The Datsun 1200 uses a Hitachi carb, model Hitachi DCG-306 (manual choke) or DCH-306 (automatic choke). This is a modern, two-barrel progessive linkage carburetor. It used bore sizes of 26/30 and venturis of 20mm (primary) and 26mm (Secondary). However, the Datsun 1200 GX models used twin Hitachi 38 sidedraft carburetors with a manual choke system.
Model Numbers
Hitachi DCx model numbers indicate the primary bore * secondary bore sizes:
Hitachi DCG306 G = manual choke | H = automatic choke 30 = 30mm secondary bore 6 = 26mm primary bore
Links
Hitachi DCx carbs were used on, among others:
* DCG286 1967-1970 Datsun B10 * #DCG306 1970-1975 Datsun B110 1973-1980 Datsun B210 1977-1983 Datsun B310 * #DCH306 1972-1973 Datsun B110 North America * 1973-1975 Honda Civic EB (1200) & EC (1500) engines * 1970-1985 Mazda 323 TC (1300) & UC (1500) engines * DCH340 1973-1980 Datsun L-series * DCF306 1981-1983 Datsun Japan B310 (starting October 1980) Australia Datsun B310 Sunny A15 * DCR306 1981-1982 Datsun USA A12A/A14/A15 (B310 USA) * DFP306 1983-1984 Nissan USA Sentra "MPG" E15 * DCZ306 1983-1988 Nissan Japan C22 1986-1987 Holden Astra E16 1982-1984 Nissan Prairie M10.E15 * DCT306 1983-1985 Ford Laser * #DFC306 1989-1994 Nissan Sunny Truck
See Also:
- Fuel System Category Page
- Carburetor Adjustment
- Carburetor Repair
- Carburetor Specifications
- Carburetor Diagnoses Diagnoses and Corrections
- Carburetor Swaps
- Weber 32/36 Carburetor
- Weber DCOE carburetor
NOTE: The B10 Datsun 1000 used a smaller carb, the Hitachi DCG-208.
DCG306
DCG is the manual-choke series.
DCH306
1973-1982 DCH is the Automatic Choke series. It had mechanical secondary linkage.
DCR306
DCH-306 with vacuum-operated secondary throttle. 1981-1982 USA models.
New features * Removable fuel bowl sight-glass * Vacuum-Secondary linkage * Externally-vented fuel bowl
DFC306
Feedback carburetor DFC306 is the carburetor on 1989-1994 JDM A12 engines. It requires a special water heated Intake Manifold and ECU control for the electronic feedback (closed-loop mixture control).
See main article: DFC306
DCK
1967-1970 Datsun 510 (1300) DCK looks similar to DCH340 with a large bolt-on glass float cover.
