Fuel Injection
Revision as of 03:48, 11 January 2009; view current revision
Category: Fuel System
Your Datsun 1200 can be converted to fuel injection. Benefits can include smoother, more powerful performance and better fuel economy. Because Injection does not require a restricting venturi like a carburetor, the performance can be better. The highest-performing engines since the early 1940s have been fuel injected -- when the Germans perfected mechanical fuel injection. Top racecars have used injection since at least the early 1960s. Electronic fuel injection (EFI) has made it less expensive as fewer precision parts are needed, and more controllable by electronic circuits.
[hide]
Mechanical Injection
Mechanical fuel injection has no computer and can also outperform carburetors. It is not as sophisticated as EFI, but can work just as well in drag racing scenarios. Since there is no computer and no electronics needed it is much simpler. However due to the precision required of the parts, it is generally just as expensive as EFI.
Here are some non-electronic systems that could be adapted to a Datsun motor:
  • Bosch mechanical (K-Jetronic) from 1970s VWs and Audis (Bosch L-Jetronic was EFI) <li>Hilborn constant-flow, favored by racers of all kinds <li>Magoo </ul> You'll need the whole package including high-pressure fuel pump, fuel distributor, injectors/throttle bodies and lines. 246.jpg1145.jpg1818.jpg
    Electronic Fuel Injection
    Why choose electronic fuel injection?
      <li>Smoother <li>More fuel efficient <li>By design more HP than a carb due to no need for a restricting venturi (though some factory EFI still use a venturi) <li>better fuel distribution, allowing for higher compression ratio and other tolerances <li>for forced induction applications, automatic a/f control under boost <li>Better air distribution <li>automatically compensate for engine tuning changes. With a carb, you'd need to carefully plan out the design, and re-jet every time a component is replaced, for example, if you get a bigger exhaust pipe
    With injection, a venturi is not needed. The venturi in a carb is a restriction that somewhat limits ultimate airflow. In the 1950s and 1960s, the fuelie Corvettes had the most power ... still true.
    And, EFI is easier to work on than an emissions-controlled carb, generally speaking from 1st hand experience. I've rebuilt and jetted many carbs successfully, and tuned EFI systems of various sorts just as successfully. The tools and methods differ, but once you learn both, you'll probably agree with me. On the other hand, I hear the newest cars from the mid-90s up need specialized equipment. I have no experience with these newest systems, but can tell you that the late 80s EFI systems don't require special tools to work on.
    Datsun Factory A-series EFI
    Some 1980-1982 Datsuns in Asia markets came with an OEM (factory) EFI system. Nissan called it "EGI" -- Electronic Gasoline Injection. This is the "rare as" A14E Injection motor.
    quote:
    a friend of mine has a system that came on the A14 in the M10 Pulsars (very first ones). The set up he got came from Singapore
    The A14E engine came in:
    "A" series engines are produced in Aichi Machine held in Aichi plant.
    Quite a large horsepower difference:
    • A14E: 92 PS @ 6400 rpm, 11.7 kg-m @ 3600 rpm
    • A14: 80 PS @ 6000 rpm, 10.2 kg-m @ 3600 rpm
    1100.jpgA14 EFI manifold
    quote:
    SSS as I remember at one stage they had import carbie A15 engines for round $600 and injected A14 and A15 for around $800
    Reportedly, Nepean Sports classics in Castlereagh NSW was selling import motors. carlos' son ran one. These are fairly sought after by the rally guys as the narrow runners provide torque and the length also good top end, too small for a big A15 though.
    These possibly came in later model Nissan Vanettes, the reason they seem rare is both my manifolds broke across the bottom of no's 1 & 2 inlet runner. Plus it suffers from reversion with a big cam.
    These were also available in asian markets (Japan, Singapore, etc).
    quote:
    • A14 EGI = HB310 (1978-1980) Type-GX & SGX
    • A15 EGI = PB310 (1980-1981) Type-GX & SGX
    As for the name in Japan, Nissan calls EGI and Toyota EFI.
    Although the EGI system should excel Carburettors in the performance, old EGI is inferior to Carburettors.
    4217.jpg A series injection manifold
    Discussions:
    As you can see here, the setup is nearly identical to 1980 200SX EFI system:
    • This car is missing the air induction piping that goes across the radiator (see 200SX EFI for layout and diagrams)
    B310 Factory Setup
    Performance
    This factory Nissan setup was designed for typical mass-market street performance. It is not a racing system. Expect better low-speed horsepower performance than a stock DCH306 carburetor (due to the longer runners), but the same peak horsepower.
