<-- back to Lighting_System#Lamp_Specifications
1. Exterior single element, one bottom contact
Rear T/S (turn signal) -- See Tail Lights Front T/S -- See Front Combination Lamp & PB110 * #26717-89900 BULB 12V-23W * B110 North America * B110 Japan and PB110 * 21 watt (other countries)
2. Exterior dual element, two bottom contacts
Dual-filament bulb * Front park & T/S -- See Front Combination Lamp * Rear Tail & Stop -- See Tail Lights
#26717-89920 BULB 1V-23/8W Type 1034ᴳ * Japan * North America (can also use 27/8W Type 1157) 12/5 watt * other countries
3. 10-AMP FUSE
(2 needed) 08941-11000 for Fuse Box
4. 15-AMP FUSE
(4 needed) 08941-11500 for Fuse Box
5. Seat Belt Lamp
USA 1972-1973 Seat belt light (on top of dash) Toshiba 12V 10W Type SV8.5 31mm long
26945-H4600 (not sure if this lamp only, or whole unit) * Type 3175ᴳ e.g. Wagner 12100
6. Dome Lamp
#26736-89902 (room lamp) Sedan, Coupe
#26715-89900 for truck version
7. Instrument Panel Lamp
The instrument panel illumination lamps use T10 bulbs. T10 bulbs come in different wattage and socket bases, the 1200 ones use a W2.1x9.5d base, known in USA as "Miniature Wedge".
* Cluster Gauge illumination bulbs, warning bulbs * SQUARE METER ONLY: + two dash T/S bulbs
7. WEDGE HOLDER & BULB
26261-89902 1.7W/2.7W bulb (ROUND GAUGE)
26261-89900 3.4W bulb (SQUARE GAUGE)
Twist-lock holder (7 used in round dash). These sockets fit bulbs with a W2.1x9.5d base (aka W2, miniature wedge, or T5 base.
Nissan 26260-89900ᴳ Wedge Socket $3.28 USD each [twist-in type] * Type V-2 Instrument Panel socketᴳ T10 cluster plug lamp for 1/2" or 13m hole * 7 or 8 for bar meter dash * 7 for B110 round gauge dash * 8 for B120 round gauge dash
USA * #26261-89902 2.7 watt bulb (ROUND GAUGE) Some Nissan catalogs say 1.7 watts * 2.7 watt Type 161 is often specified by aftermarket * 3.4 watt Type 158 is sometimes listed by aftermarket JPN B110 * #26261-89900 BULB-12V, 3.4W SQUARE METER 7 also used for B110 Tail Lights small bulb * #26261-89902 BULB-12V, 1.7W ROUND METER 7 JPN B120 B120 -8608 Tail Lights * #26261-89900 -8608 12V-3.4W 8 SQUARE METER * #26261-89900 -7803 12V-3.4W 8 ROUND METER * #26261-89902 BULB 12V-2.7W 6 * #26261-01G00 BULB 12V-1.4W 8910- F/EXH TEMP * #26711-89900 BULB 12V-1.7W 8910- F/BRAKE WARNING
T10 glass with T5/W5W base * 26261-89900 1.5 watt Ichikawa/Ichikoh Datsun B10 * 26261-30100 1.5 watt Ichikawa/Ichikoh Datsun B10 * Type 194 1.0 watt * Type 161ᴳ 2.7 watt Type 161 specs * Type 158ᴳ 3.4 watt * Type 159 6 volt
CAUTION: Type 159 is identical looking, but only 1.0 watt 6.3V. In addition there are several others including lower and higher wattage versions.
T3-1/4 glass with T5/W5W base (max. O.D.: 10.3 mm) * 194 2cp * 168 3cp * 2827 4cp * 2825 4cp (eu) * 25837 6cp
Bar Cluster Gauge uses 7 or 8 lamps including the T/S bulbs
VENDOR: RockAuto.com Product: Instrument panel bulbs☁
Type 158 less than $1 each * more watts than standard/ runs hotter * 25 lumens Hella 158 GE 158 Wagner 158LL (long life)
LED HELLA 921LED5K LED 5000K $5.32 PHILIPS 158WLED Ultinon LED $9.17 HELLA 921LED65K LED 6500K $5.37 194-xHP5-CAR 85-95 lumens $4.5 SuperBrightLeds.com
Since the LED version can be so much brighter, consider a dimmer.
LEDs get darker than incandescents, so remember to replace them long before they burn out.
