Intake Manifold
Revision as of 10:32, 15 February 2016; view current revision
Categories: Engine Mechanical | Manifold
Datsun 1200 was equipped with a round-port inlet manifold. USA got one with accessories fitings, while Japan, Canada and other countries got a plain intake manifold. For other A-series engines, manifolds differ by country and year.
Gasket Bolts
Yoke washers
08911-10810 NUT CYLINDER HEAD TO MANIFOLD (9)
08915-13810 WASHER-LOCK (5) for upper studs
14037-32200 YOKE-MANIFOLD (4) [large washers]
The "yoke" is a special washer with non-parallel faces.
M8 studs & nuts.
full
full
Datsun 1200
Datsun 1200 was equpped with a round-port, dry, original bolt-pattern, inlet manifold. It looks like the Datsun 1000 manifold but it slanted 2 degrees different.
Plain type: only fittings are for PCV and one vacuum port (seen here with a plug)
Intake and exhaust manifold are bolted together (with Heat Riser in between)
A12 GX Engine
See A12 GX Engine for details on the GX intake twin-SU manifold.
Datsun 1200 SSS
Datsun 1200 SSS was fitted with a New-Zealand built manifold and twin Dellorto carburetors.
Will not suit an A14 or A15 as those engines have oval inlet ports. These suit SSS motors with round inlet ports.
The inlet manifolds were Kiwi cast by Dennis Marwood to get them to match the head ports it is necessary to drill the mounting holes oversize to lift the manifold upwards to locate it better.
As of 2002, Autoquip Marketing in Auckland was still selling the manifolds.
Fitment with Exhaust Manifold
A12 intake and exhaust manifolds are a matched set -- they bolt together.
Fitment With Extractors
When using a tubular exhaust header (extractors) you can unbolt the intake from the exhaust manifold. Then fit shorter bolts to hold the Heat Riser block-off plate on. The A12 intake manifold comes with a block-off plate standard. This will fit over at least some big-tube header/extractors.
Most USA manifolds came with extra fittings, while Japan, Canada and other countries got a plain manifold.
14003-H3900 with bolt holes for accessories
14003-H3901 MANIFOLD-INTAKE A12,AUTO 0771-
14003-H3900 MANIFOLD-INTAKE A12,MANUAL 0771-
14003-H1901 MANIFOLD-INTAKE A12,CALIFORNIA 0671-0771
14003-H1900 MANIFOLD-INTAKE A12 EXHAUST -0571
14003-H1000 MANIFOLD-INTAKE A12 CRANK [Canada]
INTAKE GASKET
14035-K7700 GASKET-MANIFOLD TO CYLINDER HEAD
14035-18000 GASKET-MANIFOLD TO CYLINDER HEAD
OTHER
14005-18001 GASKET-INTAKE TO EXHAUT MANIFOLD
* 08216-62210 STUD FIXING CARBURETOR 4
* 08110-63210 BOLT INTAKE TO EXHAUT MANIFOLD 2
* 01111-00032 BOLT
* 08915-13610 WASHER-LOCK INTAKE TO EXHAUT MANIFOLD 3
* 08911-10810 NUT CYLINDER HEAD TO MANIFOLD 9
* 08915-13810 WASHER-LOCK 5
  • 14037-32200 YOKE-MANIFOLD 4
Gasket
* Datsun B110 single-carb
See main article: 14035
* Round Port, No water ports, Original bolt pattern
* Round Port, No water ports, New bolt pattern
* Round Port, Water Ports,    New bolt pattern
* Large Oval Port, Wet Intake
* Small oval port, Siamese ports, No water ports
* Oval Port, No Water Ports
* Oval Port, Water Ports
* Medium Oval Port, EFI Head
* Medium Oval Port, non-EFI
Manifold Selection
When selecting an intake manifold for your A-series engine, keep these fitment factors in mind:
* Port shape (round, regular oval, large oval)
* Bolt Pattern (new style vs old style)
* Water Ports for dry head vs wet head
* Attached exhaust manifold vs non-attached
Port Shape
All Datsun 1200 came with round port cylinder head (except: Datsun 1200 GX, which came with Large Oval ports). Most A14/A15 came with regular-size oval ports. Other A-series engines came with small oval port heads.
