Datsun 1200 B110/B120 * 1305 mm (51.38 in) drum-to-drum * 1295 mm (50.98") axle flange-to-flange * 1185 mm banjo housing w/o backing plates, axles or drums
Drum-to-drum Width of differential assembly:
- Datsun B10: 1239 mm (48.8 in) H145 diff. Leaf mount plates 910mm centre to centre, 65mm wide. 1120 mm banjo housing (with no axles)
- Datsun 1200 B110/B120: 1305 mm (51.38 in) drum-to-drum or 1295 mm (50.98") axle flange-to-flange
- Datsun B210/120Y: 1305 mm
- Datsun B310: 53.5 in (1360 mm)
- Datsun C20 Vanette: around 1400mm (105mm wider than a 1200)
- Datsun 510: R160 diff
- Datsun V510: 53 in
- Datsun 320 50 in H190 diff
- Datsun 521 53 in
- Datsun 521 52.25"
- Datsun 620 early: 52.875" (620 with front Kingpins, e.g. 1976)
- Datsun 620 late: 54" (620 with front Spindles, e.g. 1978)
- Datsun A10 wagon (leaf type) 49" between backing plates. Estimated 53" axle wheel flange to flange. 1190 cm overall drum to drum
- Datsun SR310/SRL310 "1500" roadster H165 axle housing length 45.75"
- Datsun SR311/SRL311 "1600" roadster H190 axle housing length 43.50"
- Datsun S110 "200SX" H165: 54 in
- Nissan S12 "200SX" H190: 57(?) in
- Nissan R31 Borg-Warner M78: 1460mm to 1465mm (57.68") rotor-to-rotor
Leaf pad centers * PL521 1116 mm leafs 60mm wide * PL620 1116 mm left 60mm wide
Axle tube flange width * PL521 1177 mm * PL620 1190 mm
Rear "Tread" @ offset * PL521 1267 mm 4Jx14 * PL620 1280 mm 4Jx14
