Side Lamps
Revision as of 03:12, 29 November 2025; view current revision
<-- back to Lighting System
Datsun 1200 side lamps are used either as running lamps (USA) or indicators/blinkers/flashers (Australia). Because USA purpose is for visibility (instead of turn signals) they are made larger, and are fitted front and rear. B210 worldwide markers adopted the size of the earlier USA B110 side lights (although the shape is slightly different).
Fitment
The side lamp bolts to the outer fender (wing/guard)
3636.jpgAlbum 3636 8456.jpgAlbum 8456
The wires from the lamp pass through the inner fender into the engine compartment via a grommet
8710_5275fd738449d.jpgPost 446905
Even late model 1200 (black rim version) use the grommet. Most aftermarket lack this part
174_67df848ea69fa.jpgPost 498823
Rear side marker lamps (used in North America) bolt to the rear fender, directly into the trunk room, hence use no grommet
143.jpgAlbum 143
Variations
1200 #global
* long thin ORANGE lenses for turn signal (blinkers)
* front only
1200 #North America
* front lamp and rear reflector
* Yellow front marker (non-flashing)
* Red rear reflector
* both are taller (more squarish)
Global
107 x 24 mm side lights are used as winker/blinker (indicator) lamp in worldwide markets, including Japan, Europe and Oceania. For #North America, side indicators were not used but only side lamps.
#H10 26160-H1001 LAMP ASS'Y-side flasher -7803 [chrome rim]
#G10 26160-G1060 LAMP ASS'Y-side flasher 7804- [black rim]
8456.jpgAlbum 8456 20763.jpgAlbum 20763
Chrome Type
174_68d7a5ed061ea.jpgPost 499061
'IKI 5002 JAPAN' | 'B-110 45 TOKYO'
20764.jpgAlbum 20764 20763.jpgAlbum 20763 12063.jpgAlbum 12063
4099.jpgAlbum 4099 3812.jpgAlbum 3812 8456.jpgAlbum 8456
* integrated two-wire harness (bulb 12V + earth/ground)
26161-H1001 LENS -7803 [marked 'IKI 5002 JAPAN]
26162-H1001 RIM -7803
20765.jpgAlbum 20765
26164-H1001 PACKING -7803
01451-00071 SCREW
08964-10410 NUT-spring
26715-89900 BULB-6W
9516.jpgAlbum 9516 16407.jpgAlbum 16407
sla.jpg slb.jpg slc.jpg sld.jpg sle.jpg slf.jpg slg.jpg slg.jpg slh.jpg sli.jpg slj.jpg slk.jpg slm.jpg sln.jpg slo.jpg slp.jpg slq.jpg slr.jpg
810
Datsun 810 Bluebird/200B/180B side markers use the Datsun B110 lens and rim
19680.jpgAlbum 19680
Type U74 looks exactly like the B110 markers right down to the bullet wire connectors, but the lamp body is somehow different
174_68d7a5adb6099.jpgPost 499061 174_68d7a5e7eb744.jpgPost 499061
Type U74 is for 4-cylinder Datsun 810. The 6-cylinder models use the larger 510/B210/240Z pointed markers
810 SIDE FLASHER LAMP ASSEMBLY
26160-U7400 for SHORT BODY
* 26161-H1001 LENS
* 26162-H1001 RIM
26160-U7400 for LONG NOSE [6-cylinder models]
Black-rimmed type
Image Search: サニトラサイドマーカーランプ
G10 type was used from 1978 April - with black rim
174_5bc7e7167e6e9.jpgPost 489721
26161-      LENS ?
            RIM ?
26164-G1060 PACKING 7804-
01451-00071 SCREW
26715-89900 BULB-6W
28025.jpgAlbum 28025 4457.jpgAlbum 4457
Even late model 1200 (black rim version) use the grommet. Many aftermarket lamps lack the grommet
174_67df848ea69fa.jpgPost 498823 174_5bc7e75199728.jpgPost 489721
174_67df849374276.jpgPost 498823 174_67df849d4e02a.jpgPost 498823 174_67df84a8552e1.jpgPost 498823
174_5bc7e730c959d.jpgPost 489721 174_5bc7e75199728.jpgPost 489721 174_5bc7e75b3811a.jpgPost 489721
North America
North America side lamps are only parking lamps, and have no indicators/blinker functions. Side lamps are larger on North American models, also the fenders come with a larger hole to match. Euro/Asia guards/wings can be used on America 1200s, if the hole is enlarged. Australia moved to the same-sized large lights with the 1974 120Y.
BEWARE: Unlike the multitude of "1200" lamps on eBay, which are actually B210 lamps, 1200 lamps have
  • two bullet-connector wiring
  • rectangle shape, not pointed in the least
The B210/240Z/510 lamps may fit but require wire splicing and/or conversion wiring
#ORANGE, FRONT | #RED, REAR
1479.jpgAlbum 1479 174_5b45742bcc2dd.jpgPost 488880 174_5b4576e3ce84d.jpgPost 488881
* 2-wire (12V + Ground) for side marker lamp (non-flashing)
* individual wires (one female bullet, one male bullet)
* right and left differ
* front and back differ
  * front has longer wires with a grommet
  * lenses amber FRONT, red REAR
* Both RH and LH lenses are marked IKI 5003 as well as IKI 7007
* Lenses marked SAE P169 and SAE A69
SAE PI69 and A69 are found on many cars and indicate meeting the 1969 standards.
