General specifications for Datsun 1200 are listed here.
For other parts and systems use the search box
<-- Search box
USA 1972 Owners manual (see pages 39-40 for General Specifications):
- Wheelbase: 90.6 inch (2,300 mm) ALL, including truck
- Overall length: 150.8 inch (3,830 mm) Sedan & Coupe
- Overall width:
- Overall height:
- Track, front:
- Track, rear:
- Turning radius:
- Ground clearance: 6.7 inch (170 mm) Sedan & Coupe
- Engine:
- Clutch:
- Transmission, manual:
- Transmission, automatic:
- Rear Axle:
- Suspension:
- Brakes:
- Steering Gearbox: Recirculating ball type
- Wheel and Tire: 6.00-12-4PR, 4J Rim
Capacities
- Fuel tank:
- Cooling System:
- Oil pan:
- Oil filter:
- Transmission case, manual:
- Transmission case, automatic:
- Differential case:
- Engine number:
- Chassis Identification number:
Engine Specifications
- Displacment:
- Bore & Stroke:
- Compression Ratio:
- Spark plugs firing order: 1-3-4-2 (same as most four-cylinder engines)
- Dwell angle at idle:
- Ignition Timing:
- Idling speed:
- Spark plug gap:
- Distributor point gap:
- Valve Clearance (hot):
- Belt tension:
