Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Genuine Nissan badges are metal or plastic depending on the year made.
Various early B110 Sunny Emblems (Japan)
Market Differences
- Japan market 1200s used "Datsun", "S" badges and "Sunny" badges
- Export market 1200 used "Datsun", "D" badges
Sedan boot emblems JDM vs non-JDM
Colors
Most badges, especially the script ones, are simple silver color.
Sedan "S" and "D" grille emblems have red and blue bars:
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
Some are faded after all this time:
Most are faded to no color after 40 years:
Sedan
Facelift emblems
Trim Levels
Comparo, Trim levels
Deluxe
Early Sedan Deluxe Grille (Japan)
Note the Deluxe model doesn't have a grille side emblem as do the GL and GX models.
Facelift Sedan Deluxe Grille (Japan)
Grand Luxe
- GL = Grand Luxe
- GX = Grand Luxe, Twin Carb
- GX-5 = special GX with 5-Speed
GX badges (South Africa GX used 'Datsun' emblems)
Late GX Sedan (note intricate "S" grille emblem)
Late GL Sedan (note intricate "S" grille emblem)
GL Sedan rear
What is the badge under the right taillight?
Location
Grille
Side
C-pillar Emblem
Rear
Center Rear (left of license plate)
keywords: エンブレム
Coupe
Coupe "D" badge (thin rear badge and thick front badge)
Radiator Grille
Early
Facelift
Quarter
Rear
Early
79200-H1020 MARK-"Nissan Full Automatic" 79200-H2820 MARK-"Nissan Full Automatic"
Facelift
Sunny Truck & Ute
LHD Badges
* Okinawa used 'S' and 'Sunny'
* Other LHD markets use 'D' and 'Datsun'
Front
62311 ORNAMENT-FRONT オーナメント、フロント
- -7803 trucks used Sedan grille and emblems "D" (Export) or "S" (JDM)
- 7804-8910 trucks used Coupe-like grille with unique rectangular center emblem
- 8911-1994 trucks use a square headlight grill with 'NISSAN' emblem on left side
- * 62392-G1265 ORNAMENT-FRONT 9810- カクガタ NISSAN
Rear
- Through 1974 'Sunny 1200' script below RH tailgate latch
- 84822-H1000 EMBLEM-trunk lid (SUNNY 1200) ALL トランク リッド エンブレム
- 84823-H1000 MARK-deluxe DX [fitted below Sunny emblem] デラックス マーク
- 14807-89910 STICKER-FUEL
- 99070-89909 PLATE-MODEL NUMBER 8504-8910
- 96905-15200 LABEL-LOADING CAPACITY -8109 [white on black?]
- 96905-89900 LABEL-LOADING CAPACITY 8110- [black on white?]
- 96906-89900 LABEL-FRIGID ZONE 8110-
- 96908-G5100 LABEL-REAR 'NISSAN' 8910-
- 96908-G1661 LABEL-REAR 'SUNNY' short body 8110-
- 96908-G1665 LABEL-REAR 'SUNNY LONG BODY' long body 8110-
Black stickers with silver writing
white sticker with black writing
Loading Capacity Label '最大積載量500kg' (Maximum payload 500kg)
Side Emblems
78801 EMBLEM-SIDE REAR, RH エンブレム、サイッド リヤ RH
- -7409 only DX comes with side emblems
- * 76854-H1000 -7510 DX
- - 8102 Sunny Truck uses 'Sunny' script-type sedan side emblems through February 1981
- 8911-up: no side emblems
B140 Bakkie
- B140 LDV 1400 Bakkie uses "NISSAN" grille letters
- 2006 Bakkie front with "Nissan" oval grille emblem
1200 SSS
The Datsun 1200 SSS sedan was a product from Datsun New Zealand.
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
- SSS badge on the glove box. Anyone have a photo?
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
- 'Sunny' badge
- 'Nissan Full Auto Matic' badge
- Steering wheel badges
Datsun 1200 S1
The Datsun 1200 S1 2-door sedan was a Datsun of Portugal offering.
- S1 grille badge
- S1 boot badge, fitted to left of the right taillight
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Front
Radiator grille - Center emblem
- 62312-H1626 EMBLEM SET-ORNAMENT radiator grille "D" Sedan Export
- 62312-H1026 EMBLEM SET-ORNAMENT radiator grille "S" early Sedan, Wagon
- 62312-H3125 ORNAMENT KIT-radiator grille late Sedan, Van
- 62312-H1826 SET-ORNAMENT radiator grille "D" Coupe Export
- 62312-H1825 SET-ORNAMENT radiator grille "S" early Coupe
- 62312-H4025 ORNAMENT-rad, radiator grille late Coupe
Radiator grille - side emblem (early)
Sedan Radiator Grille changed to fancy style for 1973(?) model year.
- 62330-H2026 SET-EMBLEM, radiator grille "GL" Sedan, Coupe early
- 62330-H2325 SET-EMBLEM, radiator grille "GX" Sedan (early), Coupe (early, late)
radiator grille - side emblem (late)
Sedan Radiator Grille changed to fancy style for 1972 JDM Facelift.
