Dashboard
Revision as of 09:37, 3 August 2018; view current revision
Category: Body
Various dashes were used for various countries, trims, and years. Standard used rectangular gauges, while GL and GX used round gauges. Deluxe (DX) could use either, for example all USA models use round gauges.
Terminology
In Nissan official terminology, the "dash" is the cowl & firewall. But in common usage, the dash is the instrument panel or gauges therein and sometimes refers to the dash pad.
Dash Panels -- see Firewall ダツシュ パネル
24072.jpgAlbum 24072
Instrument Panel is the entire removable pod assembly (commonly called the Dash) インストルメント パネル
5044.jpgAlbum 5044 5046.jpgAlbum 5046 23456.jpgAlbum 23456
The metal frame is the Instrument Panel Assembly
24118.jpgAlbum 24118
Gauge Cluster - see Cluster Gauge
21616.jpgAlbum 21616
Dash facia is Cluster Lid.  クラスター リツド
24073.jpgAlbum 24073
Dash pad is the Instrument Panel Pad.  インストルメント パツド
23277.jpgAlbum 23277
Dash includes the pad, instrument panel, and dash frame
Glovebox is on the passenger side
26012.jpgAlbum 26012
Defroster vents connect to the dash frame
26013.jpgAlbum 26013
Instrument Panel
  • Rectangular gauge instrument cluster (角/kaku): Standard, Deluxe Sedan
  • Round gauge instrument cluster (丸/maru): Deluxe Coupe, GL, GX
2149.jpgAlbum 2149
STD
804.jpgAlbum 804 11149.jpgAlbum 11149
DX Coupe
1350.jpgAlbum 1350
GL
5172.jpgAlbum 5172
1970-1971 (flat type)
11440.jpgAlbum 11440
1972 Japan (hooded type)
13214.jpgAlbum 13214
B110サニーインパネ inpane
Defrost Finishers
defrost finisher (ventilation garnishes/ventilation trim)
See Main Article: Defroster#Finisher
Trim Levels
Datsun 1200 trim packages received different factory equipment.
RECTANGLE GAUGE
STD:      Rectangle with OPTION clock
DX Sedan: Rectangle with OPTION clock
NOTE: North America DX sedan came with round gauges
ROUND GAUGE
DX Coupe: Round with OPTION clock
GL:       Round with clock
GX:       Round with Tachometer
          * clock moved to Console
          * 180 kph speedometer
Tachometer and Clock were both OPTION
26413.jpgAlbum 26413
Datsun Sunny Excellent 1400 PB110 trim levels were outfitted the same way except that DX Sedans came with round-gauge dashes.
1972 Facelift
See main article: Facelift Dash
Kilometers vs Miles
Miles only
10290_4a2f72d1a2c39.jpgUpload click to view
Miles only
Kilometers only
9082_4ae0b82060332.jpgUpload click to view
Dual range Kms with miles
277_4c0264d7b3d4a.jpgUpload click to view
Sunny Truck Dash
13485.jpgAlbum 13485
Early
1971-1978 rectangle dash the same as B110 STD/DX -- but only with black interior.
8400.jpgAlbum 8400
JDM DX utes got a shifter console.
Japan | Australia
16662.jpgAlbum 16662 11149.jpgAlbum 11149
12506.jpgAlbum 12506
Mid
1978-1989 Brown Round
978.jpgAlbum 978
the brown can be re-painted black using vinyl paint
6205.jpgAlbum 6205
With rectangular Choke warning added to dash April 1978 (Japan Market)
Late
1989-1994 dark Gray with Round Gauges
26028.jpgAlbum 26028 26029.jpgAlbum 26029
Note:
With rectangular Choke warning and EXH TEMP warning (Japan Market)
27042.jpgAlbum 27042
27036.jpgAlbum 27036 27037.jpgAlbum 27037
B140 Bakkie
14515.jpgAlbum 14515
  • "NISSAN" clock delete plate
Pad
Nissan calls the Dash pad the Instrument Panel Pad. Reference: Dash Trim Part Numbers
RHD
68910-H1000 ASS'Y-PAD, instrument [round or square]
68910-H2501 PAD-INSTRUMENT PB110 (black) DX,GL,GX
68910-H2600 PAD-INSTRUMENT PB110 (blue) GL
68910-H2700 PAD-INSTRUMENT PB110 (brown) GX
68910-H3100 PAD ASS'Y-instrument 1972 [Facelift]
68910-H2500 PAD-INSTRUMENT B120 -7803 BLACK
68910-G1060 PAD-INSTRUMENT 7804-8910 DARK BROWN
68910-95W00 PAD-INSTRUMENT 8910- GRAY
LHD
68910-H1600 LHD ASSY-PAD INSTRUMENT $306.10 USD
Maddat Code DP1200 - Datsun 1200 Dash Pad. Datsun 1200 RHD genuine Nissan dash pad, Brown only.
