Dellorto
Revision as of 04:48, 8 March 2017; view current revision
Categories: Engine Modifications | Fuel System
Dell'Orto carburetors from Italy their DLHA series were fitted to the Datsun 1200 SSS model. Dellorto made other types, but the DHLA fit the common Weber DCOE carburetor intake manifolds.
[hide]
Also See
* Choosing A Carburetor
Dellorto DHLA are similar to the Weber DCOE carburetors, but have their own unique parts and some say a better design and look better.
15946.jpgAlbum 15946
5468.jpgAlbum 5468 8181.jpgAlbum 8181
http://www.dellorto.com
The DHLA & DRLA carburettors are widely believed to be the most sophisticated carburettors of their type, prompting David Vizzard to say in Auto Performance magazine, “Dell’Ortos produce truly excellent results...On engines where atomisation is a premium requirement, Dell’Ortos are superior to everything”.
174_4de174af193c2.jpg 2965.jpgAlbum 2965
The last Dellortos were made for the Lotus Esprit Turbo. Production ceased in 1992 due to lowered demand for carburetors in the face of EFI.
The great thing about these carbs is that the jets are externally accessible, even when the air filter is on. This makes jet changes at the racetrack a snap.
Dellorto DHLA uses the same Intake Manifold as Weber DCOE carburetor, or Mikuni PHH.
8064.jpgAlbum 8064 10038.jpgAlbum 10038
See Also:
* Tuning Dellorto DHLA carburettors
* Selection and tuning of Dellorto DHLA carburettors - section "Setting the Idle and slow running"
DHLA idle mixture screws
11740.jpgAlbum 11740 11739.jpgAlbum 11739 8675.jpgAlbum 8675
Single Or Twin
A twin setup has a huge advantage over the single: ITB (individual throttle bores). 2 sidedrafts = 4 throttles.
See Choosing A Carburetor: Single or Twin?
Intake Manifold
Weber DCOE, Dellorto DHLA and Mikuni/Solex PHH use the same manifolds. Single or Twin manifolds are available, for round-port or oval-port A-series engines.
Vacuum Connection
Drill & tap the boss for a tube fitting. Can be used for power brakes, distributor vacuum advance.
14778.jpgAlbum 14778
Air Filter
Many use simple screens over the carburetor, which keep large objects out of the engine. This (or no screen) provides the fullest "awesome sidedraft sound", but at the expense of increased engine wear.
For filtering, the easiest thing is sock filters, but all sorts of regular and remote filter can be used.
LHD Fitment
Space for twin sidedrafts on LHD 1200s is limited because the brake master cylinder is on the carburetor side of the engine.
Heat Shield
Carb heat plate キャブ ヒート プレート
25550.jpgAlbum 25550
Adjustment
Idle Speed and Mixture Adjustment
  1. Warm engine fully
  2. Adjust curb idle speed to 900 rpm
  3. Slowly turn mixture screw out until the engine speeds up, then keep turning out until engine starts to slow down slightly (overly rich)
  4. Screw in (clockwise) until engine slows down (lean). Turn back out til it runs fastest (Best Lean)
  5. Repeat for second barrel of the carburetor
  6. If a twin-carb setup, repeat for the second carburetor
To get a 'feel' for this adjustment, turn the screw by half turns clockwise and anticlockwise till you hear the engine speed up and slow down. Then fine turn with 1/4 turns. Do this repeatedly until you are confident of the results.
Linkage
5212.jpgAlbum 5212 9863.jpgAlbum 9863
Linkage depends in part on the manifold you use. Does it have bolt-bosses for linkage? Or does it have built-in linkage bar?
Side Pull
Tomei manifold Side Pull. Nismo/Tomei manifold have built-in bar towers and use a large diameter cross bar
8988.jpgAlbum 8988
Center Pull
Center Pull - Need the floating lever for the carburetors. In essence, a single throttle lever, with its own balance screw
Center Pull needs only one carb-pull, eliminating the separate throttle adjustments. The center floating linka has its own balance screw
15692.jpgAlbum 15692 15691.jpgAlbum 15691
Single Carb Linkage
For bolt-style manifolds
20641.jpgAlbum 20641
Quadrant
Fan lever - Harada Shosho company
27290.jpgAlbum 27290
Nissan cable quadrant
11496.jpgAlbum 11496 11497.jpgAlbum 11497 11368.jpgAlbum 11368
Generic cable bracket
11506.jpgAlbum 11506
Throttle Lever
Universal carby throttle lever
556.gifAlbum 556
Source
Dellorto DHLA may be purchased from Eurocarb at http://www.dellorto.com
Also can be sourced by parting out Italian cars.
12881.jpgAlbum 12881
Selection & Sizing
As with any carburetor, the single most important specification is the venturi (choke) size -- not the barrell size. So a 40 or 45 is not the question. The question is which choke size should be used.
See main article: Carburetor Sizing
For a stock A12, 28 mm is the correct choke size. Which the DHLA series, you can use either 40s or 45s -- a wide variety of venturis are available for both.
Tuning
Tuning any carburetor is mythically difficult. However, DHLA is no more complicated than Weber or the Hitachis that come stock on Datsuns. They are tuned basically the same way.
SSS DHLA40 jetting specs
Venturi: 28mm
Main jet: 115
Needle and seat: 1.50
Float: .01
Starter jet: 70
Starter emulsion tube: .01
Idle jet holder: .01
Idle jet: 50
Air corrector: 200
Emulsion tube: .01
Aux venturi: .01
Pump jet: 33
Pump delivery: 7.5
To suit SSS A12 engine with mild rally cam (see specs in SSS section) and 4-2-1 tubular headers
Also see: http://www.gruntled.com/Dellorto/
NOTE: When removing and re-inserting the Pump Jet, be sure to line up the passages. See http://www.gruntled.com/Dellorto/PumpJet.html
  1. Choose DHLA 40 for A-series engines
    1. Or DHLA 45 for larger engines
  2. Choose appropriate venturi size, perhaps 26mm is best for stock A12 engine
    • Available from 25 mm to 37 mm in increments of 1mm
    • Part number 8383.25 to 8383.37 at Eurocarb
    1. Auxiliary venturi from size 1 to 4
  3. DHLA Starter -- tuning for cold starting
    1. starter jet sizes from 48 (3315.48) to 105 (3315.105)
    2. starter emulsion tube 1 to 4 (7482.1 to 7482.4)
  4. Accelerator Pump
    1. Pump Jet sizes 33 to 60
    2. Pump rod adjustment. Screwing the nut tighter increases fuel delivery, turning it anti-clockwise reduces delivery.
      • Combination of Jet and tightness works 1) Time, shoot for 1 second 2) volume. Probably twin carbs will be within 1/2 turn of each other to deliver the same volume. Test this by actual measurement using a CC vial.
