Room Lamp
Revision as of 05:42, 22 November 2025; view current revision
<-- back to Lighting_System#Interior_Lamps
The room lamp, also known a dome light.
Put the switch in the middle position so it operates from the door switches (if so equipped).
interior "dome" light
5036.jpgAlbum 5036
1972 USA Owners manual (Page 06 ... ):
To switch the interior lamp "ON", and "OFF", turn the switch lever clockwise or counterclockwise.
interior lamp switch
13404.jpgAlbum 13404
alternative interior headliner light
3401.jpgAlbum 3401
Car
Room Lamp attached to the roof in the headliner in sedans and coupes:
174_67c6433e143fd.jpgPost 498810
Room Lamp attaches to the Roof bow (the center rail across the underside of the roof panel)
174_65b2c98916684.jpgPost 498220
These parts are the same for both B110 and B210.
B110 | B210 (120Y)
20745.jpgAlbum 20745 6525_4ac87a62a371d.jpgUpload click to view
Pickup
B120 Datsun 1200 Truck used a rectangular room lamp. The same unit was used by #B10 Datsun 1000 and #521 Datsun pickup
16762.jpgAlbum 16762 20746.jpgAlbum 20746
buy from Bprojects
26410-04100 LAMP ASS'Y-room -7803 IKI [single wire]
26410-04400 LAMP ASSY-ROOM 7803- IKI [two wire]
26410-G1000 LAMP ASSY-ROOM -7803 IMASEN
Single Wire
Two Wire type:
* Red/yellow: bulb 12V
* Black: earth/ground
b10-room-lamp-2013-7-10-001.jpg b10-room-lamp-2013-7-10-003.jpg b10-room-lamp-2013-7-10-004.jpg b10-room-lamp-2013-7-10-005.jpg b10-room-lamp-2013-7-10-006.jpg
Door Sensors
Instead of buying a 2-wire room lamp, the 1-wire type can be modified so that the lamp lights when a door is opened. There is no OFF position, but the lamp will go out when the door is closed.
POST See writeup "Daily Ute"
Isuzu Alternative
Reportedly, the 2000 Rodeo sport the same or similar Room Lamp to the late 1200 (both with door light positions)
Astro_Boy: was looking at a 2000 model rodeo ute that was crashed and would you believe it? THE INTERIOR LIGHT is the same size and shape as the standard datsun one, but with a door sensor setting!
LED Conversion
B10
B10 sedan and VB10 wagon uses the same lap as 1200 ute. IKI brand (市川, Ichikawa).
26410-04100 ASS'Y-LAMP, room STD IKI
26410-04400 ASS'Y-LAMP, room DELUXE IKI
6W bulb in B20
29894.jpgAlbum 29894
521 Lamp
Datsun 521 pickup (USA) uses the same Room Lamp as a 1200 Pickup. IKI brand.
26400-04100 ASS'Y-LAMP, room
* 26411-04100 LENS
* 26715-89900 BULB (12V 6W)
* 5-10813-1 SCREW-machine (2)
510 Lamp
510 lamp is a different style and bolts into B210, so may fit B110.
23128.jpgAlbum 23128 23129.jpgAlbum 23129
26410-23100 ASSY-LAMP ROOM -0968 EXC CAN <x> 26410-23101
* 1968 CANADA used dual rectangular side lamps
26410-A0800 ASSY-LAMP ROOM 0968-
Door Switch
The door switch connects the Room Lamp circuit. It also connects the Key Warning Buzzer.
  • The 1200 door switch is a single wire unit that grounds the wire when the door is opened
  • The 1973 USA door switch is a double-switch (with an extra wire)
25360-89900 SWITCH-DOOR DELUXE(OP STD)
25360-89915 SWITCH-DOOR USA 0172-
The room lamp has one side of the lamp (RL wire) always hot from the L wire of the fuse box (Fuse 'C'). The switch has three positions:
* Off
* Auto (center)
* On
20758.jpgAlbum 20758
In the auto position, the light is grounded by the Door Switch (BR wire in A-pillar). Usually only the driver's side door has a switch. In the ON position, it is grounded through the ground wire in the headliner (or with standard switch, via the attaching screws).
Dash harness has the door switch/room lamp wiring
5043.jpgAlbum 5043
Black     Ground
Black/red Ground from door switch
Red/blue  Always Hot
  • 12V is supplied by 'C' fuse in Fuse Box (C: Cigarette, Room, Radio)
  • Ground wire out of Lamp may be a short wire that bolts to the roof metal
  • Early truck lamps have no Ground wire (black wire) but ground through the lamp screws. This is for use without a door switch
  • 1973 used a relay, but with the same wire colors. The 1973 door switch is a double-switch (with an extra wire)
7804- wiring with 2-wire room lamp (can use optional door switch)
26484.jpgAlbum 26484
-7804 truck with 1-wire room lamp (no option for door switch)
1971 USA Wiring - with buzzer
1973 USA Wiring - with buzzer, warning light, IGN interlock
26485.jpgAlbum 26485
ルームランプ
