At 2.4 liters, the KA24E or KA24DE engine is the largest widely available Nissan 4-cylinder engine (except for the newer QR25DE Engine). Not only is it larger, but has the best flowing (stock) head compared to L20B or Z20/Z22/Z24 -- it makes more HP right from the factory. It has either 4-valve heads (KA24DE) or 3-valve heads (KA24). In many countries, it is readily available and inexpensive coming out of Nissan pickups and Nissan 240SX (USA silvia S13 & S14). It will make a Datsun 1200 into a quick accelerator.
KA24E in Datsun 1200 = 14.0 second 1/4 mile
The main downside of a KA swap is that it is fairly heavy -- as heavy as an L-series engine (the KA24 is based on the L-series engines). Club members have swapped this into their 1200s with good success, reporting 14.0 second 1/4s with a stock motor (see discussion). Reportedly, a stock KA24DE can handle a fair amount of turbocharger boost, 250-300 hp without modifying the stock engine internals. The SR20DET or CA18DET can be similar modifed to a higher HP level. So the KA is a good engine for street use, but the others may be better for high-dollar supercar buildups.
KA24DE Nissan 240SX (S14) 154 HP @ 5400 RPM 160 lb-ft torque @ 4200 RPM
KA24DE Nissan D40 Frontier Pickup 143 HP @ 4300 RPM 160 lb-ft torque @ 4200 RPM
KA24E SOHC 140 hp @ 5600 RPM 152 ft-lb @ 4400 RPM
- Good aftermarket cams are available for KA24E, but not for KA24DE. So for a stock engine, use the DE. If you plan on building it up from stock levels, use the E.
Wiring up the KA is the same for a 1200 and for a Datsun 510, so here are some links to 510 swap information: Datsuns.com 510 swap info
Fiveoneoh.com:
In stock form [the KA24] produces a large amount of power and impressive torque compared to the L-series motor. It would take a very carefully built L-series motor to equal the power and torque of the KA24. It has a very fair redline and will easily spin the tires in lower gears. If you are converting from the average L20b with mikuni's or built L16/L18 you will be happily surprised.
Differences 240SX vs D22 KA24de * starter mount on the engine vs on transmission * S-Belt pulleys * position of distributor * front case: deep ribbed vs bulging * front sump vs rear sump
twistex
Donor Cars
Australia AR Market
For Australia and worldwide export RHD markets. Export means outside the Japan market.
1989-1992 U12 Pintara (australia assembled) T, Ti, and TRX trims KA24E 129hp/96kw (FWD)
Europe EL Market
For Europe and worldwide LHD markets (other than North America).
D21 KA24E D22 KA24E R20 KA24E
Japan Market
KA24E SOHC * 11044-40F00 GASKET-CYLINDER HEAD 9009-9508 M11 Prairie (Not 1988) 9701-9712 D22 Datsun
KA20DE * 11044-70F00 GASKET-CYLINDER HEAD 0104- E25 Urvan 9906- D22 Datsun 9906- F23 Atlas by UD Nissan Diesel (Volvo AB) 9906-0104 VE24 Caravan/Homy Van KA24DE DOHC * 11044-1E401 GASKET-CYLINDER HEAD 9911-0108 JU30 Basara [MPV type vehicle] 9806-0108 U30 Presage [MPV type vehicle] 9710-0107 N30 R'nessa 9305- W30 Largo 9308-9511 U13 Bluebird
* 11044-70F00 GASKET-CYLINDER HEAD 0104- E25 Caravan/Urvan/Isuzu Como 9906-0104 VE24 Caravan/Homy Van 9906- D22 Datsun
North America
* 11044-40F00 GASKET-CYLINDER HEAD ISHINO 0788-0790 * 11044-40F10 GASKET-CYLINDER HEAD MITSBISHI/REINZ 1089-0790 1988-1990 S13 240SX KA24E 1990-1992 U12 Stanza (Bluebird/Pintara) KA24E [only engine] 1989-1994 M11 Axxess CANADA (Prairie) KA24E 1990-1994 D21 Hardbody Pickup KA24E 1995-1997 D21U Hardbody Pickup KA24E
* 11044-53F00 GASKET-CYLINDER HEAD 1991-1993 S13 240SX KA24DE
* 11044-70F00 GASKET-CYLINDER HEAD 1994-1998 S14 240SX KA24DE
* 11044-3S500 GASKET-CYLINDER HEAD 1995-1997 D22U Frontier Pickup KA24DE 1999- WD22 Xterra KA24DE
* 11044-1E401 GASKET-CYLINDER HEAD 0697-0899 * 11044-9E000 GASKET-CYLINDER HEAD 0899- 1993-1997 U13U Stanza Altima 0692-0597 KA24DE 1998-2001 L30 Altima
RWD vs FWD Engine
KAs were popular from 1989 through the 2000s.
