Strut Tops
Revision as of 20:07, 11 December 2016; view current revision
Category: Front Axle And Front Suspension
The Datsun 1200 strut top (top hat) is a rubber insulator for the the strut, and utilizes a bearing for easy rotation for the steering system. Most aftermarket adjustable strut tops do not include an insulator, so are not recommended for a street or off-road vehicle.
[hide]
Also see
Stock 1200 strut tops protrude above the tower:
The stock tops are non-adjustable regarding Wheel alignment.
The strut top consists of the Insulator, Bearing and Oil Seal
120Y - note Strut Tops differ from 1200
Measurements
Bolt circle PCD      123 mm (4.84 inch)
stud to stud center  107 mm (4.21 inch)
stud nuts            08911-10810 NUT-HEX M8 x 1.25
tower hole           94 mm 1200 (80 mm B210)
strut rod nut        08912-34210 NUT-HEX SELF LOCK M12
strut rod hole       about 12 mm???
123 mm Circle (107 mm stud to stud) is the same as Datsun 510(1600), A10 (Stanza/510), Nissan Silvia, R31, etc.
1200
Comparison
Strut tops: B210 (left) vs B110 (right)
The B110 strut tops are different from B210 tops. They latter have a higher profile and raise the car up, so use the B110 tops. If there is nothing poking up through the hole in the strut tower,then it's "wrong" for a 1200.
Fitting 1200 tops into 120Y lowers the car 30mm
25205.jpgAlbum 25205 10022.jpgAlbum 10022
See Lowering B210
Fitting B210 strut tops to a 1200 raises the car about 30 mm
1204.jpgAlbum 1204
B310 tops are same as 1200, except they have larger M10 studs instead of M8 studs. They will fit the 1200 if the strut tower bolt holes are file out just a touch.
Covers
B210 Tops - small 80 mm, fit B210 & B310
64815-H5000 CAP-support, front suspension spring
TIP: You can use rubber covers from an early 90's Mazda 323 w/ electric adjustable suspension. These covers sits perfectly over a 1200 strut tower, even with large 1200 strut tops or camber-adjustable strut tops.
Strut Rod Nut
M12  B110,B210,B310,N10
     S130,510,810,910,S12,T11,Z31
     08912-34210 > 54324-21000
54320-H1000 INSULATOR-STRUT MOUNTING (2)
 08915-53810 WASHER-PLAIN M8 (6)
 08915-13810 WASHER-SPRING M8 (6)
 08911-10810 NUT-HEX M8X1.25 (6)
54325-H1000 BEARING-STRUT MOUNTING (2)
B110
08912-34210 HEX NUT SELF LOCK M12 [for strut rod] < 54324-21000
54308-H1025 GLAND PACKING KIT [45 mm]
08911-10810 M8x1.25 [for strut top]
HB210 USA (2.0" strut tube)
54308-W5025 GLAND PACKING KIT 1976-1978
54308-U0127 GLAND PACKING KIT 1974-1975 <> 54308-U0125
08912-34210 LOCK NUT M12 [for strut rod]
54320-H5000 STRUT MOUNTING INSULATOR
08911-64010 NUT-HEX M10 (6)
N10 USA
56105-M7027 N10 FRONT SHOCK ABSORBER KIT [insert]
08911-14210 M12 nut [for strut rod]
54308-M3026 STRUT GLAND PACKING KIT
54320-M0204 STRUT MOUNTING INSULATOR
B310
08911-64010 HEX NUT M10 [for strut top]
08912-44210 NUT M12 [for strut rod]
54210-N8200 STRUT MOUNTING INSULATOR <> 54320-W5000
54308-W5025 GLAND PACKING KIT [2 inch?]
Z31
08912-8421A NUT [for strut rod] M12
54308-01P25 PACKING KIT-GLAND,STRUT -8609
54308-01P10 PACKING KIT-GLAND,STRUT 8609-
48366-DA00A NUT-HUB BOLT [for strut top]
54320-N8200 INSULATOR-STRUT MOUNTING
* B310 7902-
* S110 1979-1983
M10 bolts GOLDEN RUBBER 54320-N8200 BEST QUALITY
Camber Tops
Aftermarket strut tops (camber plates) are adjustable in one or two dimensions. Unfortunately, most do not include an insulator and so will transmit shock and vibration to the body.
