<-- back to Alignment
Checking camber is part of Alignment for proper tyre wear. Camber is not adjustable. Altering the camber can change handling characteristics.
The stock 1200 suspension is non-adjustable for Camber. If the camber is out-of-specification, the factory recommends replacing parts. A good suspension man can sometimes bend the strut housing to correct for bad camber.
B110 Specification Camber: 5' to 2°05' (positive)
For upgrading to modern camber settings, there is no provision in the stock parts. Fitting custom adjustable parts are needed.
Modern suggested camber Camber: -25' to 0°
-VE Camber (Negative camber)
1.5 degrees negative camber can work well for racing or spirited driving. Large amounts of -VE are mainly for looks — for performance you want the tread parallel to the pavement. But since the car leans in corners, having some negative camber keeps the tire tread parallel to the pavement even when leaning.
3 degrees negative camber (top of tyre leaning in)
Front
Datsun 1200 is designed with non-adjustable front suspension, so a simple Wheel alignment will not change the camber angle.
-VE can be achieved in the front suspension with either method:
- Move the top of the strut. Slot the strut-top mounting points per the Nissan Competition suspension manual
- Use adjustable Camber Tops
Alternatively, following methods increase the track, which may interfere with wide tyres and/or require flares
- Move the LCA mounting point in the crossmember
- Use a lengthened LCA, like the Nissan Competition units
- use a longer Ball Joint
As always after modifying the front suspension, the Toe-in must be re-adjusted to retain correct wheel alignment.
Move the Strut Top
Pulsar N13/N14 strut tops are small and allow for movement
Or, slot the 1200 strut-top mounting points per the Nissan Competition suspension manual
POST Re: Any interest in strut tops?
Camber Tops
Install Aftermarket adjustable strut tops, which are adjustable in the camber direction.
adjustable strut tops ... only helps to get a little bit more camber and/or castor. To get [a large amount of] camber, you need to run smaller diameter springs, as well as the adjustable strut tops. With the standard springs, the available adjustment will be restricted inside the strut tower by the large original spring diameter.
Small coilover type springs and adjustable strut tops are good for about 4.5 degree negative camber.
Move the LCA
Redrill or slot the crossmember mounting points for the LCA — moving it outwards gain negative camber.
Lengthened LCA
To increase Track and Camber at the same time, use a longer bottom arm.
- Nissan Competition sold lengthened control arms — 10MM longer for increased negative camber. See Racing_Suspension_System#B310
- Maddat sells adjustable arms. See Transverse_Link#Mad_Dat
- Or lengthen the arm, like this:
NOTE: B310/Stanza LCA is same length as 1200/120Y/Ute/B310/A10. All the same length.
Longer Ball Joint
Another way to push the bottom of the tyres out is to use a longer Ball Joint. The A10 and some B310 models use a longer ball joint which fixes the bottom of the strut further outboard (more neg. camber).
Rear Axle
Negative camber can be achieved with the straight axles by cutting and welding.
This axle has 2.5 degrees negative camber with reportedly no problem over three years of driving.
POST 2.5 degree camber rear axle
