Crossmember
Revision as of 01:16, 27 January 2013; view current revision
Category: Engine Removal And Installation
Engine mounting xmember x-member cross-member
Also see: Engine Mounts (for rubber insulators and engine brackets)
[hide]
Front Crossmember
1970-1973 1200 Crossmember (two high towers)
Rear: Late 1200 crossmember (one short tower)
Front: Early 1200 crossmember
The engine crossmember for the Datsun 1200 fits the 1971-1973 A12 engine. The A10 engine from the earlier Datsun 1000 will also bolt in. To fit a newer engine -- a 1974-up A12 or A13, A14 or A15 -- a newer crossmember may be used, or an modified motor mount brackets may be fabricated (see A-series Engine Swaps). The newer crossmember is from the 1974-up Datsun 1200 truck. Note that B210 or other crossmembers do not fit the 1200.
For engine types other than A-series, see: Engine Swaps
8487.jpgEarly A12 ute vs. Late A12 ute
Suitable for 1974-up A12, A13, A14 or A15
Modified -- newer engine mounts sit further back on right side
B110 holes are 656 mm apart, and 60mm from each other
PB110 Crossmember
L14-powered B210 uses L-series towers and mid-sump design.
See L/Z/KA/SR_Crossmember
B210 Comparison
120Y vs B110
120Y (A12-powered B210) is slighty wider, and of course has late style mounts.
North American A13/A14-powered B210 has a mid-sump crossmember, almost exactly identical to the 510 crossmember. See L/Z/KA/SR_Crossmember.
B210 holes are 760.6 mm apart and 62mm(?) from each other
Installation & Removal
See main article: Changing Crossmember
フロント サスペンシヨン メンバー
B110 & early B120
  • 54401-H3900 MEMBER ASS'Y-front suspension
    • 08194-06510 BOLT (4)
    • 32886-22000 WASHER-body bolt (8)
    • 08915-14010 WASHER-lock (4)
    • 08911-54010 NUT (4)
  • 54401-H1000 [early part, interchangable with -H3900]
    • 81-94065-1 BOLT (4)
    • 89-15140-1 WASHER-lock (4)
    • 89-11540-1 NUT (4)
Late B120
  • 54401-G1601 MEMBER ASSY-FRONT SUSPENSION 8504-
    • replaced 54401-G1600 MEMBER ASSY-FRONT SUSPENSION 7510-8503
front suspension
Measurements
Front engine crossmember bolts
  • 11 mm holes
  • 8 mm forward of strut centerline
  • 60 mm front-to-rear spacing
  • 656 mm left-to-right
  • 405 mm from rear bolt to Front core support mounting hole
Strut Tower to Strut Tower centers
  • 936 mm width
Rear Crossmember
See main article: Gearbox Mount
The transmission crossmember (gearbox crossmember) is also called the rear engine crossmember.
  • 11322-H1002 MEMBER-engine mounting, rear