Front: grommet. Rear: without grommet
174_67df604d9e05e.jpgPost 498821
COMMON [4 of each per vehicle]
* 26182-H1900 RIM
* 26715-89902 BULB 12V-8W (ICHIKHO)
* 08964-10410 NUT-SPRING (ICHIKHO) [8 per vehicle]
NOTE: The lamp packing wraps around the housing and thus acts as a gasket between body panel and housing and between housing and rim/lens.
SAE lighting standards codes (SAE J759)
174_5b4587336916a.jpgPost 488883
SAEPI69
SAE = Society of Automotive Engineers (SAE International)
   P = Parking Lamps
    I = Turn signal lamps
    A = Reflex reflectors
     69 = meets the 1969 standard
Although the housing is marked 'I' (Indicators/Turn Signals), these North America side lamps are only parking lights, and have no indicators/blinker functions.
Front vs rear housings
174_67df2a3520f46.jpgPost 498820 174_67df6fc399e37.jpgPost 498822
ORANGE, FRONT
Orange/Amber front lamps are same coupe and sedan
20761.jpgAlbum 20761
* 26180-H1900 ASSY-LAMP SIDE MARKER FRONT RH (ICHIKHO)
* 26185-H1900 ASSY-LAMP SIDE MARKER FRONT LH (ICHIKHO)
* 26180-H7000 ASSY-LAMP SIDE MARKER FRONT RH OKINAWA 0772-
* 26185-H7000 ASSY-LAMP SIDE MARKER FRONT LH OKINAWA 0772-
* 26184-H1900 PACKING RH
* 26189-H1900 PACKING LH
* 26181-H1900 LENS, FRONT [amber]
* 01451-00041 SCREW (2 per lens)
front
740.jpgAlbum 740 10023.jpgAlbum 10023 1479.jpgAlbum 1479 3636.jpgAlbum 3636
Okinawa?
26794.jpgAlbum 26794
R and L lens is the same. They are marked 'TOP' on both edges so they can be turned over for correct bevel for the intended side (Lens is thicker at front edge matching the curvature of the fender).
IKI 5003 JAPAN SAE PI69 SAE A69 IKI 7007
174_5b45742bcc2dd.jpgPost 488880 174_5b4574580d799.jpgPost 488880 174_5b457473219b7.jpgPost 488880 174_5b457482c8950.jpgPost 488880 174_5b45749575cf7.jpgPost 488880
MADE IN JAPAN
174_5b45748b17d45.jpgPost 488880
With grommet intact
174_67df604d9e05e.jpgPost 498821 174_67df60575d9df.jpgPost 498821
Used part missing the grommet
174_67df2a19105d7.jpgPost 498820 174_67df2a2097527.jpgPost 498820 174_67df2a3520f46.jpgPost 498820
RED, REAR
rear lamps sedan and coupe differ. Lenses are the same but the housing differs.
174_5b4576e3ce84d.jpgPost 488881 174_67df6fc399e37.jpgPost 498822
rear COMMON COUPE+SEDAN
* 26191-H1900 LENS, REAR [red] (2)
PLUS the common parts (bulb, chrome rim, and spring nuts)
Lenses are marked same as fronts IKI 5003/IKI 7007 but of course the color differs. ICHIKO (IKI) was the company that sourced these parts for Nissan.
20760.jpgAlbum 20760
rear COUPE
* 26190-H1910 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) COUPE
* 26195-H1910 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) COUPE
* 26194-H1910 PACKING RH(ICHIKHO) COUPE
* 26199-H1910 PACKING LH(ICHIKHO) COUPE
 * 01451-00061 SCREW(ICHIKHO) COUPE (2 per lens)
rear SEDAN
* 26190-H1900 ASSY-LAMP SIDE MARKER REAR RH (ICHIKHO) SEDAN
* 26195-H1900 ASSY-LAMP SIDE MARKER REAR LH (ICHIKHO) SEDAN
* 26194-H1900 PACKING RH(ICHIKHO) SEDAN
* 26199-H1900 PACKING LH(ICHIKHO) SEDAN
 * 01451-00041 SCREW SEDAN (2 per lens)
What's the difference between Coupe and Sedan rear side light? They look the same, but since the coupe uses longer screws, perhaps the lamp housing is thicker?
rear
10023.jpgAlbum 10023 143.jpgAlbum 143 4643.jpgAlbum 4643 4185.jpgAlbum 4185 5035.jpgAlbum 5035 6603.jpgAlbum 6603 1605.jpgAlbum 1605
174_5b4576bc55c2b.jpgPost 488881 174_5b4576c360f48.jpgPost 488881 174_5b457665bceb3.jpgPost 488881 174_5b45768174e63.jpgPost 488881 174_5b45768ba51f9.jpgPost 488881 174_5b4576a819cd9.jpgPost 488881 174_5b4576ea8cb1c.jpgPost 488881 174_5b4576e3ce84d.jpgPost 488881 174_5b4576afa50fc.jpgPost 488881
Bullet connectors (see Lamp Wiring)
174_5b4576d850c66.jpgPost 488881 174_5b4576f1e2e70.jpgPost 488881
Gasket tapers (this may be coupe? or sedan?)
