Sunny model series B110 has a McPherson strut front suspension. This is lighter, less expensive, and allows more engine compartment room than the previous B10 model's double A-arm front suspension. In the rear, conventional leaf Springs and and a Live axle are fitted. Both are lightweight systems well matched to the size and weight of the Datsun 1200 car. The heavier next-generation Sunny B210 use a medium-duty duty front suspension appropriated from the Datsun 610. This means that most B210 front suspension, front axle and front brake parts do not interchange with B110.
In the Nissan parts catalog, the Brakes and Front Axle (strut, hub) are in different section. The Ball joint assembly includes the Knuckle Arm, however most part suppliers sell the ball joint by itself.
Also see: Strut
Suspension Parts
Here are the suspension parts:
NOTE: All parts are identical for 1971-1973 models (including sedan, coupe, wagon and truck). GX bar is different.
- 54401-H3900 (formerly 54401-H1000) Front Suspension Member assembly (engine crossmember)
- 54110-H1060 Transverse link ass'y R.H (formerly H1000)
- 54111-H1060 Transverse link ass'y L.H (formerly H1000)
- 54131-H1000 tranverse link bushing
- 40160-H1000 Lower Ball joint ass'y
- 54470-H1000 Tension Rod R.H
- 54471-H1000 Tension Rod L.H
- 54476-H1001 Tension rod bushing (2 per side)
- 54611-H1002 front stabilizer torsion bar (except GX)
- 54611-H2300 front stabilizer torsion bar (GX)
- 56125-18100 stabilizer link rubber bushings (4 per side)
- 54618-H2300 stabilizer connecting link (formerly H1000)
- 54616-H1001 bar to body bracket (formerly H1000)
- 54617-H1000 bar to body bushing(except GX)
- 54617-H2300 bar to body bushing(GX)
1974-up truck
- 54401-G1600 Front Suspension Member assembly (engine crossmember) to 8503
- 54401-G1601 Front Suspension Member assembly (fits earlier) from 8504
- 54110-H7400 Transverse link ass'y R.H -7711
- 54110-H8500 Transverse link ass'y R.H 7712-8503
- 54110-W5851 Transverse link ass'y R.H 8504-
- 54470-H7200 Tension rod R.H to 7910 (B210 style?)
- 54470-H8500 Tension rod R.H from 7911 (B310 style?)
- 54476-H1001 Tension rod bushing to 7910 (2 per side)
- 54476-W5000 Tension rod bushing from 7911 (2 per side) (B310/A10 style?)
- 54611-H1002 front stabilizer torsion bar -7907
- 54611-G1600 front stabilizer torsion bar 7908-8503
- 54611-G1600 front stabilizer torsion bar 8504-
- 54617-H1001 bar to body bushing