Facia (Cluster Lid)
Dash facia is called by Nissan the Cluster Lid (gauge cluster lid). Reference: Meter Part Numbers
See also: Cluster Gauge
RHD | LHD round (GL, GX, USA.DX and all Coupes)
24073.jpgAlbum 24073 24074.jpgAlbum 24074
Rectangle cluster lid (STD & JDM DX + early Truck)
8400.jpgAlbum 8400
LHD USA LID-CLUSTER
25010-H1701 [no FAN text]
25010-H4600 0172- <> 25010-H1701 [FAN-PULL]
25010-H7000 0772-
23172.jpgAlbum 23172 24071.jpgAlbum 24071
RHD LID ASSY-CLUSTER
rectangle type
  25010-H1000
  25010-H1100
  * with glass & plug (per 1974 catalog)
  * Sedan DX, Van Super-DX 4-speed (per 1971 catalog)
  25010-G1600 -7803
round type
  25010-H1800 ASS'Y-LID, cluster (metallic)
  25010-20000 ASS'Y-LID, cluster (wood grain) GL,GX
  1972 facelift
    25010-H3100 LID ASS'Y-cluster STD,DX
    25010-H3300 LID ASS'Y-cluster GL,GX
  25010-G1670 7804-8910
  68240-95W01 9810-
Close up around heater/radio section
24075.jpgAlbum 24075 27118.jpgAlbum 27118
Dash Frame
The dash frame is the metal part of the dashboard, which Nissan calls the Instrument Panel Assembly Reference: Dash Part Numbers
23278.jpgAlbum 23278
24114.jpgAlbum 24114 24115.jpgAlbum 24115 24116.jpgAlbum 24116 24117.jpgAlbum 24117 24118.jpgAlbum 24118 24119.jpgAlbum 24119
Dash Top
The top of the dash contains:
PB110
* Early: Flat instrument panel
* Late: Podded instrument panel
Early - Same as 1970-1971 1200, but offered in additional colors
See PB110 Brochure
1972 - Same as 1972 Datsun 1200
16011.jpgAlbum 16011
Cluster
Early
Late - same as 1972 B110
23173.jpgAlbum 23173
CLUSTER LID
H25 Gray Metallic DX
H26 Gold Metallic GL/GX
H31 Gray Metallic DX    from '72-1
H33 Gold Metallic GL/GX from '72-1
Sunny Excellent 1400 (PB110) hooded dash
1972 PB110 Facelift double-hump dash
Facelift PB110
Facelift PB110
Facelift PB110 Glove Box door is thick, with a prominent curve
Glovebox Lid
EARLY GLOVE BOX LID
H10 Black DX,GL,GX
H26 Blue  GL
H27 Brown GX
LATE GLOVE BOX LID
?Looks same as 1972 B110
13452.jpgAlbum 13452
Standard Dash
1975 October B120
26046.jpgAlbum 26046
1977 April B120 (和52年4月)
1977_B120_dash-1.jpg 1977_B120_dash-2.jpg 1977_B120_dash-3.jpg 1977_B120_dash-4.jpg 1977_B120_dash-5.jpg 1977_B120_dash-6.jpg 1977_B120_dash-7.jpg 1977_B120_dash-8.jpg 1977_B120_dash-9.jpg
50.JPGAlbum 50 268.jpgAlbum 268 804.jpgAlbum 804 838.jpgAlbum 838 1085.jpgAlbum 1085 1206.jpgAlbum 1206 1448.jpgAlbum 1448 1451.jpgAlbum 1451 2035.jpgAlbum 2035 2041.jpgAlbum 2041 2073.jpgAlbum 2073 2149.jpgAlbum 2149 2181.jpgAlbum 2181 2299.jpgAlbum 2299 2760.jpgAlbum 2760 2937.jpgAlbum 2937 2970.jpgAlbum 2970 3122.jpgAlbum 3122 3410.jpgAlbum 3410 3895.jpgAlbum 3895 3901.jpgAlbum 3901 3902.jpgAlbum 3902 4180.jpgAlbum 4180 4181.jpgAlbum 4181 4409.jpgAlbum 4409 4818.jpgAlbum 4818 4939.jpgAlbum 4939 5044.jpgAlbum 5044 6457.jpgAlbum 6457 6465.jpgAlbum 6465 6595.jpgAlbum 6595 6703.jpgAlbum 6703 7265.jpgAlbum 7265 7373.jpgAlbum 7373 7890.jpgAlbum 7890 8400.jpgAlbum 8400 8807.jpgAlbum 8807 8809.jpgAlbum 8809 9789.jpgAlbum 9789 9792.jpgAlbum 9792 9940.jpgAlbum 9940 10456.jpgAlbum 10456 11145.jpgAlbum 11145 11149.jpgAlbum 11149 11578.jpgAlbum 11578 11581.jpgAlbum 11581 12155.jpgAlbum 12155 12506.jpgAlbum 12506 12507.jpgAlbum 12507 13107.jpgAlbum 13107
Tinted gauge glass
24579.jpgAlbum 24579
Round Dash
See Round Dash Photo Index
1981 April
Custom Dash
Wood, stainless, silvia gauges -- customize the 1200 dash. Or fit an entire dashboard from Silvia, Charade, Starlet etc. into your 1200.
See Main Article: Custom_Dash