Oval Port Comparo (Extra Large, Regular, Water Port, Small Oval)
Bolt Pattern
New bolt-pattern VS original (B110) bolt-pattern. The new pattern started with the A13/A14 engine, but eventually all the A12s converted to the new style.
Water Ports
See main article: Water Ports
Detached Manifold
Non-attaching exhaust manifold
If fitting a detached Exhaust Manifold, the bottom of the intake will hit the exhaust manifold. In this case you can either 1) source a different, more compatible intake or 2) grind the bottom for clearance and weld the opening shut.
Types
H19
H19 casting
B210 Early
From the Nov 1976 JDM catalog
*Single Carb
* Gasket 14035-18000
14003-H1900 M/T w/o Mastervac
14003-H5101 A/T, M/T with Mastervac
*Twin Carb (A12T)
* Gasket 14035-H2300
14003-H5731 A12T
14003-H5732 A12T from '75-3 ^H5731
B210 Late
From the B210 Japanese Domestic Model parts catalog (Jul 1978)
1975 VB210 manifold (Showa 50)
th_S50_VB210_manifold-a.jpg th_S50_VB210_manifold-b.jpg th_S50_VB210_manifold-c.jpg
A12
14003-H5101 V
A12S
14003-H7400 S,K
A14
14003-H7200 V
14003-H7860 V
A14T
14003-M2450 A14T
F10
2nd generation Nissan Cherry.
Canada 1977 manifold A14
Canada 1978 manifold A14
B120
  • 14003-H1000 MANIFOLD-intake 1971-1974 [old bolt pattern, D-shaped heater gasket]
  • 14003-H5111 MANIFOLD-INTAKE 7510-7803 [old bolt pattern, triangular heater gasket]
  • 14003-H8110 MANIFOLD-INTAKE 7804-7907
  • 14003-G2561 MANIFOLD-INTAKE 7908-8109 [new bolt pattern, D-shaped heater gasket]
  • 14003-G2600 MANIFOLD-INTAKE 8110-8910
  • 14001-95W00 MANIFOLD-INTAKE 8910- [late-model water-heated carb]
Late Sunny Truck
1989-up B122 manifold: Round-port, wet style, new bolt-pattern, with extended-length carb flange.
th_14001-95W00-1.jpg th_14001-95W00-2.jpg th_14001-95W00-3.jpg th_14001-95W00-4.jpg th_14001-95W00-5.jpg
New-bolt pattern (like an A14):
B310
14003-H8950 A14 -7909
14003-W7550 A14 7910-8010
A14 post
North America
USA A14/A15 FEDERAL (except California)
14003-H9500 MANIFOLD-INTAKE FED 0880- 0 14003-H9950 [1981-1982 small oval]
14003-H9950 MANIFOLD-INTAKE FED -0780 2 14003-H9900
* 14003-H9900 MANIFOLD-INTAKE FED 0879- 0 14003-H9100
14003-H9100 MANIFOLD-INTAKE FED (EXC KFU) 0878-0779 0 14003-H7200
14003-H7202 MANIFOLD-INTAKE FED (EXC KFU) replaced 14003-H7200
14003-H7200 MANIFOLD-INTAKE FED (EXC KFU)
FED KFU (A14 round port)
wet & dry types
14003-H7400 MANIFOLD-INTAKE FED(KFU) -0778
14003-H9160 MANIFOLD-INTAKE FED(KFU) replaced 14003-H7400
USA CALIFORNIA A14/A15
14003-H9160 MANIFOLD-INTAKE CAL A14 replaced 14003-H7400
14003-H7400 MANIFOLD-INTAKE CAL A14 -0778
14003-H9550 MANIFOLD-INTAKE CAL 0678-0779
14003-H9950 MANIFOLD-INTAKE CAL -0780 superceeded 14003-H9900
* 14003-H9900 MANIFOLD-INTAKE CAL 0879- replaced 14003-H9160
CANADA A14/A15
14003-H7400 MANIFOLD-INTAKE A14 CAN -0778
14003-H9160 MANIFOLD-INTAKE CAN 0879-
Vanette
Dry Manifold
C120 A12 7810-
14003-H8110 Looks like USA B110
C120 A14
14003-H7861 7810-7906
14003-W8600 7907-8105
Water Heated Manifold
C120 7901-8706 A15
* 14003-H8850 > 14003-H8805
* water heated manifold (old style carburetor)
Water Heated Carburetor
G51 manifold - water heated carburetor. Very similar to the A12 manifold 14001-95W00 except for port shape
C22 A15 14003-G5250 8605-9304 water heated carburetor, EUR w/EGR, GEN LHD w/EGR welch plug
N10
Datsun Cherry EUR
A10 14003-M3700 7808-8107
* looks like B10 manifold
A12 [14003-M3700] 7808-8107
    14003-M5510 7808-8107 SWE
A14 14003-M8900 8008-8107
* dry manifold
LDV
Late 1400 bakkie manifold appear to be same as late Sunny Truck.
