Turn Signals
Revision as of 07:49, 28 November 2017; view current revision
Category: Lighting System
Turn signals (flashers, blinkers, indicators, winkers) -- all 1200s have them. The Hazards (4-way warning flashers) are part of the turn signal circuit, although not equipped in some countries. Optional was the Passing Lamp -- a turn signal switch with built-in passing button at the end of the stalk, which flashes the high beams.
Also See
These components comprise the T/S system:
* Turn signal switch (in steering column)
* Hazard switch (on column cover)
* Light Switch (in dash)
* Wiring & Fuse
* Lamps (lens & socket & bulbs)
  Front Combination Lamps
  Cluster Gauge (dash indicator bulbs)
  Rear Combination Lamps
RHD & LHD use the same T/S switch assembly. Just rotate it 180 degrees.
23134.jpgAlbum 23134 19664.jpgAlbum 19664
19662.jpgAlbum 19662 19663.jpgAlbum 19663 23135.jpgAlbum 23135 23136.jpgAlbum 23136
Switch Removal and Installation
  1. Remove Steering Wheel
  2. Remove Steering Column cover (clamshell)
    2136.jpgAlbum 2136 19648.jpgAlbum 19648
  3. Unplug wiring connectors down along steering column
  4. Remove position screw
    24404.jpgAlbum 24404
  5. Loosen the two clamping screws
  6. Pull straight off column
Flasher Location
The flasher units (hazard and turn-signal) bolt to each side of the pedal box strut:
15949.jpgAlbum 15949
The other flasher bolts to the other side of this strut.
non-USA
The flasher can is bolted to the right side of the steering column brace.
NILES Hazards & Turn Signal flasher unit bolts to right side of column brace
15957.jpgAlbum 15957
USA 1200s have two flashers.
NILES Hazard flasher unit bolts to right side of column brace
NILES Turn Signal flasher unit bolts to left side of column brace
15958.jpgAlbum 15958
Troubleshooting
See Turn Signal Testing
AUS Flasher
AUS Datsun B10 25520-89981 (Audible) > 25520-89900
* NILES 12.8V CF101 23Wx2+5W+3.4W
AUS Datsun 510 25520-89985
25520-88900
* Datsun B10 AUS
* Datsun 910 Bluebird AUS/EUR
* Nissan S110 Silvia JAP
* Datsun S110 Silvia/Gazelle EUR
Japan Flasher
Japan-market 1200s used a single flasher unit to operate both the Turn Signals or the Hazards (depending on position of the Hazard switch).
1200 including truck
25520-89974 UNIT-flasher, hazard & turn signal
* supercedes 25520-89962
B210 1973-1975
Late B210 used seperate flashers for Turn Signal & Hazards.
B210 1976-1977
25520-89995 UNIT ASSY-TURN SIGNAL FLASHER
25520-89997 UNIT ASSY-HAZARD FLASHER [SAME AS USA]
B10
25520-89000 > 25520-13200
USA Flasher Units
T/S flasher unit and Hazards flasher unit look similar (both are two-prong flashers), but are different specification. The load varies: Hazard flasher activates all lights at once, while T/S flasher does one side at a time.
Terminals
X: battery
L: lamp
Candlepower: 32 [32CP]
Cycles per Minute: 80 to 90 C/M
In the orginal B110/B210/B310 fitting, the T/S flasher was a large 40mm diameter NILES unit, while Hazard used the smaller 32mm NILES unit.
Newer style
19656.jpgAlbum 19656
Early Style
24407.jpgAlbum 24407 24406.jpgAlbum 24406
Aftermarket
24409.jpgAlbum 24409
Turn Signal Flasher
T/S Flasher
B5520-89993 UNIT-FLASHER 12V 50W $14 USD
NILES CF115 (23W x 2 + 3.4 w [49.4 watt])
* superceded 25520-89901
used by
* Datsun B110 USA
* Datsun 510
* Datsun 520/521
* Datsun Fairlady AUS
24408.jpgAlbum 24408
B210 USA spec is different: 25520-89976 or 25520-89966
B310 USA spec is different: 25520-89983 (clip on, not bolt-on).
Hazard Flasher
Hazard flasher
25520-89997 UNIT HAZARD FLASHER $24 USD
* supercedes 25520-89990 (original B110 spec)
* superceded 25520-89996 (original B310 spec)
NILES F215AF (23W x 2 + 3.4 w [49.4 watt])
NIEHOFF 562
used by
* Datsun B110 USA
* Datsun B210 USA
* Datsun B310 USA
Aftermarket Units may replace one or both part numbers.
NIEHOFF 562 (suitable for Hazards) is compatible with:
* 25520-89976
* 25520-89978
* 25520-89983
* 25520-89996
* 25520-89997
* 25520-B8060
* 25520-E46000
* 38300-634-671
* 38300-671-671
* 38300-671-672
* 38300-692-671
* 38300-692-672
* 38350-634-003
* 38350-634-671
* 38350-671-003
* 38350-671-013
* 2113-66-470
* 6832-10-072
* MB031754
* MB031755
* MB031756
* 6832-10073
* 7861-22000
used by:
71-85 American Motors
80-87 Aston Martin
71-85 Chrysler
71-85 Dodge
71-85 Dodge Truck
67-82 Ford (English)
70-84 Honda
61-82 Jaguar
68-82 Lotus
61-81 MG
70-84 Mazda
67-80 Mercury
83-91 Mitsubishi
71-85 Nissan-Datsun
71-85 Plymouth
71-85 Plymouth Truck
Universal Flasher
Flasher for either T/S or Hazards. My Sunny Truck is using this common USA unit.
Aftermarket universal thermal flasher
BUSS FLASHER 552/536 12V $3.19 @ O'Reilly
2-terminal
32CP MAX6
Taiwan
flashes 2-3 Turn Signal 32CP lamps
flashes 2-6 Hazard lamps
clip on type [no bolt-on tab, so zip-tie it under the dash]
Electronic Flasher
An "electronic" flasher may be used to accomodate non-stock bulbs, but requires extra wiring.
By contrast, the original thermal flasher types only work with a specific number and wattage of bulbs.
TS/Beam Switch Assembly
19645.jpgAlbum 19645
See Main Article: Turn signal switch
  • Standard type
  • Passing lamp type
Hazard & Parking Light Switch
4-way hazard flashing lights
See Main Article: Hazards
Light Switch
  • 25160-H1101 SWITCH COMP-lighting B110 (also B120)
  • 25160-H1110 SWITCH COMP-lighting, with fog lamp switch (op.)
  • 25160-H2510 SWITCH COMP-lighting, w/o fog (op.)
  • 25160-H2511 SWITCH COMP-lighting, with fog (op.)
  • 25165-H1000 KNOB ASSY-lighting
  • 25165-E7500 KNOB ASSY-lighting, with illumination, w/o fog (op.)
  • 25170-H2510 LAMP ASSY-illumination (op.)
Custom
Also here's a custom update: Add a Bluebird multi-switch (which looks like the B310 Steering Column switch). Bolts to the 1200 column:
  • T/S switch
  • Light switch
  • Wiper switch
14806.jpgAlbum 14806 14807.jpgAlbum 14807
1211.jpgAlbum 1211