- Nissan pickups: RWD
- Nissan 240SX: RWD
- Most other Nissan cars: FWD
The differences include
- FWD: Distributor at rear of engine
- RWD: Distributor similar to L-series engine
- Different location of engine mounts
- Different accessory brackets
- Inlet manifold point opposite direction
- Transmission bell pattern differs (???) or is this urban legend?
Truck blocks are about 3/4" LONGER? they have a bellhousing flange that sticks off the back of the block an extra 3/4".
Bell Pattern
if you swap in a sr20 with a ka24 gearbox, only changing the ka bell housing to the sr bell housing, it shortens the gearbox and slots it back in the original slot, and provides some better gear ratios http://community.ratsun.net/topic/48288-1980-210/page__st__20#entry786240
11251 PLATE-ENGINE,REAR
30411-30R00 U12 KA24E.MT 30411-30R00 M11 2WD.KA24E.F5 30411-30R01 M11 4WD.KA24E.F5 30411-1E411 U13U [ring type] * superseded 30411-1E400 KA24DE.MT * superseded 30411-1E410 KA24DE.AT * superseded 30411-2B600 KA24DE 30411-30R10 U12 KA24E.AT 30411-30R10 M11 KA24E.FA 30411-2B600 L30 [ring type] 30411-40F00 S13 KA24DE.MT, KA24E.MT 30411-40F01 S13 KA24DE.MT 0194- 30411-40F11 S13 KA24DE.AT, KA24E.AT * replaces 30411-40F10 30411-40F11 S14 KA24DE.AT 30411-40F01 S14 KA24DE.MT 30411-07G00 D21/D21U/D22U 4WD KA24E/KA24DE 30411-W0402 D21/D21U 2WD.KA24E.MT.F5 30411-21000 D21/D21U/D22U KA24E.AT/KA24DE.AT 30411-F4000 WD22 30411-F4000 D22U 2WD.MT 30411-F4500 D22U AT 0798-0898 30411-F4501 D22U 4WD 0789-0898
Oil Pans
Fit a front sump oil pan and use the stock Datsun 1200 crossmember. Also fits B310 car.
- Nissan Pickup (D21 & D22) is rear sump
- Nissan Silvia 240SX (S13 & S14) is front sump
Oil pans for the single cam are swappable. Not for the dual cam though.
NOTE: oil pan bolt patterns are different.Oil pans do not interchange? Some say they do.Icehouse said:That orange 620 had a car KA in it with a truck pan. The dip stick no longer works and you have to beat the **** out of it to get it to fit [in a 510]. Besides that it works.Nismopu said:as oil pan swapping goes only car ka24e, truck ka24e, and truck ka24de(frontier) can swap oil pans. The only problem is the dipstick problem but that can be resolved with a drill.
Pickup 2WD & 4WD pans differ. But swap together with the oil dipstick tube.
Sumps do not use a traditional gasket, but use "gasket fluid":
- KP510-00150 GASKET-LIQUID
- replaced KP710-00150
Although you can purchased aftermarke pans gaskets.
KA24E 1989–1992 Nissan Pintara/Ford Corsair 1993-1996 Nissan Terrano 2 Europe
KA24DE 2000-2004 Nissan Xterra 1998-2004 Nissan Frontier 1993-2001 Nissan Altima 1991-1998 Nissan 240SX 1997-2000 Nissan R'nessa (4WD model, Japan) 1998-2001 Nissan Presage U30 (Japan) 1999-2001 Nissan Bassara U30 (Japan) 1993-1997 Nissan Bluebird U13 Isuzu COMO (Japanese: Isuzu COMO) Nissan Largo
North America Market
Aftermarket supplies traditional gaskets:
12-bolt Gasket (common) Rockauto.com
- CORTECO 16618
- VICTOR REINZ OS32151
- FEL-PRO OS30617C
- 1993-1995 Axxess (Canada)
- 240SX/Pickup/D22/Frontier/Xterra KA24E & KA24DE
14-bolt early gasket F ENGINE CODE Rockauto
- CORTECO 16627
- DNJ PG606
- VICTOR REINZ OS32152
- Fel-Pro OS30629C
- 1990-1992 Stanza
- 1990-1992 Axxess (Canada)
14-BOLT LATE (FWD 1993-2001 Altima) two-piece pan Rockauto.com
- VICTOR REINZ OS32184 (upper - pan to block)
12-bolt gasket (Late 240SX) Rockauto.com
- DNJ PG622
- VICTOR REINZ OS32110
- Fel-Pro OS30644C
- 1991-1998 240SX
Front Sump (RWD - 240SX)
0788-0790 11110-40F00 PAN ASSY-OIL KA24E S13 0790-0993 11110-53F00 PAN ASSY-OIL KA24DE S13 0294-0698 11110-53F00 PAN ASSY-OIL KA24DE S14
