The Datsun 1200 uses a Hitachi carb, model Hitachi DCG-306 (manual choke) or DCH-306 (automatic choke). This is a modern, two-barrel progessive linkage carburetor. It used bore sizes of 26/30 and venturis of 20mm (primary) and 26mm (Secondary). Datsun 1200 GX models used twin Hitachi 38 sidedraft carburetors with a manual choke system.
Hitachi numbers indicate the primary bore * secondary bore sizes:
Hitachi DCG306 G = manual choke | H = automatic choke 30 = 30mm secondary bore 6 = 26mm primary bore
Links
Hitachi DCx carbs were used on, among others:
* 1967-1970 Datsun B10 (DCG286) * 1970-1973 Datsun B110 (DCG306 and DCH306) * 1973-1980 Datsun L-series (Hitachi DCH340) * 1973-1980 Datsun B210 * 1977-1982 Datsun B310 * 1973-1975 Honda Civic * 1976-1979 Mazda 323 * 1983-1985 Ford Laser (DCT306)
See Also:
- Fuel System Category Page
- Carburetor Adjustment
- Carburetor Repair
- Carburetor Specifications
- Carburetor Diagnoses Diagnoses and Corrections
- Carburetor Swaps
- Weber 32/36 Carburetor
- Weber DCOE carburetor
NOTE: The B10 Datsun 1000 used a smaller carb, the Hitachi DCG-208.
DCG-306
DCG is the manual-choke series.
DCH-306
DCH is the Automatic Choke series.
Vacuum Secondary
DCH-306 with vacuum-operated secondary throttle. 1981-1982 USA models.
DFC306
Feedback carburetor DFC306 is the carburetor on 1989-1994 JDM A12 engines. It requires a special water heated Intake Manifold and ECU control.
See main article: DFC306
