There is no page titled ":Badge". You can create this page.
For more information about searching Datsun 1200 Club, see Searching Datsun 1200 Club.
Showing below up to 20 results starting with #1.
View (previous 20) (next 20) (20 | 50 | 100 | 250 | 500).
Article title matches
- Badge Part Numbers (3770 bytes)
1: Also see: [[Badges]]
29: * 76852-H1000 BADGE-"Deluxe" SEDAN-DX
30: * 76852-H2001 BADGE-"GL" SEDAN-GL
31: * 76852-H2300 BADGE-"GX" (R.H.) SEDAN-GX
32: * 76853-H2300 BADGE-"GX" (L.H.) SEDAN-GX
Page text matches
- Steering wheel (10047 bytes)
165: ...000,48400-H1001 ASS'Y-WHEEL-steering Std, Dx with Badge - Part Numbers Index (8259 bytes)
145: [[Emblem Part Numbers|Emblem]] (Badge/Mark) - GX-5 (8005 bytes)
1: ...fifth 5-speed [[Transmission]] and special GX-5 [[badges]].
38: ...he same grille as other 1972 coupes, but the trim badge was changed to 'GX 5speed'
45: == Grille Badge ==
46: {{Main|GX5 Badges#Grille}}
51: == Boot Badge == - Datsun 1200 SSS (14109 bytes)
28: non-standard (?) high-mounted grille badge
38: == Badges ==
41: SSS grille [[Badges#1200_SSS|badge]]
44: SSS boot badge (right of rear license plate)
47: SSS badge on the glove box (not fitted to all SSS) - Badges (7769 bytes)
1: ...ic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
3: {{Badges_Navbox}}
6: Also see: [[Badge Part Numbers]]
8: Genuine Nissan badges are metal or plastic depending on the year made.
16: = Badge Installation = - Coupe Badges (11221 bytes)
1: {{BackTo|Badges|Coupe}}
3: Datsun 1200 Coupe used different badges than the Sedan, for the most part.
5: {{Badges_Navbox}}
15: Coupe got new grille badges and boot badges for the 1972 [[Facelift]].
17: For the individual badges, see: - Grille (9229 bytes)
66: {{Main|Truck_Badges#Mid-model}}
95: ...riginal grille during the 1972 facelift. Only the badges were changed.
109: Blackout [[Coupe_Badges#Radiator_Grille|center ornament]]
124: ...em (a.k.a. {{search|Mazda+Efini+badge|Mazda Efini badge}}/infini) 1991-1997
221: {{See|PB110_Badges#Grille}} - Model names (18990 bytes)
55: ...and name circa 1982. Datsun models were generally badged as both "Nissan" and "Datsun" for 1983 (earlier ...
70: ...erry Cab and Cherry Vanette, the latter two being badge-engineered versions of Sunny Cab and Sunny Vanett...
72: ...n Sunny, they had the Nissan Cherry. In the 1970s badge engineering came into full swing so they offered ...
109: ...dels came after the B310 Sunny, and were marketed/badges as '''{{wiki|Nissan Sentra}}''' in North America...
139: ...[#Pulsar Family|#Pulsar]] line. Some Pulsars were badged "Cherry" in certain markets. - Japan tour (7926 bytes)
55: ...peaker with you. Idea: ask for a JAF badge or car badges in general (get this written down on a card if p... - Facelift (3770 bytes)
21: * [[Badges]]
55: Coupe received updated [[Coupe Badges]] for the Facelift. Grille and Tail Lamps contin...
58: * Grill right trim badges (GL, GX) subtly changed
59: * Rear badge (center) 'Flying S' (DX,GL,GX)
71: New [[grille]], [[bonnet]] & [[Sedan badges]] - KB10 (9056 bytes)
80: Coupe GL rear badge
97: {{See|B10 Badges}} - B310 (13665 bytes)
26: ...sion 1979 "Blue on blue" 4-dr with special grille badge
177: *: North America models got 'DATSUN' badge
334: == Badges ==
335: {{Main|B310 Badges}} - Hitachi Twin Carb (12238 bytes)
106: ...ges#Hood.2FBonnet|174_5c9819b29197d.jpg|GX-T Hood Badge|height=227}} - Automatic Transmission (16924 bytes)
79: = Badges =
80: ...h a 'Nissan Full Automatic' or 'Nissan Automatic' badge:
82: {{Main|Sedan_badges#Automatic}} - 610 (7758 bytes)
75: = Badges =
81: 180B SSS sedan rear badge
82: <br>{{Photo|180B-SSS-rear-beaver-badge.jpg}} - PB110 Badges (8097 bytes)
8: The badges that appear to be the same as A12-powered B110 a...
9: * [[#79200-H2820|#Nissan Full Auto Matic]] badge (SEDAN)
10: * [[#Steering wheel badges]]
30: = Steering wheel badges = - Trim (9154 bytes)
68: ...the lowest level Coupe trim, so it has no special badges
69: * DX Grille [[Badges]] -- none on Grille, just like STD
77: * Rear fender badge 'Sunny' (Sedan DX/GL)
157: * Coupes have no trim badges -- as is usual with the base trim
233: * Sunny side [[badges]] - NLA (3309 bytes)
40: * [[Badges|Coupe badge]]
57: [[Badges]]
62: * 76852-H2001 BADGE-"GL" S-GL
63: * 76852-H2300 BADGE-"GX" (R.H.) 4-GX
64: * 76853-H2300 BADGE-"GX" (L.H.) 4-GX - 140Z (7545 bytes)
28: * 'D' grille badge
29: * '140Z' rear badge
48: This red coupe has "Z" badges. From {{web|www.cardomain.com/ride/3100730|Riaan...
51: ...custom badge? Or stock Datsun-Nissan South Africa badge? - South Africa (6663 bytes)
46: ...nd side emblems (Japan Datsun 1200 GX has 'Sunny' badges)
50: ** early Export round 'D' grille badge
60: ...as no C-pillar badge, but has a fender/wing/gaurd badge