Incandescent 2000 hours 7% loss CFL 10000 hours 22% loss LED 20000 hours 30% loss
8. Exterior Lamp
Side-marker lamp 6 watt (flashing, non-North America) 8 watt (North America, non-flashing) * Wagner 97 * Sylvania 97 (9.32 watt nominal)
License Lamp 7.5 watt Coupe, Van 26715-89901 Ichikho 10 watt Sedan, except North America 7.5 watt Sedan USA * B29.012.625ᴳ (7.5w) or [Toshiba A12V8W 6 7]
Reverse Light - 10 watt
9. Instrument Panel Turn Signal
Indicators (2 needed)
BULBS FOR DASH T/S INDICATORS * #26261-89900 BULB 3.4 watt (SQUARE GAUGE) wedge socket use * #26711-89900 BULB 1.7 watt (ROUND GAUGE) 26260-H1800 SOCKET-WITH LEAD WIRE can use 1.9 watt Type 1445ᴳ e.g.Wagner 1445 1.9W G3-1/2 (7/16" globe) BA9S, 22.7 mm long 1445 specs
Lamp Specifications
Australia
1974 B120 Owner's Manual (Page 30 ... 30)
Bulb Chart
Headlight unit 12V-50/40W Directional 12V-21/5W Parking 12V-21/5W Side Flasher 12V-6W License Plate Sedan 12V-10W Wagon, Van 12V-7.5W Rear Combo Tail 12V-21/5W Stop (brake) 12V-21/5W Turn Signal 12V-21W Back-up 12V-21W Meter (bar type) illumination 12V-3.4W IGN warning 12V-3.4W T/S 12V-3.4W BEAM 12V-3.4W OIL 12V-3.4W Clock 12V-3.4W Room light 12V-10W
Rectangle Meter specs (1974 B120)
Head Lamp #26705-04101 Sealed beam unit (Koito) #26705-08700 Sealed beam unit (Koito)
Front Combination Lamp early #26717-89920 BULB (12V-23/7W) #26261-89900 BULB (12V-3W)
Front Combination Lamp from 1973 September #26717-89900 BULB (12V-23) [P21W] #26261-89920 BULB (12V-8/3.4W) [P21/5W???] #26261-89925 BULB (12V-8/3.4W) 7804-
North America
1972 USA Owners manual (Page 36 ... ):
Bulb Chart
| Spec. | SAE No. | Nissan/Ichiko | |
| Headlight unit | 50/40W | 6012ᴳ | #26705-04201 |
| Front Combo Light Direction and Parking | 23/8W | 1034* | #26717-89920 |
| Side marker | 8W | 67ᴳ | #26715-89902 |
| License plate | 7.5W | 89ᴳ | #26715-89901 |
| Rear Combo Light Tail Stop (brake) Turn signal Back-up light | 23/8W 23/8W 23W 23W | 1034* 1034* 1073^ 1073 | #26717-89920 #26717-89900 |
| Wiper Knob (1973) | 3.4W | 158ᴳ | ? |
| Heater control (1973) | 3.4W | 57ᴳ | ? |
| Meter (round gauge) illumination | 1.7W | 161ᴳ | #26711-89900 |
| IGN warning | 1.7W | 161 | #26711-89900 |
| Turn Signal | #26713-89900 | ||
| BEAM | 1.7W | 161 | #26711-89900 |
| OIL warning | 1.7W | 161 | #26711-89900 |
| BRAKE warning | 1.7W | 161 | #26711-89900 |
| Room light | 10W | n/a | #26736-89902 |
^ 1156ᴳ can replace type 1073ᴳ
Portugal
Opticas 12V-50/40W 12V-21/5W Luz de mudança de direcção o de presença 12V-6W Luzes laterais de mudança de direcção 12V-7.5W Luz da chapa de matricula
Conjunto de luzes traseiras 12V-5W luz de presença 12V-21W luz de stop (travões) 12V-21W luz de mudança de direcção 12V-21W luz de marcha atrás
12V-3W Luz de iluminacão do painel de instrumentos 12V-3W Luz avisadora da ignicão 12V-3W Luz indicadora dos máximos 12V-3W Luz avisadora da pressao do óleo 12V-10W Luz interior 12V-3W Luz de iluminação do relogió
E= Nissan Part Numbers =
26151-89910
26151-89910 UNIT-sealed beam (12V-35W) KOITO
Fog Lamps OPTION * JPN B110 Fog Lamp Part Numbers
26261-01G00
Nissan 26261-01G00ᴳ BULB 8910- 12V-1.4W F/EXH TEMP Nissan 26260-95W00ᴳ SOCKET ASSY-BULB 8910- F/EXH TEMP
26261-89900
Nissan 26261-89900ᴳ BULB 3.4 watt [exterior lights + rectangle dash]
type 158ᴳ 3.4W
14V-3.36W Miniature Wedge T3-1/4 Glass (25.8mm MOL 10mm diameter) W2.1x9.5d Base
#9. Instrument Panel Turn Signal #7. Instrument Panel Lamp Meter Part Numbers SQUARE GAUGE DASH * JPN B110 bar meter * JPN B110 Tail Lights * JPN B110 KPB110 Tail Lights * JPN B120 -8608 Tail Lights * JPN B120 -7803 TURN SIGNAL (2) * JPN B120 8910- BRAKE WARNING (1) * Many 2000s era Nissan Cargo Lamp, Marker Lamp, Tail Lamp, etc
26261-89902
Nissan 26261-89902ᴳ BULB 12V-2.7W WEDGE TYPE $2.89
Official Nissan parts catalogs list it as 2.7W (B120) or 1.7W (B110,PB110 -- which also show an incorrect illustration). Even Nissan USA shows two different wattage for the same bulb.
