Floor
Revision as of 03:50, 30 May 2025; view current revision
Category: Body
フロア The front floor panel is stamped in one piece with the tunnel. However, automatic cars have a separate tunnel.
23056.jpgAlbum 23056
A CROSS MEMBER, front seat (RH & LH differ)
  * Van & Truck driver's side has Jack bracket
B SEAT BRACKET, inner (RH & LH)
C SEAT BRACKET, outer (RH & LH)
D (Truck only) Back Panel, lower
E (Truck only) Back Panel
Replacement coupe floor panels by Automotive Panel Craft (1mm cold rolled mild steel)
floor_coupe_L_1.jpg floor_coupe_L_2.jpg floor_coupe_L_3.jpg floor_coupe_L_4.jpg
2-door Sedan Floor
26416.jpgAlbum 26416
Front Floor
089-01a.jpg 16791.jpgAlbum 16791
FRONT FLOOR PANEL USA/JAPAN, COUPE/SEDAN/VAN
 1 ASSY-FLOOR FRONT
   74300-H1000 3 SPEED
   74300-H1010 4 SPEED
   74300-H1021 AUTOMATIC
 2 FRONT SEAT CROSS MEMBER RH
 3 FRONT SEAT CROSS MEMBER LH
   * H14 Van RHD [has bracket for Jack]
 4 FRONT SEAT BRACKET-INNER RH
 5 FRONT SEAT BRACKET-INNER LH
 6 FRONT SEAT BRACKET-OUTER RH
 7 FRONT SEAT BRACKET-OUTER LH
 8 INNER SILL (FLOOR SIDE MEMBER) RH
 9 INNER SILL (FLOOR SIDE MEMBER) LH
16 FRONT SIDE MEMBER RH
17 FRONT SIDE MEMBER LH
18 TENSION ROD BRACKET RH
19 TENSION ROD BRACKET LH
20 FRONT CROSS MEMBER
10318_4c46da6abdaec.jpgPost 328659
BRACKET-FRONT SEAT MOUNTING
74316-H1000 OUTER RH
74317-H1000 OUTER LH
74314-H1001 INNER RH
74315-H1000 INNER LH -8910
74351-95W00 INNER LH 8910-
Bakkie front floor
18325.jpgAlbum 18325
Floor Side (inner sill)
Floor panel cut away, exposing the right front side member
25074.jpgAlbum 25074
Front Side Members
The front side members from the base of the engine compartment; the engine crossmember bolts to it, and the hoodledges are welded to it.
10318_4c46d976dc0b1.jpgPost 328659 1759.jpgAlbum 1759
Rear Floor
Coupe, Sedan, Van and Truck all differ in the rear floor area. All use a front & rear crossmember attached to side members to create a basic ladder support to which the floor is attached.
#Coupe
Van
15569.jpgAlbum 15569
Sedan
10513_4bdee6ec26027.jpgPost 315202
Coupe
270-03b.jpgparts
Front floor panel + Rear floor panel
21235.jpgAlbum 21235
Spare wheel well (part of the Rear Floor Panel)
21236.jpgAlbum 21236
12908.jpgAlbum 12908 10318_4c46da56121c4.jpgPost 328659 174_57932af8d74e1.jpgPost 480061 174_57932afeba7f5.jpgPost 480061 174_57932b0c16080.jpgPost 480061
174_57932b0571244.jpgPost 480061
Rear Floor, Truck
The Truck rear floor is the bottom of the tray/bed. The supporting structure (side members and cross members) are also part of the floor.
Floor Trim
See:
* Upholstery
* Floor Trim Part Numbers
In addition to the (optional) Carpet insulation, the floor panels have pre-applied asbestos heat shield/sound-dampening sheets applied. It is asbestos in an asphalt base. It does not appear to flake or grate, but stays embedded even if chipping it off. So likely there is no risk of inhaling asbestos fibres unless you use a grinder on the insulation. To be safe, leave it alone. If it needs to be removed for some reason lift it off the floor while wearing a mask. Do not saw or grind it. It comes off in large pieces with relatively little work in cold weather, but is too soft in hot weather. Possibly it can be cooled using dry ice, then chiseled off in large pieces.
Ute
Rear Floor: See Body Panels
Front Floor Panel サニトラ フロント フロア  パネル
  • 74300-G1050 FLOOR ASS'Y-front (up to '72-12) 3-speed
  • 74300-G1450 FLOOR ASS'Y-front (from '73-1) 3-speed
  • 74300-G1150 FLOOR ASS'Y-front (up to '72-12) 4-speed
  • 74300-G1450 FLOOR ASS'Y-front (from '73-1) 4-speed
  • 74300-G1401 FLOOR-FRONT 7510-7803
  • 74300-G1160 FLOOR-FRONT 7804-8808
  • 74300-G1950 FLOOR-FRONT 8809-9810
  • 74300-95W00 FLOOR-FRONT 9810-
Floor assembly includes:
A
* 74310-H1000 MEMBER ASS'Y-cross seat, front (R.H.) -8904
* 74330-95W00 MEMBER-FRONT SEAT MOUNTING, RH 8904-
* 74311-H1400 MEMBER ASS'Y-cross seat, front (L.H.) -8910
* 74331-95W00 MEMBER-FRONT SEAT MOUNTING, LH 8910-
B
* 74314-H1001 BRACKET-front seat, inside (R.H.)
* 74315-H1000 BRACKET-front seat, inside (L.H.) -8910
* 74351-95W00 BRACKET-FRONT SEAT MOUNTING, INNER LH 8910-
C
* 74316-H1000 BRACKET-front seat, outside(R.H.)
* 74317-H1000 BRACKET-front seat, outside(L.H.)
(not shown in photo)
inner sill, under the aluminum sill trim
* 74320-G1000 FLOOR ASS'Y-side (R.H.)
* 74321-G1000 FLOOR ASS'Y-side (L.H.)
D, E: See Body
Related parts
* 74810-H1001 MEMBER ASS'Y-side, front (R.H.)
* 74810-G1600 MEMBER-SIDE, FRONT RH 7510-7803
* 74810-G1601 MEMBER-SIDE, FRONT RH 7804-8910
* 74810-G1900 MEMBER-SIDE, FRONT RH 8910-
* 74811-H1001 MEMBER ASS'Y-side, front (L.H.)
* 74811-G1601 MEMBER-SIDE, FRONT LH 7510-8503
* 74811-H1001 MEMBER-SIDE, FRONT LH 8504-8910
* 74811-G1900 MEMBER-SIDE, FRONT LH 8910-
* 54532-H1001 BRACKET ASS'Y-tension rod (R.H.)
* 54532-H1001 BRACKET ASS'Y-tension rod (L.H.)
* 74800-H1000 MEMBER ASS'Y-cross front
