General specifications
From Datsun 1200 Club
Category: Owner's Manual
General specifications for Datsun 1200 are listed here.
For other parts and systems use the search box at end of this page (below).
1972 USA Owners manual
29399.jpg39   29400.jpg40
General Specifications
Measurements
  • Wheelbase: 90.6 inch (2,300 mm) ALL, including truck
  • Overall length: 150.8 inch (3,830 mm) Sedan & Coupe
  • Overall width:
  • Overall height:
  • Track, front:
  • Track, rear:
  • Turning radius:
  • Ground clearance: 6.7 inch (170 mm) Sedan & Coupe
For more details, see: Measurements
Components
Capacities
1972 USA Owners manual (Page 40 ... 40):
Capacities
Engine Specifications
  • Displacment:
  • Bore & Stroke:
  • Compression Ratio
    • 9.0:1 Japan, Australia
    • 9.0:1: 1971 Export
    • 10.0:1 A12GX Hi-gas
    • 9.5:1 ??? A12GX Lo-gas
    • 8.5:1: 1972 Export (e.g. North America)
    • 8.5:1: 1973 North America
      • Source: Service Bulletin 1974 Introduction of New Datsun B210 Series
  • Spark plugs firing order: 1-3-4-2 (same as most four-cylinder engines)
  • Dwell angle at idle:
  • Ignition Timing:
  • Idling speed:
  • Spark plug gap:
  • Distributor point gap:
  • Valve Clearance (hot):
  • Belt tension
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=General_specifications"
This page has been accessed 28,121 times. This page was last modified 04:49, 28 December 2023. Content is available under Datsun 1200 Club.
