Sedan grille badges![]()
Side #C-pillar trim badge and #Rear Quarter name badge![]()
Rear #Model badge, #Trim badge, and #Transmission badge![]()
Grille
Center badge & Left-side trim badge
Side
Rear Quarter
#76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export #76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon![]()
76854-H1000
Similar: PB110_Badges#Sunny_Quarter_Badge![]()
76854-H1600
76854-H1600 EMBLEM-'Datsun' BODY SIDE Sedan, Coupe Export
'Datsun' badge has same three pins as '#Sunny' badge, so it is interchangeable
C-pillar
C-pillar Emblems:
#DX #GL #GX
DX: ~70mm wide, GX: 99mm wide?, GL 100mm or 109mm wide?
All three badges have a similar pin arrangement, perhaps it is the same
#76852-H1000 BADGE-"Deluxe" SEDAN-DX
#76852-H2001 BADGE-"GL" SEDAN-GL
#76852-H2300/76853-H2300 BADGE-"GX" SEDAN-GX RH & LH
C-pillar Badge Location
C-pillar Badge 2-dr Sedan
The C-pillar badges seem to have been put in two different places on the 2-door sedan:
* 1970-1971 - down low * l972-1973 - a bit higher up
The rear fenders are the same part number, so that's not the difference.
1970 DX Press Photo - below the corner
76852-H1000 DX
76852-H1000 BADGE-"Deluxe" SEDAN-DX ~70mm diameter
76852-H2001 GL
76852-H2300 GX
76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX 76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
Right-side and left-side versions
Rear
Model
Rear model badge (Datsun or Sunny)
- Japan domestic models had 'Sunny' badges as they were sold by Sunny Shop
- Export models had 'Datsun' badges
84822-H1000
84822-H1600
84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID SEDAN
Datsun 1200 - Right Rear signature
Trim
Left Rear trim badge (Deluxe, GL or GX). Standard model (base model) has no trim badge.
Deluxe #84823-H1000 Left Rear
GL early #84823-H2001 Left Rear
GL 1972 #84823-H3300 Left Rear
GX #84823-H2300 Left Rear
GX 5-Speed 84823-H7200
Deluxe Rear
Deluxe 84823-H1000 Left Rear sedan attaches to boot lid
differs from similar looking front facelift badge
* #DELUXE grille badge: long studs for mounting through grille * DELUXE trunk badge: small pins for surface mount
GL Rear 1970-1971
GL early 84823-H2001 Left Rear sedan & coupe
GL Rear 1972
GL 1972 84823-H3300 Left Rear Facelift sedan & coupe
GX Rear
Rear GX "see-through" script. Used in Japan and South Africa markets.
84823-H2300 trim badge GX MARK 'GX' * 1970-1972 Japan * 1974-1976 South Africa
Used by coupe on Right Side
compare to #front GX badge which is not see-through but has a solid background attached
Transmission
Rear transmission badge (#Sports or #Automatic)
- 3-speed cars did not have a gearbox badge
- 4-speed cars were badged "Sports" in some markets
Sports
79200-H1020 MARK-"Sports" sedan 4-speed 79200-H1060 MARK-"Sports", with sealing washer
"Sports" badge - 4-speed Center Rear (left of license plate)
"Sports" 4-speed - to right of license plate - 1972 GL Sedan rear
Automatic
#79200-H1020 Early "Full Automatic"
79200-H2820 Late "Full Matic" from '71 April (also used by coupe), 79200-H3200 1972
N22 Coupe badge on sedan ('Nissan Automatic')
79200-H1020
Used on early Coupe
