Brake Hoses
Revision as of 05:49, 13 November 2021; view current revision
Category: Brake System
Datsun 1200 uses two front brake hoses, one per side. And a single rear hose. These are flexible rubber hoses. Sometimes called "soft lines" to distinguish them from the "hard" metal brake lines.
Front Brake Hoses
Fitting
The front brake hoses have a slot in each end fitting. This slot takes a C-clip to secure the hose.
12057.jpgAlbum 12057
The big C-clip
One end is clipped to a bracket on the strut
The other end is clipped to a bracket on the inner fender
Nissan [drum or disc type, single or tandem]
* 46202-H7025 ASSY-HOSE BRAKE FRONT L=280 (2) $21 USD
** superceded 46202-89913 ASSY-HOSE BRAKE FRONT L=280
Beck Arnley 0730267 Rockauto.com
* Length=11" End A Size=M10X1 End B Size=M10X1
RAYBESTOS BH36892/4536892
DORMAN H96862
ACDELCO 18J2188, 18J126, 19173109
* 1971-1973 Datsun 1200
* 1970-1978 Datsun S30 240Z/260Z/280Z
* 1982-1986 Nissan N12 Pulsar NX
* 1983-1986 Nissan B11 Sentra
NOTE: B210 requires 11.7" brake hoses
Wagner F96549 Rockauto.com
* B210
* B110
* etc
* Replaces Nissan 46202-89915,46202-H7200,46212-01A15
Rear Brake Hose
Rear Hose Fitting
The rear hose (A) goes from the body to the Rear Axle.
28213.jpgAlbum 28213
On the axle, it screws into the Rear Splitter
28212.jpgAlbum 28212
Rear Hose Part Numbers
Nissan
46201-H7200 Hose-brake $27 USD
* superceded 46201-89918 ASSY-HOSE BRAKE REAR L=330
* Length=13.18" End A Size=M10X1 End B Size=M10X1
RAYBESTOS BH36866
DORMAN H36866
BECK/ARNLEY 0730879 Rockauto.com
* 1971-1973 B110
* 1974-1978 B210
* 1977-1979 S10
* 1979-1983 S130
* 1978-1981 A10 wagon, rear
* 1977-1981 810
* 1982-1984 910 Maxima/810
