<-- back to Part Numbers Index
Also see: Main article for usage, photos, cross-reference Front Axle Road Wheel & Cap Tires Hub Front Brake Drum Brake Rotor Wheel bearings Idler Arm Balljoint
1 40018-18000 COLLAR-SPINDLE FRONT (2) 2 08114-06510 NUT-LOCK FRONT WHEEL BEARING (2) 3 40264-18000 WASHER-LOCK FRONT WHEEL BEARING (2) 4 40052-H1000 ARM-KNUCKLE RH -0173 4 40052-H5000 ARM-KNUCKLE RM 0273- 6 40052-H1000 5 40053-H1000 ARM-KNUCKLE LH -0173 5 40053-H5000 ARM-KNUCKLE LH 0273- 6 40053-H1000 6 40056-H1000 BOLT-KNUCKLE ARM 38MM (2) -0173 6 40055-H1000 BOLT-KNUCKLE ARM 44MM (2) 0273- 6 40056-H1000 7 40055-H1000 BOLT-KNUCKLE ARM 44MM (2) 8 08911-64010 NUT-HEX M10X1.25 (4) 9 08915-14010 WASHER-SPRING M10 (4) 10 40038-H1000 BOLT-STEERING STOPPER (2) 11 08911-34010 NUT-HEX M10 (2) 12 40160-H1000 ASSY-BALL JOINT LOWER (2) 13 40189-73000 PLUG-FILLER (2) 14 40192-H1000 COVER-DUST LOWER (2) 15 40146-18000 CLAMP-DUST COVER (2) 16 08911-84210 NUT-HEX SLOTTED M12X1.25 (2) 17 08921-32010 PIN-COTTER (2) 18 40178-H1000 BOLT-FIXING BALL JOINT A (2) 19 40179-H1000 BOLT-FIXING BALL JOINT B (6) 20 08911-60810 NUT-HEX M8X1.25 (6) 21 08915-13810 WASHER-SPRING LOCK (8) 22 40202-18051 ASSY-HUB ROAD WHELL FRONT (2) 22 40202-H1005 ASSY-HUB ROAD WHELL FRONT FOR DISC BRA (2) OP 23 40222-22001 BOLT-HUB ROAD WHEEL (8) 24 40210-H1000 ASSY-BEARING FRONT WHEEL INNER (2) 0570- 2 40210-18000 24 40210-18000 ASSY-BEARING FRONT WHEEL INNER (2) 25 40215-18000 ASSY-BEARING FRONT WHEEL OUTER (2) 25 40215-H1000 ASSY-BEARING FRONT WHEEL OUTER (2) 0570- 2 40215-18000 26 40232-18000 SEAL-GREASE FRONT HUB (2) 27 40234-18000 CAP-HUB FRONT (2) 28 40206-18003 DRUM-BRAKE (2) 29 40206-H1006 ROTOR-BRAKE DISC FRONT (2) OP 30 40209-H1005 BOLT FIX ROTOR FRONT (8) OP 31 40300-H1001 ASSY-ROAD WHEEL 4JX12 (2) DELUXE 32 40310-H1140 SET-TIRE & TUBE 155SR 12 RADIAL (2) OP 32 40310-H1940 SET-TIRE & TUBE 155SR12 RADIAL EMVSS (2) OP 32 40310-H1928 TIRE 6.00-12-4PR SNOW FMVSS (2) OP 32 40312-H1922 TIRE 6.00-12-4PR FMVSS (2) 32 40310-H1772 SET-TIRE & TUBE 6.00-12-4PR WHITE EMVSS (2) OP 33 40315-H1100 COVER-ROAD WHEEL (2) SEDAN (DELUXE) (OP STD) 34 40315-H1800 COVER-ROAD WHEEL (2) OP COUPE 34 40315-H1801 COVER-ROAD WHEEL (MEXICO MADE) (2) COUPE 0872- 5 40315-H1800 35 40225-27700 NUT-ROAD WHELL (16) 36 40325-H1000 WEIGHT 50G WHEEL BALANCE (0) 2 40325-18000 36 40329-18000 WEIGHT 90G WHEEL BALANCE (NOT ADOPTED (0) 36 40330-18000 WEIGHT 100G WHEEL BALANCE (NOT ADOPTED () 36 40328-18000 WEIGHT 80G WHEEL BALANCE (NOT ADOPTED (0) 36 40327-H1000 WEIGHT 70G WHEEL BALANCE (0) 2 40327-18000 36 40327-18000 WEIGHT 70G WHEEL BALANCE (0) 36 40326-H1000 WEIGHT 60G WHEEL BALANCE (0) 2 40326-18000 36 40326-18000 WEIGHT 60G WHEEL BALANCE (0) 36 40321-H1000 WEIGHT 10G WHEEL BALANCE (0) 2 40321-18000 36 40325-18000 WEIGHT 50G WHEEL BALANCE (0) 36 40321-18000 WEIGHT 10G WHEEL BALANCE (0) 36 40322-18000 WEIGHT 20G WHEEL BALANCE (0) 36 40322-H1000 WEIGHT 20G WHEEL BALANCE (0) 2 40322-18000 36 40323-18000 WEIGHT 30G WHEEL BALANCE (0) 36 40323-H1000 WEIGHT 30G WHEEL BALANCE (0) 2 40323-18000 36 40324-18000 WEIGHT 40G WHEEL BALANCE (0) 36 40324-H1000 WEIGHT 40G WHEEL BALANCE (0) 2 40324-18000
