Sedan grille badges
Revision as of 07:53, 1 November 2025; view current revision
Category: Body
<-- back to Sedan badges
Grille #Center Ornament and #Grille Left Side Badge (trim badge)
20869.jpgAlbum 20869
Center Ornament
#Early Center Ornament 62312-H1626 ('D') and 62312-H1026 ('S')
11318.jpgAlbum 11318
#1972 Center Ornament
22828.jpgAlbum 22828
Early grille center badge 62312-H1626 ('D') and 62312-H1026 ('S')
  • 1970-1973 Sedan & Van (wagon)
  • 1971-1978 Truck (ute)
11318.jpgAlbum 11318 24321.jpgAlbum 24321
19527.jpgAlbum 19527
11793_4a2f681382129.jpgPost click for topic 21120.jpgAlbum 21120
737.jpgpress photo 24563.jpgbrochure
62312-H1626
174_65b7f2b8ecb21.jpgPost 498235 174_65b7f2ce67914.jpgPost 498235
174_65b7f2ecb7f43.jpgPost 498235 174_65b7f2c5a20a1.jpgPost 498235
174_65b7f2e0133dd.jpgPost 498235 174_65b7f2d8b4d60.jpgPost 498235
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
62312-H3100 cast mark
752.jpgAlbum 752 22828.jpgAlbum 22828 7522.jpgAlbum 7522 13057.jpgAlbum 13057 bfsjq597-img600x450-1293012459v70sxm12525.jpg S_badge_reverse.jpg bfsjq597-img600x450-1293012459yvrlgd12525.jpg bfsjq597-img600x450-1293012459er55u512525.jpg
457.jpgAlbum 457
retrofitted to early grille
23190.jpgAlbum 23190
22513.jpg#1972 DX
174_6905a8b215cf0.jpg#GL early
28127.jpg#GL 1972
6420_5c245be860d51.jpg#GX Early
25658.jpg#GX 1972
1536.jpg#GX 5 SPEED
62330-H2325 Early GX
GX early (1970-1971) COUPE, SEDAN grille badge
18053.jpgAlbum 18053
Compare to rear see-through badge
grille badge has long studs for mounting through the grille
contrast with rear sedan badge which has flush-mount pins
6420_5c245be860d51.jpgPost click for topic 6420_5c245c9d038d3.jpgPost click for topic 6420_5c245ca5bcc0b.jpgPost click for topic 6420_5c245cacd7d00.jpgPost click for topic
GX-grille-badge-2.jpg GX-grille-badge-1.jpg yunakiti-img600x450-1277628693ok47g777311.jpg yunakiti-img600x450-1277628693ybadxo77311.jpg yunakiti-img600x450-1277628693qqw7ym77311.jpg 62330-H2225.jpg 62330-H2225_reverse.jpg gx_grille_badge-1.jpg gx_grille_badge-2.jpg gx_grille_badge-3.jpg 27477.jpgAlbum 27477
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
GX flat badge
This modern GX badge has no pins. It has a design like the early GX front trim badge (with the same black background) but is designed for stick-on applications so won't easily fit the 1200 sedan or coupe grilles. Has sticky tape on the flat back of the emblem.
27825.jpgAlbum 27825 27826.jpgAlbum 27826 27827.jpgAlbum 27827
62330-H2026 Early GL
62330-H2026 EMBLEM-'GL' (1970-1971). Used by #sedan and coupe
27822.jpgAlbum 27822 174_6905a8b215cf0.jpgPost 499102 174_6905a8b746394.jpgPost 499102
background-color: blue, but the paint has usually disappeared after 30 to 50 years in the weather
bolt-on type (rear GL badge looks similar, but is the push-in type)
963.jpgAlbum 963 174_6905a89807c03.jpgPost 499102
26619.jpgcoupe brochure 27374.jpgsedan brochure
M4 studs, nuts and washers
174_6905ab49bd21d.jpgPost 499102 174_6905ab3fbcf25.jpgPost 499102 174_6905ab59b55ed.jpgPost 499102 174_6905ab7c303ba.jpgPost 499102 174_6905ab676c645.jpgPost 499102
62330-H3125 1972 Deluxe
NOTE: 1970-1971 DX did not come with a trim badge on the grille
EMBLEM SET-radiator grille "DELUXE" [1972]
7522.jpgAlbum 7522 25974.jpgAlbum 25974
compare to rear badge 84823-H1000
22513.jpgAlbum 22513
62330-H3425 1972 GX
GX 1972 62330-H3425 EMBLEM SET-radiator grille "GX" SEDAN, COUPE
Grille 'GX' has long bolts and a bracket, in order bolt it to the grill. The similar rear 'GX' badge has short pins.
Late badge has narrow font (approximately 71mm wide)
25658.jpgAlbum 25658 29956.jpgAlbum 29956
compare to early 1970-1971 'GX' expanded font grille emblem
compare to rear see-through badge (short pins) and ~100mm wide
Long bolts for the grille badge
29955.jpgAlbum 29955 29957.jpgAlbum 29957
comes with a clamp plate
29958.jpgAlbum 29958
#Early GL and Late GX
16719.jpgAlbum 16719
62330-H3325 1972 GL
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL" (1972 sedan, coupe)
28127.jpgAlbum 28127
compare to early rectangular GL badge #62330-H2026
20864.jpgAlbum 20864
Grille badge has long studs for mounting through the grille.
28132.jpgAlbum 28132
Backing plate is either simple flat or the stronger ridged type
28128.jpgAlbum 28128 28129.jpgAlbum 28129 28131.jpgAlbum 28131
original white paint | with paint faded away
28130.jpgAlbum 28130 28133.jpgAlbum 28133
Cast mark "62330-H3300"
28134.jpgAlbum 28134
placed on 1972 sedan grille
1523.jpgAlbum 1523 457.jpgbrochure 28135.jpgAlbum 28135
62330-H7225 GX 5 SPEED
The 1972-only GX5 came with this badge, used on both sedan and coupe
26083.jpgAlbum 26083
