Pre-1980
B10: H145, 3.900 VB10: 4.111 (van/wagon) B20: 4.111 (ute/truck) B110: H145 3.900 VB110: H145 4.111 (van/wagon) PB110: H165 4.111 B120: H165 4.111 (ute/truck) B210 1974: H145 3.900 B210 1975-up: H150 3.700 or 3.889 PB210/GB210: H165 B310: H150 various A10: H165 various
1980-up
Axle Codes H = Hitachi removable gear carrier (pumpkin/centre section) HA - H145 (145mm diameter ring gear, 5.709 inch) HA38 H150 3.889 ratio HB - H150 (150mm diameter ring gear, 5.906 inch) HC - H165 (165mm diameter ring gear, 6.496 inch) HD - H190 (190mm diameter ring gear, 7.480 inch) ALUMINUM CARRIER HE - H190 CAST IRON CARRIER HF - H190A revised for strength
Axle code is on Chassis Identification plate 1980-on
Starting in mid-80s, Axle Code is on door-jamb sticker.
Counting
39 divided by 11 = 3.545 ratio