Front Sump (FWD - Stanza/Altima/Axxess)
0189-0394 11110-65E00 PAN ASSY-OIL KA24E M11 0789-0692 11110-65E00 PAN ASSY-OIL KA24E U12 0692-0597 11110-65E00 PAN ASSY-OIL KA24DE U13U [2-piece pan, 14-bolt] 0697-0899 11110-5B600 PAN ASSY-OIL KA24DE L30 [2-piece pan, 14-bolt] 0899- 11110-5B605 PAN ASSY-OIL KA24DE L30 [2-piece pan, 14-bolt]
Rear Sump (RWD Trucks - Pickup/Hardbody/Xterra/Pathfinder)
0192-0196 11110-86G00 PAN ASSY-OIL KA24E KA24E D21, D21U 2WD * replaced 11110-3S500 0196-0897 11110-F4000 PAN ASSY-OIL KA24E D21U 2WD 0890-0897 11110-86G06 PAN ASSY-OIL KA24E D21, D21U 4WD 0599-0700 11110-4S100 PAN ASSY-OIL KA24DE WD22 0700-0902 11110-F4500 PAN ASSY-OIL KA24DE WD22 0898-0898 11110-86G06 PAN ASSY-OIL KA24DE D22U 4WD 0701-0499 11110-F4500 PAN ASSY-OIL KA24DE D22U 2WD 0599-0700 11110-4S100 PAN ASSY-OIL KA24DE WD22 0700-0902 11110-F4500 PAN ASSY-OIL KA24DE WD22
Transmission
KA uses the same bellhousing pattern as the Z-series engines. This in turn is just like the L-series engine, but straight up unlike the slant of the L. So Z, or KA transmissions may be used. L-series transmissions are sometimes use but the slant is wrong.
Recommendation: Use a short Stumpy (26.3") transmission and H165 rear with stock 1978-1979 Datsun A10 (Stanza/510) driveshaft. Cut the stock dust shield off the driveshaft so it fits into the Stumpy all the way. You can also use a 1975-up B210 automatic driveshaft, which is a different length than the B310 auto-shaft.
Single Cam 12-valve 1988-1990 S13 240SX KA24E 1st- 3.321 2nd- 1.902 3rd- 1.308 4th- 1.000 5th- 0.759
Twin Cam 16-valve 1991-1993 S13 240SX KA24DE 1994-1998 S14 240SX KA24DE 1st- 3.321 2nd- 1.902 3rd- 1.308 4th- 1.000 5th- 0.759
KA24E and KA24DE 5-speeds ratios are the same.
Speedometer Drive
Replace the late-model Speed Sensor with a 1980-1987 gear drive. Use a speedometer cable such as a 1972 510 cable as necessary (1200 cable may or may not fit).
Starter
KA block from D21 truck uses a D21 starter, or you can use a Z-series or L-series starter.
KA block from 240SX requires a 240SX starter.
KA24E 240SX block (Japan engine)
KA24E D21 block (Mexico engine)
Rear Axle
The torque of a KA24 requires at least an H165 differential. The H145 of Datsun B110 and H150 of B210/B310 is not strong enough.
See main article: H165
Crossmember and Engine Mounts
KA can use the same crossmember as L-series or Z-series or SR-series. So treat the crossmember like any L-series swap.
See main article: L/Z/KA/SR Crossmember
Fuel Lines
Use high-pressure fuel line, e.g. from an EFI Datsun/Nissan. Use the EFI fuel line clamps. You can use the stock fuel tank, just don't let it get below 1/4.
Fuel pump I used was an Airtex E2000.
Double clamp the fuel injection fuel lines to the original metal lines.
Use an external EFI pump (280Z, Maxima, 200SX, etc). Or aftermarket like Airtex E2000.
Wiring up a KA with its stock EFI involves getting the entire donor engine-room harness, the computer and all connected wiring. Eight wires from the KA harness connect to the car's wiring -- there are lots of wires in the new engine harness, but you only need to identify eight of them to connect up. Use severals relays and new fuses. It's a chore but you'll have OEM EFI -- power and economy both with awesome smoothness. A CAN/AM Box (engine swap wiring distribution box) makes EFI wiring swaps easier -- and easier to troubleshoot (though not required). Wiring up the KA EFI is the same for a 1200 and for a Datsun 510, so see Ratsun article How to wire a KA, CA, SR, and VG into anything.