    Quote
    A factory EFI setup imported from Japan was tried, and found to be much smoother, but ... restrictive above 6000rpm when used with the [racing] cam.
    939.jpg940.jpg941.jpg 2408.jpg2409.jpg2410.jpg 2411.jpg3215.jpg 3684.jpg3685.jpg 942.jpg1877.jpg1884.jpg 1100.jpg2875.jpg2826.jpg 2950.jpg2960.jpg2961.jpg
    Other Choices
    If you can find a complete Nissan EGI system for A-series engine, it is the easiest way to convert. It is a relatively straight-forward bolt on. However if you cannot find it, need higher performance, or have a far from stock engine, you'll want to look at other options.
    Several choices here:
    • Swap the entire engine assembly from a another Datsun into your 1200, like a CA18E or E15E
    • Adapt an EFI system from another engine to the A-series engine. You can fit 200SX EFI, an OEM Nissan EFI system into other cars.
    this set-up will run just about any 4 cylinder in the world ... And it's easier than you think.  ;^)
    Discussion: A15 EFI?? Using E-series setup on A-series engine.
    A-series Conversion Kits
    Purpose-made kits, including everything needed for an A-series engine, may be offered by some vendors.
    Universal Conversion Kits
    You can purchase "universal" 4-cylinder kits that use a carburetor manifold. These are sometimes call "ITB" (Individual Throttle Body) kits, although dual-throttle-body versions are even more common. Prices are about $500-$3500 -- not including manifold. Kits are available for:
    • Weber DCOE single sidedraft manifold
    • Weber DCOE dual sidedraft manifold
    • Weber 32/36 downdraft plus an adapter plate for stock Datsun manifold
    Generally, the kit won't include a hi-pressure fuel pump system, sensors, or ECU.
    Twin Hitachi
    Twin DCOE
    Single DCOE
    Example $1200
    • Your own Weber single-sidedraft manifold (~$100 used)
    • Use the Extrudabody universal DCOE EFI kit ($580 USD with drilling)
    • Add your choice of fuel supply (~$200)
    • Add your choice of two injectors ($20 used, $70 new)
    • Add your choice of sensors ($50 used)
    • Add your choice of ECU ($200-up)
    Single Downdraft
    This is a nice budget possibility. It has a bit of bling, plus you'll get better performance than stock and a nice smooth driving experience -- after careful tuning. Possibly even better fuel economy than stock, if you tune it right.
    • Use your existing Datsun A-series manifold ($0)
    • Custom fabricated adapter plate ($20 for aluminum stock)
      • Plus your labor measuring, cutting, drilling and filing
    • ITB: SU-Universal Throttle Body kit ($160)
    • Air filter ($0 - $15)
      • You can run without a filter. Extrudabody has a nice $15 unit.
      • Hoses:
      • Hi-pressure fuel pump
      • Surge tank
    • Add your choice of sensors ($20-$50 used)
      • Get from the wreckers: GM air temp, water temp, oxygen, and MAP sensor
    • Add your choice of ECU ($140-up)
      • $140 for MegaSquirt-I solder kit
    • Wiring ($0 - $20)
      • Get wiring out of your parts car, or from the wreckers
    Total (estimated) $555-$1000
    Create Your Own Kit
    Most Datsun1200.com users that have converted their A-series to EFI have designed their own kits, using a variety of parts. For example, using a factory EGI manifold with aftermarket ECU. Or universal Injector Bodies with HALtech ECU and GM sensors. Or fitting Ford TBI with Bosch injectors and a GM brain.
    What about spark control?
    Along with your fuel injection system, you can use the stock A12 distributor. However, to totally modernize your engine, you may install a Datsun electonic distributor, or use a distributorless crank-trigger multi-coil ignition system. The latter is called a "spark" system and can work with the EFI ECU, or with a standalone controller like MegaJolt.
    See:
    Weber DCOE Manifold Conversions
    Got a Weber DCOE carburetor sidedraft manifold? Design your own system.
    Replace the carbs with DCOE-replacement throttle bodies. These are a direct replacement for:
      <li>Weber DCO/DCOE <li>Mikuni PHH <li>Solex ADDHE <li>SK racing sidedraft <li>Dellorto DHLA
    Available in 40, 42, 45, 48, 50, and 55mm sizes from TWM
    These take standard Bosch, Lucas, Rochester (GM) or Weber injectors.
