Coupe Badges
Revision as of 13:51, 3 December 2025; view current revision
Category: Body
<-- back to Badges
Datsun 1200 Coupe used different badges than the Sedan, for the most part.
USA #Front, #Side and #Rear
Japan #Front, #Side and #Rear
27821.pngAlbum 27821
Japan market
1972 Facelift
Coupe got new grille badges and boot badges for the 1972 Facelift.
For the individual badges, see:
* #Front Grille badges
* #Rear Center emblem
* #Rear Right mark
0570589A30151217W00413.jpg 0570589A30151217W00417.jpg 0570589A30151217W00418.jpg 70005705893015121700400.jpg 0570589A30151217W00401.jpg
Radiator Grille
Japan market
Center Ornament
Coupe emblem - screws arranged diagonally
Left: #boot badge | Right: #grille badge
5199.jpgAlbum 5199
#62312-H1826 Export 'D' emblem
16758.jpgAlbum 16758 174_67e768d340176.jpgPost 498833
#62312-H1825 Japan 'S' badge
15930.jpgAlbum 15930 26619.jpgbrochure
1972 #62312-H4025 Center ornament - Winged 'S'
NOT THIS: similar badge -- but with knurled edges -- is the #Rear Center badge.
Custom Ornaments
Late-model Nissan hamburger badge
280Z ornament installed on 1200 coupe grille by club member Datsunbeginner
174_57fc61556da0e.jpgPost 481739
'S' Ornament
62312-H1825 SET-ORNAMENT radiator grille "S" early Coupe
Red, White, Blue badge colours
24322.jpgAlbum 24322
15930.jpgAlbum 15930 19630.jpgAlbum 19630
'D' Ornament
62312-H1826 SET-ORNAMENT radiator grille "D" Coupe Export
16758.jpgAlbum 16758 174_5c56c269494f3.jpgPost 490491 2837.jpgAlbum 2837 16678.jpgAlbum 16678 24322.jpgAlbum 24322 COUPE-badge.jpg 2260.jpgAlbum 2260
'S' Ornament (winged S)
The famous 'winged-S' was used on all 1972 Datsun 1200 Coupes, including Deluxe, GL, and GX. This is due to the facelift minor change.
62312-H4025 ORNAMENT-radiator grille 1972 Coupe winged-'S'
174_60fa0987e3721.jpgPost 495631 13679.jpgAlbum 13679
Although it look near-identical to the rear badge, they are not interchangeable.
Grille badge - diagonal screws | #Rear badge - level screws
Fits any plastic 1200 grille -- meaning it bolts to the early coupe and the mid-model 1200 truck (1978-1989)
2774.jpgAlbum 2774
Although from the factory it only was applied to coupes, it can be modded to fit on a Sedan Grille:
25054.jpgAlbum 25054
Bprojects 62312-H4025
174_60fa09dd863af.jpgPost 495631 19905.jpgAlbum 19905 rg72.jpg 174_60fa09a883101.jpgPost 495631 174_60fa09c23580c.jpgPost 495631 174_60fa09d01e9e0.jpgPost 495631 174_60ffc6519b07d.jpgPost 495640 174_60ffc65d05e58.jpgPost 495640 174_60ffc670bfb70.jpgPost 495640
Grille Trim Badge
Trim badge was placed on left side of JDM grille. USA coupes had no trim badge.
963.jpgAlbum 963
NOTE: the base version (STD/Standard) has no front-mounted trim badge. Neither did DX/Deluxe.
GL Grille Badge
62330-H2026 EMBLEM-'GL' (same as early sedan GL badge)
963.jpgAlbum 963
GL 1972
62330-H3325 1972 EMBLEM-'GL' [not set in a block] (same as Facelift Sedan Badge)
GX
62330-H2325 SET-MARK 'GX' (same as early sedan GX badge)
grille badge has long studs for mounting through the grille
compare to late (1972) sedan (compressed font)
25658.jpgAlbum 25658
compare to rear see-through badge
GX5
62330-H7225 1972 EMBLEM-'GX-5SPEED' COUPE, SEDAN
Quarter
Badges placed on quarter panel (rear fender).