- 62330-H3125 EMBLEM SET-radiator grille "Deluxe" Sedan-DX
- 62330-H3325 EMBLEM SET-radiator grille "GL" Sedan, Coupe late
- 62330-H3425 EMBLEM SET-radiator grille "GX" Sedan
- 62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED" Sedan, Coupe
Side
Body Side C-Pillar
- 76852-H1000 BADGE-"Deluxe" SEDAN-DX
- 76852-H2001 BADGE-"GL" SEDAN-GL
- 76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
- 76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
Body Side Rear Fender
Rear quarter-panel mounted:
- 78841-H1800 EMBLEM-"Sunny" (early '71) Coupe
- 78841-H1850 EMBLEM-"Sunny" (W/Sealing washer) Coupe
- 78842-H1800 EMBLEM-"Coupe" (early '71)
- 78842-H1850 EMBLEM-"Coupe" (W/Sealing washer)
- 78842-H2201 EMBLEM-"Coupe GL" (early '71)
- 78842-H2251 EMBLEM-"Coupe GL" (W/Sealing washer)
- 78842-H2400 EMBLEM-"Coupe GX" (early '71)
- 78842-H2450 EMBLEM-"Coupe GX" (W/Sealing washer)
- 76854-H1000 EMBLEM-body side "Sunny" (early '71) Sedan, Wagon
- 76854-H1050 EMBLEM-body side "Sunny" (w/sealing washer) Sedan, Van-P, Van-DX
- 76854-H1600 EMBLEM-'DATSUN' BODY SIDE Sedan, Coupe Export
Rear
Trunk Lid Fitting (right)
Mounted on right side of trunk lid:
- 84822-H1000 EMBLEM-trunk lid "Sunny 1200" Sedan, Van-DX
- 84822-H1600 EMBLEM-'DATSUN 1200' TRUNK LID (cursive) Sedan Export
- 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID (non-cursive) COUPE Export
- 84822-H1856 EMBLEM-'DATSUN 1200' TRUNK LID (non-cursive) COUPE Export (supercedes H1806)
Trunk Lid Fitting (left)
Mounted on left side of trunk lid:
- 84823-H1000 EMBLEM-"DELUXE" Sedan, Van-DX, Van-P
- 84823-H2001 MARK-"GL" Sedan, Coupe early
- 84823-H3300 MARK-"GL" Sedan, Coupe late
- 84823-H2300 MARK-"GX" Sedan, Coupe
- 84823-H7200 EMBLEM-"GX-5 SPEED" Sedan, Coupe
- 96905-18100 LABEL-loading capacity (Van, lower left)
Rear Badge (Center)
- 79202-H1825 SET-ORNAMENT REAR PANEL COUPE "S" early
- 79202-H4025 SET-ORNAMENT REAR PANEL COUPE "S" late
- 79202-H1826 SET-ORNAMENT REAR PANEL COUPE "D" Export
Rear Badge (Transmission Mark)
These are mounted to the left of the number plate:
- 79200-H1010 MARK-"Sports" Sedan-ST,Sedan-DT,Sedan-GT, Van-DX T
- 79200-H1060 MARK-"Sports" (w/sealing washer) Sedan-ST,Sedan-DT,Sedan-GT
- 79200-H1020 MARK-"Nissan Full Automatic" early Sedan, Coupe (left trunk lid)
- 79200-H2820 MARK-"NISSAN FULL AUTO MATIC" (From '71-Apr.) Sedan, Coupe (left trunk lid)
- 79200-H3200 MARK-"NISSAN FULL AUTO MATIC" late Sedan
These are mounted on left side of trunk lid:
- 79855-N2200 MARK-"NISSAN AUTOMATIC" SEDAN, COUPE (left trunk lid) Export
Location Unknown
- 96907-G1100 LABEL-4 speed Van-Std T, Van-P T
1 62312-H1826 SET-ORNAMENT,RADIATOR GRILLE COUPE 2 08915-43410 WASHER-PLAIN (2) 3 08915-13410 WASHER-LOCK (2) 4 08911-10410 NUT (2) 5 84822-H1856 EMBLEM-'DATSUN 1200'TRUNK LID COUPE 6 76854-H1600 EMBLEM-'DATSUN'BODY SIDE 8 84822-H1806 EMBLEM-'DATSUN 1200' TRUNK LID COUPE 9 79855-N2200 MARK-NISSAN AUTOMATIC 10 79202-H1826 SET-ORNAMENT REAR PANEL COUPE
Part Sources
* Nissan USA and Nissan Japan are out of badges
* Nissan Australia apparently still has some.
* Too Intense usually has some 1200 badges
* Aoba Auto
* Yokohama South
* Matsuoka
Be careful of the quality:
Malaysia repro vs Nissan item: This reproduction badge has has poor chroming and what appears to be hand-painted coloring that doesn't exactly stay within the lines. However, other reproduction badges may be high quality.
エンブレム バッジ マーク