Custom/Aftermarket Manifold
Weber
A12 40 DCOE X1 99003.822 $165 @ Pierce Manifolds
A12 40 DCOE X2 99003.110 $250 @ Pierce Manifolds
A14 40 DCOE X1 99003.821 $215 @ Pierce Manifolds
Suppliers
  • TWM
  • Lynx single (PN M041) and dual (PN M042) DCOE/DHLA manifolds, dual SU manifold (M137)
  • TWM Induction intakes, carbs, etc
  • Ramflo
  • Lynx manifolds & Kay C (KC) adapter, Ramflo filters and Weber carbs
  • Ram intake downdraft manifold
  • Cannon Industries, apparently no longer in business
    5611 208th Ave S.W.
    Lynnwood, WA 98036
  • Redline Auto (Australia) makes single and dual DCOE manifolds and linkage, for A12 through A15 motors.
  • Same parts are available from Holley (Australia).
  • Stewart Wilkins GX manifold - only $260 AUD
  • eBay
CUSTOM MANIFOLDS
Steel manifold is difficult to make. You need to form steel to ovals to round to tapered out. When used with a turbocharger, Steel won't break and would be ported to your cylinder head.
  • "Mammi Motors" on the Peninsula in Victoria (40 mins from Melbourne).
    Ph: (03) 5977 7973
    • Steel manifold for maybe $250 for Weber 40s or 45s. ** They also do nice head work for around $300 which includes porting and 1600 exhaust valves
Aftermarket manifold finish quality can be really poor so check for flat flanges, port overlap. See Jason's Weber page.
Single Sidedraughts
Cannon
Cannon manifolds are very low profile, so you can fit inlet trumpets or a tall air cleaner.
821 single DCOE oval port (A14/A15)
Thickness 2-13/16 to 2-10/16 inch
822 single-DCOE round port A12 (old bolt pattern)
Lynx
  • M041 MANIF DATSUN 1200 1 X DCOE/DHLA
  • M042 MANIF DATSUN 1200 2 X HS4 SU
  • M137 MANIF DATSUN 1200 2 X HS4 SU
D1000
Round port, pre-emission (no provision for PCV valve) for SU or Hitachi sidedraughts.
D1200 SU
Lynx D1200 for A12 engine, twin SU HS4 pattern, round port with crossover design.
Does this exist?
These do:
Lynx M042 MANIF DATSUN 1200 2 X HS4 SU
Lynx M137 MANIF DATSUN 1200 2 X HS4 SU
D1200 Single
Lynx D1200 for A12 engine, single-DCOE pattern, round port with crossover design.
Crossover puts the runners in firing order
click for larger pic
D1200 Twin
Lynx D1200 (model M041) Round port for Twin Weber DCOE 40 style.
SSS
Oval port twin DCOE manifold marked 'SSS'. This is not for the Datsun 1200 SSS model which had round port heads.
Redline Australia
Redline Performance/Hardiman: http://www.redlineauto.com.au
12-18 Manifold 2 X DCOE fit Datsun A14/A15
12-3060 Manifold Datsun 1 & 1.2L 2XDCOE Weber
12-3114 MANIFOLD DATSUN 120Y 1x40DCOE WEB
Rowland
Out of South Africa, Rowland made manifolds for the A14. http://www.manifolds.co.za
M028: Nissan 1400 36 Weber DCD down draught
* use gasket 14035-H7200
M030: Nissan 1400 Twin sidedraugt
Warneford
EFI
For EFI manifolds, see EFI Manifold