#7. Instrument Panel Lamp Meter Part Numbers ROUND GAUGE DASH * B110, B120 * R35 Nissan GT-R 2015-2018 Premium [door courtesy lamp bulb, step lamp]
26705-04101
26705-04101ᴳ Sealed beam unit (Koito)
Headlight Part Numbers * JPN B120 -8910 (except Okinawa -8503)
26705-08700
26705-08700ᴳ Sealed beam unit (Koito)
26705-04201
26705-04201ᴳ UNIT-SEALED BEAM (ICHIKHO) <> #26705-89925 (ICHIKHO) * 12V-50/40W
Headlight Part Numbers * USA B110
26705-89905
26705-89905ᴳ UNIT-SEALED BEAM (KOITO) * 12V-50/40W
26705-89920
26705-89920ᴳ HEAD LAMP UNIT IKI
26705-89925
26705-89925ᴳ UNIT-SEALED BEAM (ICHIKHO) <> #26705-04201 (ICHIKHO) * 12V-50/40W
Headlight Part Numbers * USA B110 * JPN HEAD LAMP UNIT IKI F/OKINAWA -8503
26705-C9920
26705-C9920ᴳ HEAD LAMP UNIT [square type]
Headlight Part Numbers * JPN B120 8910-
26711-89900
Nissan 26711-89900ᴳ BULB 12V-1.7W * G10 glass with BA9S base (10MM Globe with 9mm Bayonet mount)![]()
#9. Instrument Panel Turn Signal qty 2 Meter Part Numbers round guage * USA B110 * JPN B110 * JPN B120 7804- * JPN B10 Coupe 8
26717-89900
Nissan 26717-89900ᴳ BULB 12V-23W Turn Signal bulb (front and rear)
#. single bottom contact USA/JPN B110, B120 Rear Combo Lamp T/S (turn signal) bulbs USA/JPN B110, B120, B210 Front Combo Lamp T/S (turn signal) bulbs JPN PB110 Front Turn Signal Lamp JPN KPB110 Rear Combination Lamp * S-8 size and shape, single contact bayonet base
Type 1073ᴳ but can also use 27 watt Type 1156ᴳ e.g. Wagner 1156
26715-89900
26715-89900ᴳ BULB-6W * G14 globe style * superceded 26073-30001ᴳ
Side Lamps Japan market B10 Lights#Side Lights JDM Room Lamp Japan truck 510 Side Marker (Canada to September 1969)
26715-89901
26715-89901ᴳ BULB 12V-7.5W (ICHIKO) * 12V-7.5W
License Lamp Part Numbers * USA B110 Sedan, Coupe * JPN B120 Truck * JPN B110 Coupe * JPN B110 Van 1970-1971
26715-89902
26715-89902ᴳ * 12V-8W * USA B110 front & rear Side Lighting Parts Numbers
26717-89920
26717-89920ᴳ BULB 12V-23/8W (ICHIKHO) Type 1034ᴳ * 12V-23/8W
Front Combination Lamp Part Numbers Direction and Parking * USA/JPN B110 Sedan Rear Combination Lamp Part Numbers * USA/JPN KB110 Coupe Rear Combination Lamp Part Numbers * JPN PKB110 coupe rear combination lamp * JPN VB110 Van Rear Combination Lamp Part Numbers * JPN B120 -7308 Truck Rear Combination Lamp Part Numbers
Incandescent Miniature type 1034
- 23/8.3 watt (1.8/.59 amp) 12.8/14 volt
- 200 hours marker lamp (primary filament)
- 5000 hours indicator lamp (secondary filament)
- Base: S8 Double Contact Index Bayonet (BAY15d) Base
- Sylvania 36111 161 lumens (402 lumens initial)
Can also use 27/8W type #1157. Higher wattage. Same brightness.
