フロア The front floor panel is stamped in one piece with the tunnel. However, automatic cars have a separate tunnel.
A CROSS MEMBER, front seat (RH & LH differ) * Van & Truck driver's side has Jack bracket B SEAT BRACKET, inner (RH & LH) C SEAT BRACKET, outer (RH & LH) D (Truck only) Back Panel, lower E (Truck only) Back Panel
Replacement coupe floor panels by Automotive Panel Craft (1mm cold rolled mild steel)
Front Floor
FRONT FLOOR PANEL USA/JAPAN, COUPE/SEDAN/VAN 1 ASSY-FLOOR FRONT 74300-H1000 3 SPEED 74300-H1010 4 SPEED 74300-H1021 AUTOMATIC 2 FRONT SEAT CROSS MEMBER RH 3 FRONT SEAT CROSS MEMBER LH * H14 Van RHD [has bracket for Jack] 4 FRONT SEAT BRACKET-INNER RH 5 FRONT SEAT BRACKET-INNER LH 6 FRONT SEAT BRACKET-OUTER RH 7 FRONT SEAT BRACKET-OUTER LH 8 INNER SILL (FLOOR SIDE MEMBER) RH 9 INNER SILL (FLOOR SIDE MEMBER) LH 16 FRONT SIDE MEMBER RH 17 FRONT SIDE MEMBER LH 18 TENSION ROD BRACKET RH 19 TENSION ROD BRACKET LH 20 FRONT CROSS MEMBER
BRACKET-FRONT SEAT MOUNTING 74316-H1000 OUTER RH 74317-H1000 OUTER LH 74314-H1001 INNER RH 74315-H1000 INNER LH -8910 74351-95W00 INNER LH 8910-
Bakkie front floor
Front Side Members
The front side members from the base of the engine compartment; the engine crossmember bolts to it, and the hoodledges are welded to it.
Rear Floor
Coupe, Sedan, Van and Truck all differ in the rear floor area. All use a front & rear crossmember attached to side members to create a basic ladder support to which the floor is attached.
Coupe
Rear Floor, Truck
The Truck rear floor is the bottom of the tray/bed. The supporting structure (side members and cross members) are also part of the floor.
See Truck Rear Floor Panel
Floor Trim
See: * Upholstery * Floor Trim Part Numbers
In addition to the (optional) Carpet insulation, the floor panels have pre-applied asbestos heat shield/sound-dampening sheets applied. It is asbestos in an asphalt base. It does not appear to flake or grate, but stays embedded even if chipping it off. So likely there is no risk of inhaling asbestos fibres unless you use a grinder on the insulation. To be safe, leave it alone. If it needs to be removed for some reason lift it off the floor while wearing a mask. Do not saw or grind it. It comes off in large pieces with relatively little work in cold weather, but is too soft in hot weather. Possibly it can be cooled using dry ice, then chiseled off in large pieces.
See main article: Floor Part Numbers
Ute
Rear Floor: See Body Panels
Front Floor Panel サニトラ フロント フロア パネル
- 74300-G1050 FLOOR ASS'Y-front (up to '72-12) 3-speed
- 74300-G1450 FLOOR ASS'Y-front (from '73-1) 3-speed
- 74300-G1150 FLOOR ASS'Y-front (up to '72-12) 4-speed
- 74300-G1450 FLOOR ASS'Y-front (from '73-1) 4-speed
- 74300-G1401 FLOOR-FRONT 7510-7803
- 74300-G1160 FLOOR-FRONT 7804-8808
- 74300-G1950 FLOOR-FRONT 8809-9810
- 74300-95W00 FLOOR-FRONT 9810-
Floor assembly includes: A * 74310-H1000 MEMBER ASS'Y-cross seat, front (R.H.) -8904 * 74330-95W00 MEMBER-FRONT SEAT MOUNTING, RH 8904- * 74311-H1400 MEMBER ASS'Y-cross seat, front (L.H.) -8910 * 74331-95W00 MEMBER-FRONT SEAT MOUNTING, LH 8910- B * 74314-H1001 BRACKET-front seat, inside (R.H.) * 74315-H1000 BRACKET-front seat, inside (L.H.) -8910 * 74351-95W00 BRACKET-FRONT SEAT MOUNTING, INNER LH 8910- C * 74316-H1000 BRACKET-front seat, outside(R.H.) * 74317-H1000 BRACKET-front seat, outside(L.H.) (not shown in photo) inner sill, under the aluminum sill trim * 74320-G1000 FLOOR ASS'Y-side (R.H.) * 74321-G1000 FLOOR ASS'Y-side (L.H.)
D, E: See Body Related parts * 74810-H1001 MEMBER ASS'Y-side, front (R.H.) * 74810-G1600 MEMBER-SIDE, FRONT RH 7510-7803 * 74810-G1601 MEMBER-SIDE, FRONT RH 7804-8910 * 74810-G1900 MEMBER-SIDE, FRONT RH 8910- * 74811-H1001 MEMBER ASS'Y-side, front (L.H.) * 74811-G1601 MEMBER-SIDE, FRONT LH 7510-8503 * 74811-H1001 MEMBER-SIDE, FRONT LH 8504-8910 * 74811-G1900 MEMBER-SIDE, FRONT LH 8910- * 54532-H1001 BRACKET ASS'Y-tension rod (R.H.) * 54532-H1001 BRACKET ASS'Y-tension rod (L.H.) * 74800-H1000 MEMBER ASS'Y-cross front