Alternatively, get a carby manifold and go with carbs and the stock 1200 wiring can be adapted (oil pressure sensor, temp sensor, distributor feed). It'll be a rowdy powerful sounding engine with none of that high tech stuff!
A third alternative, particularly useful if you didn't get the KA24 wiring harness/ECU is to use the 200SX EFI -- see article "4-wire EFI".
And of course for the tinkerers or serious modders, you can use an aftermarket ECU such as the MegaSquirt or one of many other brands. If keeping the engine relatively stock, there is no reason to use other than the stock ECU.
Ignition Switch
Newer Datsun ignition switches fit the 1200 (large size) but work slightly different. When the key is in START position, the original switches cut power to IGN. The new switch retain power to IGN. Some say to use this switch. However if wired correctly this is not needed.
The two Ignition Switch wires to tap into and connect to the EFI relays are:
- IGN (B/W wire) You can tap into this at the switch, at the existing Coil wiring in the original vehicle engine room harness, or anywhere else this wire exists.
- START B/Y wiree. You can tap into this at the switch, at the existing Starter wiring in the original vehicle engine room harness, at the starter 'S' terminal, or anywhere else this wire exists. Connect this via a 10A fuse to the START ECU signal wire in the harness.
It is recommended to solder a new larger B/Y wire from the ignition switch to the starter, instead of the original small-gauge B/Y for the 1kw oringal starter.
Alternator
KA alternators are wired like any Hitachi LR Alternator, but do not use the familiar T-connector of the older alternators.
- Connect the alternator thick white wire to battery positive
- Connect W/R wire from alternator to dash for charge light. Can use the existing wire in the original Datsun 1200 engine room harness
- Optional, but recommended. Solder a 100k resistor across the CHG lamp circuit on the back of the gauge cluster. This will allow the alterator to keep charging even if the lamp burns out.
S-BELT (serpentine)
LR180-715 23100-30R00 * S13 USA 0788-0790 LR180 23100-53F00 * S13 USA 0790- LR180-742/742B/742C 23100-70F00 * S14 USA KA24DE LR190-724 23100-70F05 * S14 USA KA24DE 0294-0796 for SE projector fog lamp option
Starter
Wire the new starter same as the original Datsun 1200 starter:
- Wire from Ignition Switch to S terminal on starter solenoid
- Ensure large Ground wire exists from engine block to body. See Battery Wiring
- Thick Positive wire from battery to starter motor
Battery
If you relocate the battery to the trunk/boot:
- Connect large gauge cable from Battery Positive to starter motor
- Connect large gauge cable from Battery Negative to engine block. Resist the temptation to simply connect the battery to the sheet metal. That may work but running a line to the engine is more reliable.
- run large cable from engine to chassis ground.
Swap Notes
You can remove these from the engine and wiring harness and still have the engine function (seemingly) great:
- Secondary (post-convertor) O2 sensor
- CAS (Crank angle sensor, located on transmission bell housing S14 models)
- IAT (Intake air temp sensor, usually located in intake tube or air box)
- EGR system and associated sensors
- transmission sensor/switches (except reverse switch, if you want your lights to work)
- emissions control sensors and actuators
These are needed for the stock EFI system:
- TPS (Throttle position sensor)
- Water temp sensor
- Knock sensor
- MAF sensor
- Injectors
- Distributor/coil
- Primary oxygen sensor
- IAC (Idle control motor)
- Fast idle valve
- Fuel pump
Belts
Accessory Belts: S14 comes with power steering. For a delete option see ka-t.org power steering delete
Fuel Supply
See Fuel Injection, section "Fuel Tank". Feed and return lines should be 5/16" (8mm) instead of the stock Datsun 1200 1/4" (6mm) lines.
Exhaust
Use the stock cast iron exhaust manifold and have a muffler shop fit 2.5" exhaust tubing and muffler.
Unknown if any headers fit the 1200 chassis.
Sway Bar
Sway-bar should fit fine with no interference.
Radiator
150 HP requires a larger radiator than the stock 1200 radiator.
See Radiator#Upgrades. The larger B310 radiator may be large enough for KA engine, or the aluminum Rabbit radiator.
Fit a good electric fan and remove the engine fan to gain room in the engine compartment.
Steering Linkage
Steering linkage is fine with cast iron exhaust manifold and the front-sump oil pan.
Carbureted
1. Fit L-series distributor (RWD pickup blocks) or EDIS crank-trigger (FWD blocks). Replace the KA oil pump shaft and distributor with those from an L-series engine. Make a hold down bracket. Or the L20B distributor mount fits into the Pickup KA24E front cover if you drill and tap two new holes.
2. Buy or fabricate carburetor manifolds
- Nismo
- aftermarket NOS
- Or make your own
