Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Also see: Badge Part Numbers
Genuine Nissan badges are metal or plastic depending on the year made.
Various early B110 Sunny Emblems (Japan)
1972 JDM Facelift emblems
Badge Installation
Most Datsun badges are fastened via Hole-barrel nuts.
1. Two or three simple holes are drilled 2. Round inserts are pushed into the holes 3. The badge is pushed into the inserts
The inserts may be stuck to the old badge, you can see them on this GL badge:
The nuts are not sold separately, but can be found on wrecker cars or old broken badges.
Emblem/Trim Retainers (Hole Stud Tubular Nut/Panel Tubular Speed Nut)
? Tubular Speed Nut 1/8" Stud. #018 Fits 5/32" to .161" Hole. 0.012-0.018" Panel Thickness ?
Market Differences
- Japan market 1200s used "Sunny" & "S" badges
- Export market 1200 used "Datsun", "D" badges
Colors
Most badges, especially the script ones, are simple silver color.
Sedan "S" and "D" grille emblems have red and blue bars:
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
Some are faded after all this time:
Most are faded to no color after 40 years:
Coupe
See main article: Coupe Badges
Sedan
Grille
Center Ornament
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
Grille Left Side Badge
NOTE: there are 3 types of GX badges:top: early GX grille middle: 1972 GX grille bottom: GX rear (see through script)
DX early - no trim badge on grille
DX 1972 - 62330-H3125 EMBLEM SET-radiator grille "DELUXE"
compare to rear badge
84823-H1000
GL early - 62330-H2026
screw-on type. Rear GL badge is push-in type.
GL 1972 - 62330-H3325 EMBLEM SET-radiator grille "GL"
compare to early rectangular badge
GX early - 62330-H2325 COUPE, SEDAN
If the mounting bracket is lost, a length of plumbers tape will do the job (metal strapping tape)
GX 1972 - 62330-H3425 EMBLEM SET-radiator grille "GX"
compare to early wide badge
or rear see-through badge
GX5 - 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
Side
Rear Quarter
C-pillar
C-pillar Emblem
GL
DX: 80mm wide? , GX: 99mm wide?, GL 109mm wide?
C-pillar Badge Location
1977 GX
1970? press photo
C-pillar Badge 2-dr Sedan
The C-pillar badges seem to have been put in two different places:
* 1970-1971 - down low * l972-1973 - a bit higher up
The rear fenders are the same part number, so that's not the difference.
1970 DX Press Photo - below the corner
1971 - below the corner
1973 at the corner
1973 at the corner
Rear
Model
Trim
Left Rear Deluxe - 84823-H1000
differs from similar looking front facelift badge
Left Rear GL - 84823-H2001 early
Left Rear GL - 1972 - 84823-H3300
Left Rear GX 84823-H2300
"see-through" script (compare to front GX badges which have a background attached)
GX 5-Speed 84823-H7200
Sports
4-speed Center Rear (left of license plate)
Sports badge
"Sports" 4-speed - to right of license plate
1972 GL Sedan rear
Automatic
Early "Full Automatic" 79200-H1020
Late "Full Matic" 79200-H2820 from '71 April (also used by coupe), 79200-H3200 1972
non-1200 'Nissan Matic' is blue 84821-U0300
Coupe badge on sedan ('Nissan Automatic')
keywords: エンブレム
Sunny Truck & Ute
See main article: Truck Badges
Van
Van uses the same badges as Sedan:
* Grille 'S' ornament (including facelift version) * No grille trim badges (Deluxe, GL or GX) * 'Sunny' rear quarter badge * 'Sunny 1200' rear badge * 'Deluxe' rear badge (DX only, early version) * 'Sports' rear badge (DX 4-speed only)
In addition, Van used these unique badges:
96905-18100 LABEL-loading capacity '400 kg' * lower left side
96907-G1100 LABEL-4 speed Van-Std T, Van-P T * middle height right side
'VAN' badge - Portugal![]()
Custom
'DATSUN 1200' coupe badge + Portuguese 'VAN' badge
GX
1200 SSS
The Datsun 1200 SSS sedan was a product from Datsun New Zealand.
SSS left-side grille emblem
Same as 62800-N0401 MARK-radiator grille "SSS" Datsun 510 Coupe KPK, Sedan PTK
82858-U0800 - same as 610/180B SSS
- SSS badge on the glove box. Anyone have a photo?
Non-1200 SSS
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
910 Bluebird SSS 62892-W3500 Front Grille Mark 8201-8907 [triangular 'SSS']![]()
62896-W1200 Front Mark 7910-8112 [octagonal 'SSS']
810 Bluebird SSS [Sedan:62396-U7625, Coupe:62396-U8325]
62397-U7600 'SSS' ~120 mm long
411 SSS rear badge
:post
:full
:full
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
- 'Sunny' badge
- 'Nissan Full Auto Matic' badge
- Steering wheel badges
Datsun 1200 S1
The Datsun 1200 S1 2-door sedan was a Datsun of Portugal offering.
See main article: Datsun 1200 S1
- S1 grille badge
- S1 boot badge, fitted to left of the right taillight
Custom
Grille-fixed Sedan boot badge 'Datsun1200' with the 1200 painted red
Germany
'DATSUN' rear side 'DATSUN 1200' boot right side
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Part Sources
* Nissan USA and Nissan Japan are out of badges * Nissan Australia apparently still has some. * eBay has them from time to time * Yahoo Auctions Japan always has some * Too Intense usually has some 1200 badges * Aoba Auto * South Yokohama * Matsuoka
Be careful of the quality:
Malaysia repro vs Nissan item: This reproduction badge has has poor chroming and what appears to be hand-painted coloring that doesn't exactly stay within the lines. However, other reproduction badges may be high quality.
エンブレム バッジ マーク
