The B110 chassis number is stamped on the cowl and on the engine-compartment plate.
See Nissan chassis codes for explanation of model numbers.
Contents[hide] |
MODEL NO. PLATE/TYPE PLATE/CAR NUMBER PLATE is attached to the hood ledge or the firewall
モデルNo.プレート表示 Model Number Plate display
取付および打刻位置 Installation and embossing position
Car Number (car identification number)
1981-up Model Plate
Vehicles sold in USA — starting with Model year 1981 — changed to a more detailed international VIN plate.
In October 1981 Japan domestic market started using a more detailed caution plate:
L-: L-level emissions (1981 Oct - 1989 Oct) G: Long Wheelbase Model: B122 [Sunny Truck] T: 4-speed Color: 002 White トリム Trim: C Engine: A12 gasoline engine S: Single carburetor Axle: HC41 H165 4.10 ratio Plant 4: Aichi Machine
Door Build Plate
North America had a dated #FMVSS Build Plate
Australia
See main article: Australian-assembled
ADR compliance plate - B120
Show plates by datskool
コーション プレート
Caution Plate
モデルNo.プレート 表示
Model Number Plate
ダットサン B110型
気筒容積 1171 cc
最高馬力/回転数 56PS/6000 RPM
軸間距離 2300 mm
?関型式 A12
車台番号 B110-xxxxx
保安基準適合 x-x
日産自動車株式会社
DATSUN B110 type
cylinder volume 1171 cc
Maximum horsepower 68PS/6000RPM
Axis distance 2300mm
engine model A12
chassis number B110-xxxxxx
safety standard x-x
Nissan Motor Co., Ltd.
Horsepower: 68 PS, Torque: 5.6 Newton Meters
GX: Horsepower: 83 PS, Torque: 7.1 Newton Meters
PB110
B120
B120-066350 - 68 PS 保安基準適合 8-4
1975 GB120 - 68 PS 保安基準適合 0-4 [Safety Requirements]
H-GB120 68 PS 保安基準適合 0-12 [Safety Requirements]
131127: 1978 April - 1979 July
L-GB122-023187 (1984 November), Plant 4 Aichi Machine
B10
New Type
Beginning October 1979, plate includes model subtypes and trim codes
Thailand
New Zealand
Nissan Motor Distributors (N.Z.) Ltd.
In addition to regular Nissan plates, Land Transport NZ (formerly Land Transport Safety Authority) may add a "Low Volume Vehicle Certification Plate":
Brought to you by the Low Volume Vehicle Technical Association
South Africa
140Z (a version of the KPB210)
1400 B140 model 408 (1400 Standard)
The last plates had two sets of mounting holes.
2007 model 408 Nissan Standard
GVM 1349 Gross Vehicle Mass
V 1349 Vehicle maximum mass
T 758 Tare weight
PD 0047 (47kW)
GAU 560 FRONT Gross Axle-Unit
GAU 915 REAR Gross Axle-Unit
AU 549 FRONT
AU 800 REAR
2008 model B01 Nissan ChampNISSAN SA. (PTY) LTDᵂ (EDMS) BPK MADE IN SOUTH AFRICA IN SUID AFRIKA VERVAARDIG VIN &ADNB010000A040858& [ADNᵂ = Nissan South Africa] MODEL B0102624413 [B01 = 1400 Champ] GVMᵂ/BYM 1360 V 1360 [maximum Vehicle mass] D/T 1750 [permissible maximum drawing vehicle mass] T 772 [Tare weightᵂ (unladen weight)] GCMᵂ 1750 PD 47.00 [kW] FRONT REAR GA/BA 575 [Gross Axle mass] GA/BA 921 GAUᴳ/BAE GAU/GAE [Gross Axle Unit mass] A 560 A 800 [maximum Axle mass] AU/AE AU/AE [maximum Axle Unit mass]
USA & Canada
1971 69 HP quench chamber cylinder head
1972-1973 68 HP open chamber cylinder head
USA Ratings: * Horsepower: 68 or 69 SAE HP * Torque: Not listed
For an explanation of SAE and why some are 68, others are 69, see: Performance.
Car Number Dash Plate
Windshield serial number on USA cars matches the Car Number Plate
Tune-up/Dyno Label
Tune-up/Dyno sticker as applied underhood
14805-H3900 (1972)
Vehicle Emission Control Information (Tune-up details)
14805-H7000 (1973)
The Inertia Wheel Weight (dyno setting): 2000 lbs
14808-H7000 (1973)
FMVSS Build Plate
In addition to the Nissan chassis numbers, USA models have an FMVSS build plate:
This is the only place on the 1200 that lists the month of manufacture.
Color Number
See main article: Color Number Tag
Custom Plates
Serial Numbers
B120
B120 truck from Japan catalog C-415 (1997-10) pages F1 to G1 1 1975-OCTOBER "H" emission standards B120-200001~ GB120-100001~ 2 1978-APRIL minor change and "E" emission standards B120-236882~ GB120-126578~ 3 1979-AUGUST 1979 year exhaust emissions and vehicle type changed to B121 B121-000001~ GB121-000001~ 4 1981-OCTOBER "L" emission standards and vehicle type changed to B122 B122-000001~ GB122-000001~ 5 1985-APRIL minor change B122-017001~ GB122-025001~ 6 1989-OCTOBER "R" emission standards B122-040101~ GB122-050101~ 7 1994-MARCH 年産打さ切り production ends
Pages G1 to I1 2-5 月頭シャシ-NO.-?表 1983-1994 monthly chassis numbers 1983 JUL AUG SEP OCT NOV DEC JAN-84 FEB MAR B122 008430 008967 009230 009630 009940 010270 010570 010850 011280 GB122 009993 010544 010843 011433 011863 012263 012623 013057 013783 1984 APR MAY JUN JUL AUG SEP OCT NOV DEC JAN FEB MAR B122 012500 012677 013093 013503 013840 014097 014456 014931 015330 015691 016116 016483 GB122 020000 020158 020552 021101 021525 021854 022339 022850 023248 023509 023934 024475
B110
JDM Catalog 11/1971 -- this may be the serial numbers where 3N71B automatic was first introduced. Translation is unclear.
* Sedan: From B110-226985 * Coupe: From B110-877228
USA Catalog * U = United States models * N = Canada models. Also some U models were sold in Canada. * A = Automatic transmission-equipped models
Reference: Datsun 1200 USA & Canada Parts Catalog Model B110 Series (C-0030U), 4th Overall Revision, December 1973
- KLB110TU
- KLB110TN
- KLB110AU
Z | From (L)B110-764205 | From Apr-71 |
Z | From LB110-640001 | From Jan-72 |
Z | From LB110-477893 | From Jun-72 |
F | From (L)B110-877228 | From Apr-71 |
F | From (L)B110-940001 | From Jan-72 |
F | From LB110-975540 | From Jul-72 |
[I'm guessing the "Z" means the Zama plant, and "F" means the Fuji Heavy Industries plant. This fits because only some Coupe models were marked F, while all sedans were built at the Zama plant.]
- LB110TRU
- LB110TRN
- LB110ARU
Z | From (L)B110-247023 | From Apr-71 |
Z | From (L)LB110-341001 | From Jan-72 |
Monroney Sticker
See Monroney Sticker
Vehicle Identification Number
Starting in 1980, Datsuns were marked with an international-standard 17-digit VIN number.
See main article: VIN
Engine
See Engine ID Mark
Transmission
Manual transmission number
