tape on the flat back of the emblem.
62330-H2026 Early GL
62330-H2026 EMBLEM-'GL' (1970-1971). Used by #sedan and coupe
background-color: blue, but the paint has usually disappeared after 30 to 50 years in the weather
bolt-on type (rear GL badge looks similar, but is the push-in type)
62330-H3125
EMBLEM SET-radiator grille "DELUXE" [1972]
compare to rear badge 84823-H1000
62330-H3325
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" (1972 sedan, coupe)
compare to early rectangular GL badge #62330-H2026
Grille badge has long studs for mounting through the grille.
Backing plate is either simple flat or the stronger ridged type
original white paint | with paint faded away
placed on 1972 sedan grille
62330-H3425
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX" SEDAN, COUPE
Grille 'GX' has long bolts and a bracket, in order bolt it to the grill. The similar rear 'GX' badge has short pins.
Late badge has narrow font (approximately 71mm wide)
compare to early 1970-1971 'GX' expanded font grille emblem
compare to rear see-through badge (short pins) and ~100mm wide
Long bolts for the grille badge
#Early GL and Late GX