Export
76854-H1600 EMBLEM-'DATSUN' BODY SIDE-rear (same as sedan)
24323.jpgAlbum 24323
21438.jpgAlbum 21438 3973.jpgAlbum 3973 5035.jpgAlbum 5035 6558.jpgAlbum 6558
Japan Market
Japan market (all differ from sedan)
#78841-H1800 EMBLEM-'Sunny' model badge
DX #78842-H1800 EMBLEM-'Coupe'
GL #78842-H2201 EMBLEM-'Coupe GL'
25569.jpgAlbum 25569
GX #78842-H2400 EMBLEM-'Coupe GX'
78841-H1800
78841-H1800 EMBLEM-'Sunny' model badge, rear side
78842-H1800
78842-H1800 EMBLEM-'Coupe' [fitted to DX coupes] rear side
Not this
78842-H2201
78842-H2201 EMBLEM-'Coupe GL' rear side
25571.jpgAlbum 25571 25570.jpgAlbum 25570 25569.jpgAlbum 25569 Coupe-GL-emblem.jpg
78842-H2400
78842-H2400 EMBLEM-'Coupe GX' rear side
Has a satin finish behind black 'coupe', and a striated finish behind white-inset 'GX'
2013ityou0501.jpg 27823.jpgAlbum 27823 27824.jpgAlbum 27824 coupe_GX-1.jpg coupe_GX-2.jpg coupe_GX-3.jpg 964.jpgAlbum 964 5173.jpgAlbum 5173
Rear
174_5d6f29118fa20.jpgPost 492456
Japan badges all differ, and includes GL and GX trim badges
174_5d7443192547e.pngPost 492501
Japan 1972 changes
174_5d744324b0803.jpgPost 492501
Automatic
79200-H1020 MARK-"Nissan Full Automatic" [script style] (to '71-March)
79200-H2820 MARK-"NISSAN FULL AUTO MATIC" [block style] (from '71-April)
79855-N2200 MARK-NISSAN AUTOMATIC USA COUPE ONLY
#79200-H2820 MARK-"NISSAN FULL AUTO MATIC" [block style] (from '71-April)
26203.jpgAlbum 26203
#79855-N2200 MARK-NISSAN AUTOMATIC USA COUPE ONLY
Nissan Automatic
* 5.75 inches wide
* USA Datsun 510 from 1971 June (3N71B)
28019.jpgAlbum 28019
28020.jpgAlbum 28020
Placement: trunk lid left side
174_5d6f4c3942ebf.jpgMain 174_589bfebd40a9e.jpgPost 483811 3239.jpgAlbum 3239 174_5d7437b43a6a8.jpgPost 492500 174_50f625c97336f.jpgUpload click to view 1417.jpgAlbum 1417
79200-H2820
Also used by Excellent 1400 (see PB110 Badges#79200-H2820
#used on Coupe
5618.jpgAlbum 5618
used on Sedan
fullmatic.jpgAlbum click to view 19301.jpgAlbum 19301
NOT THIS: non-1200 'Nissan Matic' is blue 84821-U0300 from Datsun 610
174_5d70333c2dfd0.jpgPost 492469 174_5d7032bd8a92b.jpgPost 492469
H28
174_5d70274f3808d.jpgPost 492468 174_5d70272e23fd3.jpgPost 492468
NOTE: mounting studs broken off
174_5d70276093ebd.jpgPost 492468
Right Side
  • Export coupes had a "DATSUN 1200" badge; Japan-market coupes had a trim badge
  • DX — the base model coupe — had no trim badge
Rear Model
Export coupes had a rear model badge.
USA & Australia 'DATSUN 1200' diagonal
84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID COUPE <> 84822-H1856
4466.jpgAlbum 4466 22156.jpgAlbum 22156
GL Rear Trim Badge
84823-H2001 Japan trim badge GL [1970-1971] (same as Sedan badge)
84823-H3300 Japan trim badge GL MARK 'GL' [1972] (same as Sedan badge)
GX Rear Trim Badge
84823-H2300 1970-1972 Japan trim badge GX MARK 'GX' (same as Sedan badge) Used in Japan and South Africa markets.
174_5d74ccd7de40e.jpgPost 492514 11785.jpgAlbum 11785
GX5 Rear Trim Badge
84823-H7200 1972 Japan GX 5-Speed (same as Sedan badge)
Rear Center
Rear badge versus Front badge. Rear has segmented edge, is thinner and fits over the rear panel crease
174_5d6e2d79f165f.jpgPost 492445
Center round 'D' badge - #Export
Center round 'S' badge - #Japan
NOT THIS: Sedan Grille Badges are not entirely round
11318.jpgAlbum 11318
Export Rear Center
79202-H1825 SET-ORNAMENT, rear panel
Export market 'D' badge
174_5d6e2d95032ed.jpgPost 492445 174_5d6e2da4126c3.jpgPost 492445
174_67e768be4d45c.jpgPost 498833
79202-H1826 SET-ORNAMENT, REAR PANEL COUPE <> 79202-H1825
452.jpgAlbum 452 3850.jpgAlbum 3850 5287.jpgAlbum 5287 7034.jpgAlbum 7034 3570.jpgAlbum 3570 14005.jpgAlbum 14005 22637.jpgAlbum 22637 24237.jpgAlbum 24237 174_5d6e2dab0c48a.jpgPost 492445
Japan Rear Center
Japan market 'S' badge
27714.jpgAlbum 27714 27715.jpgAlbum 27715 26396.jpgAlbum 26396
Rear Center 1972
79202-H4025 ORNAMENT SET-rear panel
174_5d749ae0c03cf.jpgPost 492513 1873.jpgAlbum 1873
174_5d744324b0803.jpgPost 492513
Winged 'S' badge - 1972 JDM Facelift
174_5d749af9881a8.jpgPost 492513 174_5d749b0251a13.jpgPost click for topic
174_5d749b1a20c2e.jpgPost 492513
Rear badge - level screws | #Grille badge - diagonal screws
16330.jpgbrochure
Dealer Badge
DeMaagd Nissan, Battle Creek, Michigan USA
174_50f624665c9f0.jpgPost 427664 174_61d0f91f9b484.jpgPost 496382
