Datsun model series 810 was produced 1976-1979. In some countries it was marketed as "Bluebird", in others as "200B" or "180B" or "160B" depending on the engine fitted.
810 rotors are solid discs. Vented discs like the 280ZX swap are superior for fade-resistant, which is important for racing and for mountain driving.
NOTE: For the Japan market 810, front drum brakes were used for Van Deluxe, and for all LPG models (810.P with L18P engine, 811.P with Z18P engine).
245 mm
4-cylinder 810s used same 245 mm brake rotors as B310 Sunny. Most 810 SSS used this too.
Annette 20, N20 (AN20) Type
40207 40206-U6700 Annette N20 (AN20) 245 mm rotor * Short Body, except SSS ES model Also from: * A10 (Stanza) * B210 A14 * B310 A14/A15
See B310 Strut Swap and Stanza Strut Swap
253 MM
Annette 22 N22 (AN22) Type
253.5 (254) mm 40206-U7600 * Long Nose models (including 4-cylinder) except EF and EL * SSS ES model * 200SX USA S110 1980-1983 * Centric 121.42015 Height: 47.6 mm Thickness new: 12.5 mm Thickness min: 11.5 mm weight 4.7 kg 4 x 95mm bolt circle
Caliper
Pad Kit 41000K 41060-U2726/41060-U2727 41060-U3426
257 MM
257 mm * 200B Australia early? * 180B Europe Thickness: 26 mm Height: 52.2 mm Minimum thickness: 24 mm Centering diameter: 68 mm 5-bolt * 40206-9C100/40206-9C101, 40206-Y9502 * Ferodo DDF722
270 MM
N34 type was used G6EL and G6EF (EFI) six-cylinder 810s, and all North American 810s.
270 mm (10.62 inch) Nissan part number 40206-U8700 * C230 Nissan Laurel * G810 L24 or L20 * Japan: Bluebird 2000G6 2 liter [L20S, L20E] Height 48 mm Nominal thickness 12.5 mm Min thickness 10.5 mm Hub hole: 73 mm Bolt circle: 4 x 95 mm (to hub) Type: Bolts behind the hub (same as Datsun 1200) Weight: 13.7 lbs (compare to 1200 at 5.9 lbs) * Centric 121.42009 * Aimco 3127 * Wagner BD97318 * Raybestos 9252R/9252 270mm discs use Annette 34 calipers * dual-piston sliding yoke (same as Datsun 1200 but larger) * Bore: 54 mm (2.12 inch) * Pad: 10x .01140 41000-U8700 AN34 caliper, RH 41010-U8700 AN34 caliper, LH * Centric 141.42010,141.42009 * Raybestos FRC3030, FRC3029 * Beck/Arnley 0760056 * Wagner CR105925 Also fits Caliper with yoke: * 200SX S110 1980-1983 Caliper w/o yoke: * 620 1978-1979 * 720 1980-1983 to 11/82
Brake pads for 270 mm Pad Kit 41000K 41060-U8725 77.7 x 69.2 x 15.5 mm FMSI TYPE: D57, D114, D161, D173, D238, D244, D246 * Centric 102.01140 * Beck/Arnley 0861175, 0821175 * 41060-B9525/41060-B9527 Datsun 720 USA * 41060-E4125 * 41060-N3026, 41060-N3036, 41060-N4426, 41060-N8525 * 41060-U8725
