Rear brakes are traditional twin-shoe type.
The same rear brake drum was used 1967-1994. It is an 8" diameter cast iron drum, that fits 1-3/8 wide brake shoes.
Starting from Oct 1989, Sunny Trucks started using a different brake shoe -- while still using the same drum as early 1200s. These late model 1200s use a self-adjusting rear brake system. Aside from the drum, all the parts differ from earlier rear brakes.
Installation
B110 rear brake parts
Order of Wheel Cylinder shims:
Specs
- Linings (shoes)
- 35 x 4.8 x 195 mm (width x height x thickness)
- 1.378 x 0.189 x 7.68 inch (W x H x T)
- 1-3/8 x ~3/16 x ~7-11/16 inch (W x H x T)
- Total breaking area: 273 cm² (42.3 sq. in.)
- B110: (manual adjusting)
- Cylinder: 11/16" with front discs
- Cylinder: 13/16" with front drums
- B310: Drum LT-20 (auto adjusting)
- Cylinder: 13/16" (20.64 mm)
1978-1989 B120 ute used rear type Drum-LT20 with front type Drum2L20.
Finned Alloy Brake Drums
Works Racing
Finned drums like these were offered by Datsun Competition in Japan.
quote
Datsun Competition Dept supplied it's favoured teams with many experimental parts that were never sold over the counter. 1200s had alloy drums and calipers fitted as wellas the alloy diff heads from the wagons.
Also see: Brakes, Nissan Competition
Isuzu Bellett
1969-1971 Isuzu Bellet 1600 GT (model G161) featured ALFIN rear brake drums.
* 3 outer holes on face * slot for adjusting brakes on face
Datsun Z-car
Larger 9" alloy drum are used on all S30 models (1971-1978 Fairlady/240Z/260Z/280Z). All 1200 brakes are 8", so they are not a simple swap. They fit on 510 rear brakes but the backing plate needs to be ground a bit to prevent rubbing.
- The fins look like structural type, not cooling type.
- There are cast iron inserts where the brake shoes touch.
- The rest is aluminum
Nissan 43206-E4100 DRUM-BRAKE REAR * approximately 6.45 lbs. Cast Iron version * approximately 12.5 lbs * Centric 123.42002 Standard Finish * Centric 122.42002 Premium Finish specifications:RockAuto.com
Rear Brake Shoe
set (8 x 1-3/8, fits B110, B210 and B310)
- RAYBESTOS 371PG $15.36
- WAGNER PAB371 $16.52
- ACDELCO 17371B $19.02
- WAGNER BD60368 $39.89
Rear Drum Brake
- 44060-G0300 SHOE ASSY-REAR BRAKE SHOE 7510-7611
- 44060-G0325 7612-8910
- 43206-18000 DRUM BRAKE-REAR
- 44060-G1225 8910-
1989 October and newer Sunny Truck feature auto-adjust rear brakes:
Adjusters
B110 adjusters (manual, square adjustment nut)
44200-18000
1200 late star aduster (self-adjusting with star wheel)
44200-W5211 ADJUSTER ASSY-REAR BRAKE, RH
44201-W5211 ADJUSTER ASSY-REAR BRAKE, LH
Same as B310 W52 type
Others
B310 small H83 (automatic with star wheel, A12-powered models)
44200-H8300 ADJUST. ASS'Y RH
44201-H8300 ADJUST. ASS'Y LH
B310 A14/A15 adjuster assembly (automatic with star wheel)
44200-W5211 ADJUSTER ASSY-REAR BRAKES,RH
44201-W5211 ADJUSTER ASSY-REAR BRAKES,LH
* superseded 44200-W5210/44200-W5210
B310 star adjuster (A14/A15 models)
44202-W5210 SCREW RH
44203-W5210 SCREW LH
To 7302
- 13/16" diameter
- 44100-18000 ASS'Y-CYLINDER-rear wheel (13/16") B10, B110 to 7302
- Fits early B110 with front drum brakes
- 11/16" diameter
- 44100-H0500 CYLINDER ASS'Y-rear wheel (11/16")
- Fits early B110 with front disc brakes
From 7303
- 44100-H3100 CYLINDER ASS'Y-rear wheel (13/16")
- for late B110 with front drum brakes
- 44100-H3300 CYLINDER ASS'Y-rear wheel (11/16")
- for late B110 with front disc brakes
