Strut Tops
Revision as of 00:26, 13 February 2012; view current revision
Category: Front Axle And Front Suspension
The Datsun 1200 strut top is a rubber insulator for the the strut, and utilizes a bearing for easy rotation for the steering system. Most aftermarket adjustable strut tops do not include an insulator, so are not recommended for a street or off-road vehicle.
[hide]
Also see
Stock 1200 strut tops protrude above the tower:
NOTE: In the photo above, the tower has been modified for camber adjusability per the Datsun Competition suspension manual.
See main article: Camber
Aftermarket adustable:
54320-H1000 INSULATOR-STRUT MOUNTING (2)
 08915-53810 WASHER-PLAIN M8 (6)
 08915-13810 WASHER-SPRING M8 (6) 6
 08911-10810 NUT-HEX M8X1.25 (6) 6
54325-H1000 BEARING-STRUT MOUNTING (2)
Comparison
Strut tops: B210 (left) vs B110 (right)
The B110 strut tops are different from B210 & B310 tops. They latter have a higher profile and raise the car up, so use the B110 tops. If there is nothing poking up through the hole in the strut tower,then it's "wrong" for a 1200.
Covers
TIP: You can use rubber covers from an early 90's Mazda 323 w/ electric adjustable suspension. Thse covers sits perfectly over a 1200 strut tower, even with large 1200 strut tops or camber-adjustable strut tops.
10017.jpg B310 tops