174_67df6fcd45d76.jpgPost 498822 174_67df6fd682934.jpgPost 498822
Bulb Replacement
Nissan 26715-89900 or type 97
174_67df6fde3d1f5.jpg97
Remove both screws from the lens, and remove lens
Push bulb in slightly and twist anti-clockwise
Pull bulb straight out
Wiring connectors differ between early, late 1200s and differ for various countries. Early 1200 lamps use bullet connectors.
Only the 1200 lights interchange. However, USA 620 lenses interchange with USA 1200.
620
In USA, the 620 side marker lenses look identical. The front lamp assembly looks nearly the same as the 1200, except the packing (gasket) may be beveled (?) The rear uses a highly-angled lamp housing.
USA 620 vs 1200
* lens & rim interchange
* front housing may interchange
* rear housing does not interchange
1974_620_rear.jpg markers-c.jpg markers-a.jpg markers-d.jpg markers-b.jpg markers-e.jpg
SAME AS B110 USA
* 26181-H1900 LENS-SIDE MARKER LAMP, FRONT (2)
* 26191-H1900 LENS-SIDE MARKER LAMP, REAR (2)
* 26182-H1900 RIM-SIDE MARKER LAMP (4)
* 01451-00041 SCREW, FRONT LAMP (4)
* 08964-10410 NUT-SPRING, FRONT LAMP (4)
The rear lamp technically takes:
01451-00051 SCREW (4)
08966-30410 NUT-SPRING (4)
Pointed Lens
Pointed lens is used by B210 and 240Z and (late USA) 510. B110 is rectangular, compared to the slightly pointed rectangle type.
1200 North America
Pointed type
B210 side lamp is different from B110 lamp, and uses a different connector style
See Main Article: B210#Side_Lights
S30 240Z bullet wire connectors
S30 260Z/280Z rectangular connector
B210 (120Y)   rectangular connector
510 late
The USA late 510 units 1970-1972 uses the 240Z pointed lens, though the assembly differs somehow
S30
240Z has individual wires
260Z has the rectangular connector
Lamp assembly differs from B210 somehow
North America (Canada and USA) used amber front side lamp and red rear side reflector
IKI 5005 & 5004
26160-E4100 & 26165-E4100
26160-E4100
26190-E4600 & 26195-E4600
LENS 26161-E4100 IKI 5005
26161-E4100_IKI_5005_.jpg 26161-E4100_IKI_5005.jpg 26161-E4100_IKI_5005-.jpg
PB110
See Main Article: PB110#Side_Lights
Datsun 1000
See main article: Datsun 1000
B140
South Africa B140 bakkie from 1982-2004 used the #Global indicator.
From 2005-2008, the B140 used this small indicator:
26051.jpgAlbum 26051
26054.jpgAlbum 26054 26053.jpgAlbum 26053
Clear aftermarket from Autostyle
16080.jpgAlbum 16080 17089.jpgAlbum 17089
Clear Lense
20379.jpgAlbum 20379 1850.jpgAlbum 1850
clear side lenses with front & rear combo lenses
20381.jpgAlbum 20381
26121-27700 Datsun B10 clear lens - will it fit the 1200?
20759.jpgAlbum 20759
Semi-clear lenses for 2005-2008 B140
17088.jpgAlbum 17088
Custom
14605.jpgAlbum 14605 15474.jpgAlbum 15474 17152.jpgAlbum 17152 17552.jpgAlbum 17552
Commodore
Holden Commodore VT indicators 1997-2000
14930.jpgAlbum 14930 400px-1999-2000_HSV_Senator_%28VT_II%29_Signature_sedan_01.jpgWIKI go to Wikipedia
you'll need to weld up the standard indicator hole as the commodore blinkers aren't as big on the back where they mount. The hole needs to be about half the standard size
10172.jpgAlbum 10172 11014.jpgAlbum 11014
Falcon
Ford Falcon BA 2002-2005
15803.jpgAlbum 15803 400px-2002_Ford_Fairmont_%28BA%29_sedan_%2817695633372%29.jpgWIKI go to Wikipedia
C130 Laurel Winkers
Side lamps from the 1972-1977 Nissan C130 Laurel fit the 1200 according to blog
400px-1974_Nissan_Laurel_Hadtop_2000SGX.jpgWIKI go to Wikipedia
Remove the 1200 side lamp
174_5db39690a1395.jpgPost 492955 174_5db396ab0129c.jpgPost 492955
drill out the front hole | bolt C130 lamp on
174_5db396b3f3701.jpgPost 492955 174_5db396bbc5736.jpgPost 492955
Search terms: lens, blinker, marker, side light, side lamp, running light ウインカ ランプ レンズ ウィンカー サイドマーカー
