Datsun model series 810 was produced 1976-1981. In some countries it was marketed as "Bluebird", in others as "200B" or "180B" or "160B" depending on the engine fitted. Not the same as the 1980-1984 Datsun 810 north america, which is actually model series 910.
810 rotors are solid discs. Vented discs like the 280ZX Strut Swap are superior for fade-resistant, which is important for racing and for mountain driving.
NOTE: For the Japan market 810, front drum brakes were used for Van Deluxe, and for all LPG models (810.P with L18P engine, 811.P with Z18P engine).
244 mm
Girlock brakes were fitted to Australia-assembled 810s. Japan built 810 sold in Australia used the 253 mm brakes.
244 mm discs * Some Australian 200B * Some Australia Stanza A10 from 0779
ROTOR Diameter 244 Height 43.6 Thickness 12.7 Min Thickness 10.5 Centre Hole Dia 73 Bolt Holes 4 * DBA326
PAD * DBA1091
245 mm
4-cylinder 810s used same 245 mm brake rotors as B310 Sunny. Most 810 SSS used this too.
Annette 20, N20 (AN20) Type
See B310 Strut Swap and Stanza Strut Swap
40207 40206-U6700 Annette N20 (AN20) 245 mm rotor * Short Body, except SSS ES model Also from: * A10 510 USA * A10 Stanza Australia to 0679 (Japan built) * B210 A14 * B310 A14/A15
For details on the rotor, see Brakes.
Diameter: 245 mm Height: 35.5 mm Thickness: 10 mm Thinness: 8.4 mm Hub reg: 73 mm 4 x 95 PCD (bolts to hub) * DBA307
N20 Caliper
N20 41000-G2800 41000-U9602
253 MM
Annette 22 N22 (AN22) Type
253.5 (254) mm 40206-U7600 * Long Nose models (including 4-cylinder) except EF and EL * SSS ES model * 200SX USA S110 1980-1983 * Centric 121.42015 Height: 47.6 mm Thickness new: 12.5 mm Thickness min: 11.5 mm weight 4.7 kg 4 x 95mm bolt circle
N22 Calipers
41000-R5702 SSS ES 41000-S3002 late long nose EL, EF 41000-U7200 early long nose
N22 Pads
Pad Kit 41000K 41060-U2726/41060-U2727 41060-U3426
257 MM 5-bolt
257 mm 5 x 4.5 inch PCD * 180B Europe * C23M Serena Europe (Vanette) * HC23 Vanette Cargo 9409- * LDV Cub 9808- Thickness: 26 mm Height: 52.2 mm Minimum thickness: 24 mm Centering diameter: 68 mm 5-bolt * 40206-9C100/40206-9C101, 40206-Y9502 * Ferodo DDF722
270 MM
N34 type was used G6EL and G6EF (EFI) six-cylinder 810s, and all North American 810s.
270 mm (10.62 inch) Nissan part number 40206-U8700 * C230 Nissan Laurel * G810 L24 or L20 * Japan: Bluebird 2000G6 2 liter [L20S, L20E] Height 48 mm Nominal thickness 12.5 mm Min thickness 10.5 mm Hub hole: 73 mm Bolt circle: 4 x 95 mm (to hub) Type: Bolts behind the hub (same as Datsun 1200) Weight: 13.7 lbs (compare to 1200 at 5.9 lbs) * Centric 121.42009 * Aimco 3127 * Wagner BD97318 * Raybestos 9252R/9252
N34 Caliper
270mm discs use Annette 34 calipers * dual-piston sliding yoke (same as Datsun 1200 but larger) * Bore: 54 mm (2.12 inch) * Pad: 10x .01140 41000-U8700 AN34 caliper, RH 41010-U8700 AN34 caliper, LH * Centric 141.42010,141.42009 * Raybestos FRC3030, FRC3029 * Beck/Arnley 0760056 * Wagner CR105925 Also fits Caliper with yoke: * 200SX S110 1980-1983 Caliper w/o yoke: * 620 1978-1979 * 720 1980-1983 to 11/82
N34 Pads
Brake pads for 270 mm Pad Kit 41000K 41060-U8725 77.7 x 69.2 x 15.5 mm FMSI TYPE: D57, D114, D161, D173, D238, D244, D246 * Centric 102.01140 * Beck/Arnley 0861175, 0821175 * 41060-B9525/41060-B9527 Datsun 720 USA * 41060-E4125 * 41060-N3026, 41060-N3036, 41060-N4426, 41060-N8525 * 41060-U8725
Bendix DB86 Pad - Australia FMSI D57 78 x 68 x 15 mm * AUS 200B sumitomo * 200SX (S110) 1981-1983 * 240K GL 1972-1979 * 240Z (S30) 1970-1974 * 260Z (S30) 1973-1978 * 260C/280C 1974-1979 * 720 1980-1982 4WD, Dual cab * 720 King Cab 1-ton * Skyline C210 1978-1981 * Toyota Corona, Cressida, Crown
Australia
Datsun 810 "200B" was equipped with either Girlock or Sumitomo brakes.
GIRLOCK 200B 1977-1978 DB1027 pad 200B 1979-1981 DBA326 rotor, DB1091 pad
DBA326 rotor: 244 mm DBA315 rotor: 253 mm
SUMITOMO - DB86 pad 200B 1977-1979 Sedan 200B 1977-1980 SSS & Wagon
compare to Stanza A10 discs: * DBA307 245 mm japan built * DBA308 232 mm * DBA315 253 mm * DBA326 244 mm