26718-26500
26718-26500ᴳ BULB (12V-30W) ICHIKOH * 30W * 白熱 [incandescent] * S25Y yellow globe (25mm diameter glass) * BA15s socket (15mm diameter base)
Fog Lamps OPTION * JPN B110 Fog Lamp Part Numbers * JPN PB110 PB110_lights#Fog_Lights * JPN 510 Fog Lamps * JPN B210/PB210 (to 1973.12) B210 Fog Lamps
possible replacements (35W) bulb S25Y BA15s 35Wᴳ * KOITO 4519Y * Stanley 26585819 35W * Stanley A4580Y * Stanley 501 * Toyota 90981-13026/90981-13026-76
26718-89906
26718-89906ᴳ BULB 12V-35W incandescent globe ICHIKOH $12 CAD * supercedes 26713-34200/26713-34210 * 12V-35W * Yellow globe
Fog Lamps OPTION * JPN B110 Fog Lamp Part Numbers * 1965-1970 SP311 Datsun Fairlady 1600, SPL311 Sports 1600 (Datsun Roadster) * 1967-1970 SR311 Datsun Fairlady 2000, SRL311 Sports 2000 * 1965-1968 Datsun 520 * 1969-1972 Datsun 521
26719-26500
26719-26500ᴳ BULB (12V-55W) ICHIKOH
- 沃素 [iodine, possibly a mini halogen bulb]
Fog Lamps OPTION * 510 265 Grille /w Fog Lamps * 510 Fender mount fog lamps
26750-25710
26750-25710 BULB (12V-55W) 2 KOITO
1157
VENDOR: RockAuto.com Product: 1157 Light Bulb☁
27/8W Type 1157ᴳ * Same brightness as #26717-89920 (type 1034) * More heat generated * More current used. Renew Fuse Box contacts * 1200 hours marker lamp (primary filament) * 3000 hours indicator lamp (secondary filament) * 161 lumens (402/38 lumens initial)
16 cents to $3.11 Wagner 1157 $0.16 Philips 1157LL $0.88 long life 2-pack Hella 1157 GE 1157 GE 1157NH Nighthawk 50% More Light (shorter life) $0.44 PHILIPS 1157CV CrystalVision 30% more light $3.27
LED version 100/330 lumens -- much brighter. A brand-new incandescent is brighter (402 lm), but quickly drops burns-in to the design lumens (161 lm).
PHILIPS 1157ALED Ultinon LED Amber $15.40
26730-S0115
26730-S0115ᴳ
26730-S0115 BULB 12V-30W * B210 Fog Lamps * used into the 90s by some Nissan fog lamps
26736-89902
26736-89902ᴳ
Room Lamp Part Numbers * USA B110 * ? JPN except Truck, Van Truck uses #26715-89900
10 watt (room lamp) * Type SV8/5168ᴳ 10 watt too long needs lamp contacts to be bent out * Type SV7, ~29 mm long seems to fit best, but are usually 3w or 5w DE3022 5W 31mm 6428 3W 29mm * SV7-8 Festoon base (pointy ends)/ LES / SV7
Some parts stores specify the longer unit (Type #3175) which is readily available, but the Room Lamp socket must be bent slightly to fit.
3175
Dome lamp type 3175 is Longer version of Nissan #26736-89902 for Datsun 1200 Sedan & Coupe. It will fit if the Room Lamp sockets are bent slightly. Or in some cases the lamp ends can be ground down to fit. 31mm long.
VENDOR: RockAuto.com Product: Dome Light Bulb☁
DE3175 bulbᴳ
Less than $1 each Wagner 12100 Philips/GE/Hella DE3175
LED $4 to $7 GE DE3175NH Nighthawk 50% More Light (higher color temperature) PHILIPS 30MMLED VisionLED PHILIPS DE3175WLED Ultinon LED 6000K Bright White
Color Temperature
The old-school incandescent light bulbᵂ is 2700K, a "soft white" color with a slightly yellowish glow. The color temperatureᵂ over 5000 K are called "cool colors" (bluish), while lower color temperatures (2700–3000 K) are called "warm colors" (yellowish).
2700K–3000K Soft White (yellowish-white) 3500K–4100K Cool White (aka Bright White) 5000K–6500K Daylight (bluish-white)
Bright White is a whiter color that appears brighter even at the same lumens.
Brightness
We typically think of the brightness of a light bulb in wattage. However, wattage simply represents the amount of energy needed to use the bulb. The lumens scale indicates the brightness of a bulb — energyearth.com
This means a 35W incandescent bulb and a 35W LED bulb will have very different brightness. In fact the LED version of a 35W indicator bulb only uses about 4W.
The lumen (lm) is the SI derived unit of luminous flux, a measure of the total quantity of visible light emitted by a source. Luminous flux differs from power (radiant flux) in that radiant flux includes all electromagnetic waves emitted, while luminous flux is weighted according to a model of the human eye's sensitivity to various wavelengths.