Adjustable in one dimension (camber only):
Two dimension adjustable (camber + caster):
Bolt circle: 123mm
NOTE: The standard springs diameter restrict how much camber/castor you can get by moving the top of the strut around -- if you just buy the adjustable tops, you'll find you can maybe get 1 degree more camber before the spring hits the inside of the strut tower. This is why when most people get adjustable strut tops, they also go for smaller diameter springs, which one you've done that, you may as well pay the extra coupla hundred for adjustable height threaded sleeves. See Coilover Kits.
Top Nut
All Datsun struts use a strut rod thread at the end for an M12 nut. Some camber tops use a regular nut, while others used a shanked nut.
standard lock nut
Shanked nut, in various Outside Diameter to fit various bearing hole sizes
Collar, so that small-diameter Strut Rods can fit large-hole Bearing
Retainer for alloy spring cup
10116.jpgAlbum 10116 10117.jpgAlbum 10117 10118.jpgAlbum 10118
Datsun Competition
The Datsun Competition suspension manual recommends slotting the tower bolt holes for camber adjustability.
See main article: Camber
DIY
For about $20, you can make camber tops. Buy a 5mm (1/4") circle 6" in diameter. Fit into strut tower, and mark the holes. Drill the three holes. Drill the center hole off-center for extra negative camber. Mount using the stock strut top bearing.
These won't have the stock rubber anti-shock mounting.
You can also drill the center hole a little rearward of center for extra castor, but with large-diameter tires it runs the risk of pulling the tyre in to the footwell. See Castor.
Strut tower hole opened up (to allow maximum adjustment), and custom camber tops fitted:
Noltec
NOLTEC makes camber tops for Datsun B110, B120, 120Y & B310.
N44071  polyester bushed for street use (bell above)
N44071s Solid mounted for track use (bell above)
NOLTEC N44016  polyester (for street) bell below
NOLTEC N44016S solid (for clubsport) bell below
Trim the sections of the centre plate that are hanging out.....then you will get plenty of adjustment.
"Bell above" vs "bell below" styles
full
full
Cusco
Cusco 204 410 A is a pillowball top hat for Datsun 1200.
http://www.cuscousainc.com
10085.jpgAlbum 10085 10084.jpgAlbum 10084
* Camber Adjustable Type
* Can be used with OE spring
* +30mm Vehicle Ride Height raised
* Comes with Pillow Nut: H (M12x1.25mm, Depth 5mm)
* Comes with Collar: Type 10
Ground Control
http://www.ground-control.com
mounts on top of strut tower for extra travel
Aftermarket
S13 camber tops fit straight into the 3 holes of the Datsun 1200 strut towers.
The only downside is that as the 1200 strut top reaches up through the strut tower 2 inches, you would be then mounting the shocker end 2 inches lower using adjustable tops. This means you have lost two inches of shocker travel in the bump direction. So it is preferable to get "bell above" style tops to mitigate this.
Camber tops may raise the car say 30 mm (such as the Cusco tops), and if so after fitting you can lower the car back down by lowering the spring perch. This is OK with otherwise stock suspension, but if your car is already lowered it may be necessary to use a shorter strut insert but which still has a full range of travel.
Generic Nissan tops mount 180 degrees the wrong way so when set for negative camber in a 1200 that would be the setting for positive camber in an s13.
discussion
Alternatively, you may rotate them 180 deg although some brands will need grinding on one side to fit this way.
You might have to do this to get the top studs come through.
post
They also need a rose joint spacer between bearing and tophat to allow spherical bearing in tophat to allow movement!
The strut rod may not go through the top hat far enough to get the nut on. So use a shanked nut (as come with aftermarket kits).
This shanked nut also fits the large hole, and centers the small strut rod.
discussion
If using non-stock strut inserts such as the VW Golf inserts, the strut rod is a different diameter. In this case you may need a different shank nut, or a different pillow joint spacer.
discussion
Adjustable strut tops are often available on eBay, or some buy them from TRD. Most Datsun/Nissan use the same bolt circle, but some use larger diameter bolts or larger strut shaft diameter (modify as necessary):
* eBay
* TRD
* Cusco
* http://www.otomoto.com.au
* as part of a Coilover Kit
maddat
S13
Andos
rock1200
SCCA
Lowering tops
IMG_2977.jpgPost click for topic IMG_2970.jpgPost click for topic
racetech
10007.jpg 11182.jpg 12037.jpg 14796.jpg 10519.jpgAlbum click to view
