The engine-mounting cross-member is what Datsun calls the "front suspension member", also known as x-member (X for cross).
Also See: Engine Mounts (for rubber insulators and engine brackets)
Front Crossmember
1970-1973 1200 Crossmember (two high towers)
Rear: Late 1200 crossmember (one short tower, one high tower)
Front: Early 1200 crossmember
The engine crossmember for the Datsun 1200 fits the 1971-1973 A12 engine. The A10 engine from the earlier Datsun 1000 will also bolt in. To fit a newer engine -- a 1974-up A12 or A13, A14 or A15 -- a newer crossmember may be used, or an modified motor mount brackets may be fabricated (see A-series Engine Swaps). The newer crossmember is from the 1974-up Datsun 1200 truck. Note that B210 or other crossmembers do not fit the 1200.
For engine types other than A-series, see: Engine Swaps
Early A12 vs. Late A12 ute (suitable for 1974-up A12, A13, A14 or A15)
Modified -- newer engine mounts sit further back on right side
B110 holes are 656 mm apart, and 60mm from each other
PB110 Crossmember
L14-powered B210 uses L-series towers and mid-sump design.
See L/Z/KA/SR_Crossmember
B210 Comparison
120Y vs B110
120Y (A12-powered B210) is slighty wider, and of course has late style mounts suitable for late A12 + A14/A15.
North American A13/A14-powered B210 has a mid-sump crossmember, almost exactly identical to the 510 crossmember. See L/Z/KA/SR_Crossmember.
Crossmember Bolting Dimensions B110 656 mm X 60mm B210 760.6 mm X 62mm(?) or 80mm(?)
Installation & Removal
See main article: Changing Crossmember
Engine Swaps
Remove the crossmember uprights/horn (engine mount brackets), then you can weld different horns suitable for your engine choice.
See Engine Swaps
1200 crossmember with horns removed, suitable for swapping most engine types with front-sump oil pan.
フロント サスペンシヨン メンバー
54480M B110 & early B120 * 54401-H3900 MEMBER ASS'Y-front suspension 08194-06510 BOLT (4) 32886-22000 WASHER-body bolt (8) 08915-14010 WASHER-lock (4) 08911-54010 NUT (4) * 54401-H1000 [early part, interchangable with -H3900] 81-94065-1 BOLT (4) 32886-22000 WASHER-body bolt (8) 89-15140-1 WASHER-lock (4) 89-11540-1 NUT (4)
Late B120 * 54401-G1601 MEMBER ASSY-FRONT SUSPENSION 8504- replaced 54401-G1600 MEMBER ASSY-FRONT SUSPENSION 7510-8503
Measurements
Front engine crossmember bolts * 11 mm holes * 8 mm forward of strut centerline * 60 mm front-to-rear spacing * 656 mm left-to-right * 405 mm from rear bolt to Front core support mounting hole
Strut Tower to Strut Tower centers * 936 mm width
Rear Crossmember
See Main Article: Gearbox Mount
The transmission crossmember (gearbox crossmember) is called by Datsun the rear engine mounting member.