    Also available for downdraft IDF-style and IDA-style and DCNF-style manifolds.
    suppliers:
    Electronic Controller Units
    The Electronic Controller Unit (ECU) -- aka ECU/brains/computer -- is critical to operation of the EFI system. You can use the factory stock ECU, or aftermarket ones, including MegaSuirt and General Motors.
     See main article: ECU
    Fanta injection
    Fanta injection can be used with or without fuel injection. Search the main forum for more information. Texans prefer Nehi Grape as an anti-detonant.
    Parts needed
      <li>EFI Manifold, or other manifold sufficiently modified <li>Throttle body <li>Injectors and wiring harness <li>Fuel rail and lines <li>Gas tank <li>Fuel pump, high pressure (mounted in tank, or out of tank below level of fuel) <li>Fuel filter <li>Fuel pressure regulator <li>(optional) surge tank <li>Return line <li>ECU (Electronic control unit)
    Wiring:
      <li>injector harness <li>sensor harness <li>power wiring and fuse
    Sensors: one or more of the following:
      <li>Throttle Position Sensor (TPS) <li>Coolant temperature <li>Oil temperature <li>Intake air sensor <li>Oxygen sensor <li>MAP (Manifold absolute pressure -- vacuum sensor. Some can sense boost also)
    Injector Sizing
    Say the injectors are rated at 3bar (43.5 psi) +-3%. 80% is the normal maximum practical operating capacity. You can get more output by boosting fuel pressure, for example some injectors might be safe at 70lbs pressure.
    You need to know the BSFC (Brake Specific Fuel Consumption). For a normally aspirated engine, plan on 0.5 lbs/hour/hp. Put another way, take the HP/2
    200 HP / 2 = 100 lbs/hr is the need.
    With 4 injectors, they need to be 25 lbs/hr allowing for 80% operation, you should get 30 lbs/hr rated injectors. If you are planning on raising power output later, go up one size to start with.
    High or Low Resistance Injectors?
    Whether you use High or Low Resistance Injectors depends first on whether your ECS can do both. Get the kind that is compatible.
      <li>Most OEM controllers use high-resistance injectors (saturated driver) <li>Many aftermarket controllers use low-resistance injectors (peak and hold)
    The low-resistance injectors generally react faster, for more precise control and higher rpm capability.
    Used Parts
    Yep. Injectors off many cars from the wreckers are perfect for you. Get the injector wiring plug too. For example Ford Mustang 5.0, Chevrolet V8, 4-cyl ECI Magna (the same as VN group A injectors)
    Oxygen sensors may be sold very inexpensively by some wreckers. Supply and demand: not too many people buy used O2 sensors, keeping used prices low.
    Intake and Exhaust Manifolds
    A tuned-runner manifold would not be hard to make one out of some steel tubing and a bit of 10mm plate for the flange, just need a throttle body around 50mm. 661.jpg
    quote:
    Figure out exactly what you want, take some dimentions and a spare cyl head (if you have one) to an aluminum or stainless steel fabrication place eg, aluminium boat builder, have it fabricated ,then machined and bob's your uncle, you have an injection manifold. I'm an aluminium boat builder by trade, so I couldnt see it costing anymore than $250 - $350 max
    1477.jpg1713.jpg1717.jpg 1727.jpg1815.jpg 2057.jpg2058.jpg2365.jpg 2716.jpg EFI Fuel Pump
    301.JPGDimlights's UM-1
    Innovative intake manifold allows use of stock exhaust manifold.
    You could also use a modified Hilborn injection manifold.
    4069.jpg A15 GX manifold with injector bosses welded on
    O2 Sensor Reading -- Air/Fuel Meter
    O2 (oxygen) sensors can be used to troubleshoot the fuel/air mixture. This uses an Oxygen sensor (Lambda sensor) to display to you how the actual a/f ratio of the engine as it is running. This is good for carbureted cars too, so you can see which way you need to adjust or jet the carb.
    Basically, you can tap in to the existing wire for the sensor. You can get a high-impedance ohmmeter at radio shack for under $40, but the specs need to be 20 Mega ohms resistance (most are not this high).
    $10 a/f sensor from Autospeed article
    full-range LED sensor project from Autospeed article
    See datsuns.com tech article. For an excellent description with diagrams, download TWM's PDF file www.twminduction.com for their "Halmeter" product. Link LambdaLink From New Zealand
    Camden Industries Zcar Magazine two excellent articles on using Lambda sensor. For more, including build-it yourself A/F meters, see Jason's Weber page
