Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Various early B110 Sunny Emblems (Japan)
Market Differences
- Japan market 1200s used "Datsun", "S" badges and "Sunny" badges
- Export market 1200 used "Datsun", "D" badges
Coupe grille "S" badge (on a Sunny Truck)
Export rear quarter "Datsun" mark
Colors
Most badges are simple silver color.
Sedan "S" and "D" emblems have red and blue bars:
"D" badge and early "S" Sedan badges
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
- Coupe "D" badge (rear and front)
- Coupe rear "D" badge
Trim Levels
Deluxe
Deluxe Sedan C-pillar Emblem
This is a reproduction badge from Malaysia
2-dr Sedan Deluxe Emblems (USA)
Early Sedan Deluxe Grille (Japan)
Note it doesn't use a "Deluxe" grille side emblem. All USA models are similar.
Late Sedan Deluxe Grille (Japan)
Grand Luxe
- GL = Grand Luxe
- GX = Grand Luxe, Twin Carb
Late GX Sedan (note intricate "S" grille emblem)
Late GL Sedan (note intricate "S" grille emblem)
Late coupe rear emblems (missing some?)
GL Sedan rear
What is the badge under the right taillight?
Sunny Truck & Ute
- 1971-1977 trucks used Sedan grille and emblems
- 1978-1988 trucks used Coupe-like grille with unique rectangular center emblem "D" (Export) or "S" (JDM)
- 1989-2006 trucks use a square headlight grill with Nissan emblem
- B140 LDV 1400 Bakkie uses "NISSAN" grille letters
- 2006 Bakkie front with "Nissan" oval grille emblem
Side Emblems
Sunny Truck uses sedan side emblems through 1980 at least
- Sunny
B140 Bakkie
Tailgate
- 'Nissan' and 'Sunny Long Box' stickers
1200 SSS
1200 SSS badges from Datsun New Zealand
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
- 'Sunny' badge
- 'Nissan Full Auto Matic' badge
- Steering wheel badges
Datsun 1200 S1
Datsun 1200 S1 was a Datsun of Portugal offering.
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Nissan USA and Nissan Japan are out of these parts. Some of them can be purchased from:
- Sunny Truck Shop
- Matsuoka M
- Yokohama South
See: Parts Sources
Front
Radiator grille - Center emblem
- 62312-H1626 EMBLEM SET-ORNAMENT radiator grille "D" Sedan Export
- 62312-H1026 EMBLEM SET-ORNAMENT radiator grille "S" early Sedan, Wagon
- 62312-H3125 ORNAMENT KIT-radiator grille late Sedan, Van
- 62312-H1826 SET-ORNAMENT radiator grille "D" Coupe Export
- 62312-H1825 SET-ORNAMENT radiator grille "S" early Coupe
- 62312-H4025 ORNAMENT-rad, radiator grille late Coupe
Radiator grille - side emblem (early)
Sedan Radiator Grille changed to fancy style for 1973(?) model year.
- 62330-H2026 SET-EMBLEM, radiator grille "GL" Sedan, Coupe early
- 62330-H2325 SET-EMBLEM, radiator grille "GX" Sedan (early), Coupe (early, late)
radiator grille - side emblem (late)
Sedan Radiator Grille changed to fancy style for 1972 JDM Facelift.
- 62330-H3125 EMBLEM SET-radiator grille "Deluxe" Sedan-DX
- 62330-H3325 EMBLEM SET-radiator grille "GL" Sedan, Coupe late
- 62330-H3425 EMBLEM SET-radiator grille "GX" Sedan
- 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED" Sedan, Coupe
Side
Body Side C-Pillar
- 76852-H1000 BADGE-"Deluxe" SEDAN-DX
- 76852-H2001 BADGE-"GL" SEDAN-GL
- 76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
- 76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
Body Side Rear Fender
Rear quarter-panel mounted:
- 78841-H1800 EMBLEM-"Sunny" (early '71) Coupe
- 78841-H1850 EMBLEM-"Sunny" (W/Sealing washer) Coupe
- 78842-H1800 EMBLEM-"Coupe" (early '71)
- 78842-H1850 EMBLEM-"Coupe" (W/Sealing washer)
- 78842-H2201 EMBLEM-"Coupe GL" (early '71)
- 78842-H2251 EMBLEM-"Coupe GL" (W/Sealing washer)
- 78842-H2400 EMBLEM-"Coupe GX" (early '71)
- 78842-H2450 EMBLEM-"Coupe GX" (W/Sealing washer)
- 76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon
- 76854-H1050 EMBLEM-body side "Sunny" (w/sealing washer) Sedan, Van-P, Van-DX
- 76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export
Rear
Trunk Lid Fitting (right)
Mounted on right side of trunk lid:
- 84822-H1000 EMBLEM-trunk lid "Sunny 1200" Sedan, Van-DX
- 84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID (cursive) Sedan Export
- 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID (non-cursive) COUPE Export
- 84822-H1856 EMBLEM-'DATSUN 1200' TRUNK LID (non-cursive) COUPE Export (supercedes H1806)
Trunk Lid Fitting (left)
Mounted on left side of trunk lid:
- 84823-H1000 EMBLEM-"DELUXE" Sedan, Van-DX, Van-P
- 84823-H2001 MARK-"GL" Sedan, Coupe early
- 84823-H3300 MARK-"GL" Sedan, Coupe late
- 84823-H2300 MARK-"GX" Sedan, Coupe
- 84823-H7200 EMBLEM-"GX-5 SPEED" Sedan, Coupe
- 96905-18100 LABEL-loading capacity (Van, lower left)
Rear Badge (Center)
- 79202-H1825 SET-ORNAMENT REAR PANEL COUPE "S" early
- 79202-H4025 SET-ORNAMENT REAR PANEL COUPE "S" late
- 79202-H1826 SET-ORNAMENT REAR PANEL COUPE "D" Export
Rear Badge (Transmission Mark)
These are mounted to the left of the number plate:
- 79200-H1010 MARK-"Sports" Sedan-ST,Sedan-DT,Sedan-GT, Van-DX T
- 79200-H1060 MARK-"Sports" (w/sealing washer) Sedan-ST,Sedan-DT,Sedan-GT
- 79200-H1020 MARK-"Nissan Full Automatic" early Sedan, Coupe (left trunk lid)
- 79200-H2820 MARK-"NISSAN FULL AUTO MATIC" (From '71-Apr.) Sedan, Coupe (left trunk lid)
- 79200-H3200 MARK-"NISSAN FULL AUTO MATIC" late Sedan
These are mounted on left side of trunk lid:
- 79855-N2200 MARK-"NISSAN AUTOMATIC" SEDAN, COUPE (left trunk lid) Export
Location Unknown
- 96907-G1100 LABEL-4 speed Van-Std T, Van-P T
Badge Fitting
Part Sources
Nissan USA and Nissan Japan are out of badges. Nissan Australia apparently still has some.
All the usual places, plus:
- Too Intense usually has some 1200 badges
- Aoba Auto
- Yokohama South
- Matsuoka
